1 Reply Latest reply on Jul 2, 2008 7:34 AM by SujitG
    returning data which can access AS function
    ccrum
      I migrating from an HTML/Flash app previously built to an all FLEX app. The previous app ran a db query through AJAX to an ASP script and returned the results (basically a list of names) as a series of forms (each name was essentially it's own form), which, when clicked on, fired some javascript to do some other actions. A single result looked like this:
      <form style="margin: 0;" target="_blank" id="frm117" action=" http://www.wispmon.com/gis/getcust.pl" method="POST"><input type="hidden" name="CustomerID" value="117" /><input type="hidden" name="WispID" value=" 10001 " /><a href="javascript:void(0);" onclick="link(frm117)"><font color="#FF0000">Monty Smith</font></a>
      The javascript function "link()" basically just submitted the form to the cgi script.
      I have the FLEX app calling the same ASP script and returning the same results to a TextArea, but what I want is instead of the results being a form and firing the javascript, I want it to be a flex text field and have them fire some AS Function which will perform the same action as my "old" app. I guess the question is, can I build FLEX controls on the fly?
        • 1. Re: returning data which can access AS function
          SujitG Level 2
          You can definitely create Flex controls during run time. All you have to do is to instantiate the component and add it to container. I created a very simple sample code which adds a TextArea at runtime. Please find the sample code attached.
          Hope this helps.
          Code:
          <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="vertical">
          <mx:Script>
          <![CDATA[
          import mx.controls.TextArea;
          private function addTextArea():void
          var txt:TextArea = new TextArea();
          txt.text = "Hi this is added at run time";
          this.addChild(txt);
          </mx:Script>
          <mx:Button label="Add text area" click="addTextArea()"/>
          </mx:Application>
