8 Replies Latest reply on Nov 6, 2017 5:04 PM by webukaty
    Blur Gallery in CC2018
    webukaty
      I 'm on Windows 10 and recently upgraded to Photoshop CC2018. Every time I try to use the Blur Gallery, Photoshop crashes. What's up with that? Anyone have a clue? My scratch drive has plenty of space, and there's plenty of RAM assigned. I'm swingin'
        • 1. Re: Blur Gallery in CC2018
          Trevor.Dennis Adobe Community Professional (Moderator)
          Blur Gallery uses the GPU, but will work — albeit not so quickly — without GPU assistance.  Try turning off GPU acceleration in Preferences > Performance.  If the system crashes stop, then look to see if there is a later driver for your video card, but do so from the card maker's website.
          If you are not sure how to proceed, go Help > System info > Copy and paste to this thread so we can see what hardware etc you are using.
          • 2. Re: Blur Gallery in CC2018
            webukaty Level 1
            Thanks! That worked, but it makes no sense to me. I guess at this point, I should stop expecting Photoshop to make sense. Your reply is greatly appreciated!
            • 3. Re: Blur Gallery in CC2018
              Adobe add GPU acceleration to more functions with most updates, and it makes quite a difference to the performance.  So long as you keep your video card driver up to date, it will behave itself in most situations.  When that is not the case, you can try different settings for Drawing Mode in Preferences > Performance.  You don't want to run with GPU acceleration turned off if you can avoid it, as it causes a significant performance hit doing so.
              • 4. Re: Blur Gallery in CC2018
                webukaty Level 1
                I checked it out, and it seems everything is up to date, so I'm not understanding why Blur Gallery works with GPU acceleration off, but not on. It's kind of weird. I normally keep GPU Accel. on for 3D and generating web assets, and everything works fine. I guess I can just turn it off when I need the Blur Gallery, but I don't think that's the way it's supposed to work. I really appreciate your response! Thank-you!
                • 5. Re: Blur Gallery in CC2018
                  Have you tried different Drawing Mode settings?  (I was not at home when I made my last post, so could not include a screen shot.)
                  You've got nothing to lose by posting your System Info here (as per post #1) and it would be better not having to worry about GPU acceleration.  It would drive me crazy constantly having to turn it off and on, and you have to restart Photoshop to make the changes take effect.
                  • 6. Re: Blur Gallery in CC2018
                    webukaty Level 1
                    My advanced Performance settin gs were the same as yours, other than History States (mine was 50). Here's the System info:
                    Adobe Photoshop Version: 19.0 20170929.r.165 2017/09/29: 1138933  x64
                    Number of Launches: 2
                    Operating System: Windows 10 64-bit
                    Version: 10 or greater 10.0.15063.296
                    System architecture: Intel CPU Family:6, Model:13, Stepping:4 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
                    Physical processor count: 2
                    Logical processor count: 4
                    Processor speed: 2195 MHz
                    Built-in memory: 12200 MB
                    Free memory: 5268 MB
                    Memory available to Photoshop: 10663 MB
                    Memory used by Photoshop: 70 %
                    Surface Dial: Enabled.
                    Alias Layers: Disabled.
                    Modifier Palette: Enabled.
                    Highbeam: Enabled.
                    Image tile size: 128K
                    Image cache levels: 4
                    Font Preview: Medium
                    TextComposer: Latin
                    Display: 1
                    Display Bounds: top=0, left=0, bottom=1080, right=1920
                    OpenGL Drawing: Enabled.
                    OpenGL Allow Old GPUs: Not Detected.
                    OpenGL Drawing Mode: Advanced
                    OpenGL Allow Normal Mode: True.
                    OpenGL Allow Advanced Mode: True.
                    AIFCoreInitialized=1
                    AIFOGLInitialized=1
                    OGLContextCreated=1
                    NumGLGPUs=1
                    NumCLGPUs=1
                    NumNativeGPUs=0
                    glgpu[0].GLVersion="4.1"
                    glgpu[0].IsIntegratedGLGPU=0
                    glgpu[0].GLMemoryMB=1024
                    glgpu[0].GLName="Intel(R) HD Graphics 5500"
                    glgpu[0].GLVendor="Intel"
                    glgpu[0].GLVendorID=32902
                    glgpu[0].GLDriverVersion="20.19.15.4531"
                    glgpu[0].GLRectTextureSize=16384
                    glgpu[0].GLRenderer="Intel(R) HD Graphics 5500"
                    glgpu[0].GLRendererID=5654
                    glgpu[0].HasGLNPOTSupport=1
                    glgpu[0].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll,igdumdim3 2,igd10iumd32,igd10iumd32,igd12umd32"
                    glgpu[0].GLDriverDate="20160929000000.000000-000"
                    glgpu[0].CanCompileProgramGLSL=1
                    glgpu[0].GLFrameBufferOK=1
                    glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 20.19.15.4531"
                    glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447 ]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                    glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                    glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                    glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                    glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
                    clgpu[0].CLPlatformVersion="2.0 "
                    clgpu[0].CLDeviceVersion="2.0 "
                    clgpu[0].IsIntegratedCLGPU=1
                    clgpu[0].CLMemoryMB=4871
                    clgpu[0].CLName="Intel(R) HD Graphics 5500"
                    clgpu[0].CLVendor="Intel(R) Corporation"
                    clgpu[0].CLVendorID=32902
                    clgpu[0].CLDriverVersion="20.19.15.4531"
                    clgpu[0].CLBandwidth=1.3614e+10
                    clgpu[0].CLCompute=157.324
                    License Type: Subscription
                    Serial number: 94070953842123610843
                    GUIDBucket:
                    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
                    Temporary file path: C:\Users\Kate\AppData\Local\Temp\
                    Photoshop scratch has async I/O enabled
                    Scratch volume(s):
                      Startup, 929.7G, 810.6G free
                    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
                    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
                    Installed components:
                       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                       ACE.dll   ACE 2017/09/19-18:51:44   79.586793   79.586793
                       AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                       AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                       AdobeOwl.dll   Adobe Owl   5.2.11
                       AdobePDFL.dll   PDFL 2017/09/01-01:08:01   79.239219   79.239219
                       AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
