Expand my Community achievements bar.
SOLVED
Dynamic form sequence
Avatar
Level 2
We are using AEM forms in our project and one of the requirements is to change the form sequence basis external trigger such as user input, or url parameters.
E.g. If user is identified to be of type "A", then sequence should be 1, 2, 3, 4, 5, 6, 7, 8
If user is identified to be of type "B", then sequence should be 1, 5, 2, 3, 8, 4, 5, 6, 7
Similarly other combinations can be configured.
This needs to be configurable such that sequence can be changed when required. Is this achievable via AEM forms?
1 Accepted Solution
Avatar
Correct answer by
Level 8
How complex are the rules to determine the order and are they determined server side or client side?  You can hide and show panels via script in the form or server side you may look at form sets.
View solution in original post
Avatar
Level 2
We are not using Adobe target.
I've gone through the documentation you shared and it doesn't talk about sequencing. The usecase I'm trying to solve is little complicated.
More suggestions welcome.
Avatar
Level 10
I have never read anything about this use case in AEM Forms docs. I am checking with the internal team to make sure.
Avatar
Correct answer by
Level 8
