1 Reply Latest reply on Dec 18, 2017 8:25 AM by Tariq Dar
    Creating PDF/A
    Brandime
      I am using, in this case Acrobat XI pro. In an attempt to save a document, that was scanned using a different application (Kofax Express 3.2), as a PDF. I am finding that after running text recognition pages that were oriented correctly have been rotated, either upside down or 90 degrees. Has anyone noticed this issue when using the text recognition?
        • 1. Re: Creating PDF/A
          Tariq Dar Adobe Employee
          Hello,
          I hope you already have found an answer to this question.
          Rotate your page before you convert a file to PDF/A.
          Rotate pages You can rotate all or selected pages in a document. Rotation is based on 90° increments.
          You can rotate pages using the rotate tools in the Page Thumbnails pane or by using the Rotate option (described below).
          1 Choose Tools > Pages > Rotate.
          2 For Direction, select the amount and direction of the rotations: Counterclockwise 90 Degrees, Clockwise 90 Degrees, or 180 Degrees.
          3 For Pages, specify whether all pages, a selection of pages, or a range of pages are to be rotated.
          4 From the Rotate menu, specify Even Pages, Odd Pages, or both, and select the orientation of pages to be rotated.
          For reference, page number 267 : https://help.adobe.com/archive/en/acrobat/XI/acrobat_reference.pdf
          -Tariq Dar
