6 Replies Latest reply on Sep 7, 2018 2:41 AM by Pretend that I am ACP
    Script to arrange artboard in grid
    charur94718007 Level 2
      Hello guys, I need a script to arrange selected artboards in a grid format in photoshop cc 2017 or cc 2018. Thanks in advance
        • 1. Re: Script to arrange artboard in grid
          Jarda Bereza Level 4
          Can you upload image how result of script should look at your screen?
          • 2. Re: Script to arrange artboard in grid
            Here is more description A simple script to rearrange selected artboards into a grid with the option of how many rows and columns + how much spacing between them vertically and horizontally. Preferably in the order they're laid out in the layers panel. This is all assuming that the selected artboards have the same dimensions to make the math slightly easier. Final result will be as in screen shot.Screen Shot 2017-10-30 at 7.27.59 PM.png
            • 3. Re: Script to arrange artboard in grid
              Level 1
              Hello, where can you share this script with me?
              I need him very much.
              • 4. Re: Script to arrange artboard in grid
                I didn't make script for this. I just wanted to make the question more clear if other scripters would have interest.
                • 5. Re: Script to arrange artboard in grid
                  r-bin Level 5
                  var clms = 5;
                  var space_x = 20;
                  var space_y = 20;
                  clms = prompt("Columns", clms, "Input");
                  if (clms)
                      clms = Number(clms);
                      var arts = new Array();
                      var w = 0;
                      var h = 0;
                      for (var i = 0; i < activeDocument.layerSets.length; i++)
                          var r = new ActionReference();
                          r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("artboardEnabled"));
                          r.putIdentifier(stringIDToTypeID("layer"), activeDocument.layerSets[i].id);
                          if (executeActionGet(r).getBoolean(stringIDToTypeID("artboardEnabled")))
                              r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("artboard"));
                              var rect = executeActionGet(r).getObjectValue(stringIDToTypeID("artboard")).getObjectValue(stringIDToTypeID("artboardRect"));
                              var l = rect.getDouble(stringIDToTypeID("left"));
                              var t = rect.getDouble(stringIDToTypeID("top"));
                              var r = rect.getDouble(stringIDToTypeID("right"));
                              var b = rect.getDouble(stringIDToTypeID("bottom"));
                              arts.push([activeDocument.layerSets[i], [l,t,r,b]]);
                              var w1 = r-l;
                              var h1 = b-t;
                              if (w1 > w) w = w1;
                              if (h1 > h) h = h1;
                      var rows = Math.floor(arts.length/clms);
                      if (rows*clms < arts.length) ++rows;
                      var i = 0;
                      for (var y = 0; y < rows; y++)
                          var pos_y = y * (h + space_y);
                          for (var x = 0; x < clms; x++)
                              if (i >= arts.length) break;
                              activeDocument.activeLayer = arts[i][0];
                              var pos_x = x * (w + space_x);
                              move(pos_x-arts[i][1][0], pos_y-arts[i][1][1])
                              i += 1;
                  function move(x, y)
                      try {
                          var d = new ActionDescriptor();
                          r.putEnumerated(stringIDToTypeID("layer"), stringIDToTypeID("ordinal"), stringIDToTypeID("targetEnum"));
                          d.putReference(stringIDToTypeID("null"), r);
                          var d1 = new ActionDescriptor();
                          d1.putUnitDouble(stringIDToTypeID("horizontal"), stringIDToTypeID("pixelsUnit"), x);
                          d1.putUnitDouble(stringIDToTypeID("vertical"), stringIDToTypeID("pixelsUnit"), y);
                          d.putObject(stringIDToTypeID("to"), stringIDToTypeID("offset"), d1);
                          executeAction(stringIDToTypeID("move"), d, DialogModes.NO);
                      catch (e) { throw(e); }
                  3 people found this helpful
                  • 6. Re: Script to arrange artboard in grid
                    Level 1
                    I saw you again. You really are the second enthusiastic foreigner I have ever met.
                    Thank you very much for your script he is very good
                    You are really a programming god
