Version: Adobe Pro DC 2017.01.12.20098
I can no longer add a Digital Signature field into my fillable PDF forms for some reason.
I can add a Signature Field but it is a "Text Field" so when I use Adobe Sign to send out for Signature its does not ask the user to sign those "Text Fields" so when the user submits the form back those forms are blank.
Can I get some suggestions on how to insert these signature fields??
Hi Ngbahamas,
Sorry for the delay in response.
I hope you already have found an answer/solution to your problem. If not you may check this help page: Get multiple signatures on a single document | and Send PDF documents for signature, Adobe Acrobat
Let us know if that helps.
-Tariq Dar
