1 Reply Latest reply on Oct 29, 2017 10:45 AM by John T Smith
    Activation endommagée
    AlainC141
      Bonjour;  / Bonsoir;
      J'utilise ADOBE DESIGN PREMIUM CS3 mais depuis que je suis passé à WINDOWS 10 j'ai un message d'erreur qui me dit que mon activation est endommagée.
      Que puis-je / dois-je faire pour résoudre mon problème ?
      Merci d'avance pour votre aide.
      Alain
        • 1. Re: Activation endommagée
          CS3 and Acrobat 8 activation server is retired see reply #1 https://forums.adobe.com/thread/2372929
          -steps to fix activation problem in https://forums.adobe.com/thread/2385900
          Two ideas that MAY work to install and/or run old programs in Windows 10
          -RIGHT click the program icon or EXE and select a compatibility mode in the pop up option window
          -or Run as Administrator http://forums.adobe.com/thread/969395 to assign FULL Windows permissions may help... says Encore, but sometimes required for ALL Adobe programs (this is NOT the same as using an Administrator account)
          Owners of old programs simply have problems with Windows 10... none of which is Adobe's fault... Adobe did not change your old program to make it stop working... Microsoft changed their operating system and THAT is why your old program won't work, not because of anything Adobe did... Also... every time Microsoft issues a Win10 update, there is the risk that an old program that HAS been working after the initial Win10 upgrade will STOP working... bottom line, old programs require a matching old operating system