                       AdobeSVGAGM.dll   AdobeSVGAGM   79.586793   79.586793
                       AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
                       AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
                       AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
                       adobe_caps.dll   Adobe CAPS   10,0,0,6
                       AGM.dll   AGM 2017/09/19-18:51:44   79.586793   79.586793
                       ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
                       AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                       amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
                       ARE.dll   ARE 2017/09/19-18:51:44   79.586793   79.586793
                       AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                       AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                       Bib.dll   BIB 2017/09/19-18:51:44   79.586793   79.586793
                       BIBUtils.dll   BIBUtils 2017/09/19-18:51:44   79.586793   79.586793
                       boost_date_time.dll   photoshopdva   11.1.0
                       boost_filesystem.dll   photoshopdva   11.1.0
                       boost_signals.dll   photoshopdva   11.1.0
                       boost_system.dll   photoshopdva   11.1.0
                       boost_threads.dll   photoshopdva   11.1.0
                       cg.dll   NVIDIA Cg Runtime   3.0.00007
                       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                       CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                       CoolType.dll   CoolType 2017/09/19-18:51:44   79.586793   79.586793
                       CRClient.dll   Adobe Crash Reporter Client DLL   1.6.1.0
                       dnssd.dll   Bonjour   3,0,0,2
                       dvaaudiodevice.dll   photoshopdva   11.1.0
                       dvacore.dll   photoshopdva   11.1.0
                       dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                       dvamarshal.dll   photoshopdva   11.1.0
                       dvamediatypes.dll   photoshopdva   11.1.0
                       dvametadata.dll   photoshopdva   11.1.0
                       dvametadataapi.dll   photoshopdva   11.1.0
                       dvametadataui.dll   photoshopdva   11.1.0
                       dvaplayer.dll   photoshopdva   11.1.0
                       dvatransport.dll   photoshopdva   11.1.0
                       dvaui.dll   photoshopdva   11.1.0
                       dvaunittesting.dll   photoshopdva   11.1.0
                       dynamiclink.dll   photoshopdva   11.1.0
                       ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1133690   81.1133690
                       icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                       igestep30.dll   IGES Reader   9.3.0.113
                       imslib.dll   IMSLib DLL   10.0.0.22
                       JP2KLib.dll   JP2KLib 2017/08/23-01:11:25   79.267771   79.267771
                       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                       libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                       libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                       LogSession.dll   LogSession   7.4.1.60.45263
                       mediacoreif.dll   photoshopdva   11.1.0
                       MPS.dll   MPS 2017/09/01-01:08:01   79.586120   79.586120
                       pdfsettings.dll   Adobe PDFSettings   1.04
                       Photoshop.dll   Adobe Photoshop CC 2018   19.0
                       Plugin.dll   Adobe Photoshop CC 2018   19.0
                       PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.0.0
                       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.0.0.55
                       PSArt.dll   Adobe Photoshop CC 2018   19.0
                       PSCloud.dll                                                   1.0.0.1
                       PSViews.dll   Adobe Photoshop CC 2018   19.0
                       SCCore.dll   ScCore 2017/08/31-12:13:14   81.1133690   81.1133690
                       SVGRE.dll   SVGRE   79.586793   79.586793
                       svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                       tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                       TfFontMgr.dll   FontMgr   9.3.0.113
                       TfKernel.dll   Kernel   9.3.0.113
                       TFKGEOM.dll   Kernel Geom   9.3.0.113
                       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                       updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                       VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                       VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                       WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
                       wu3d.dll   U3D Writer   9.3.0.113
                    Required plug-ins:
                       3D Studio 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Accented Edges 19.0 - from the file “Filter Gallery.8bf”
                       Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
                       Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
                       Average 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Average.8bf”
                       Bas Relief 19.0 - from the file “Filter Gallery.8bf”
                       BMP 19.0 - from the file “Standard MultiPlugin.8bf”
                       Camera Raw 10.0 - from the file “Camera Raw.8bi”
                       Camera Raw Filter 10.0 - from the file “Camera Raw.8bi”
                       Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
                       Chrome 19.0 - from the file “Filter Gallery.8bf”
                       Cineon 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Cineon.8bi”
                       Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
                       Collada 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
                       Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
                       CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
                       Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
                       Craquelure 19.0 - from the file “Filter Gallery.8bf”
                       Crop and Straighten Photos 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “CropPhotosAuto.8li”
                       Crop and Straighten Photos Filter 19.0 - from the file “Standard MultiPlugin.8bf”
                       Crosshatch 19.0 - from the file “Filter Gallery.8bf”
                       Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
                       Cutout 19.0 - from the file “Filter Gallery.8bf”
                       Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
                       De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
                       Dicom 19.0 - from the file “Dicom.8bi”
                       Difference Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
                       Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
                       Displace 19.0 - from the file “Standard MultiPlugin.8bf”
                       Dry Brush 19.0 - from the file “Filter Gallery.8bf”
                       Eazel Acquire 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “EazelAcquire.8ba”
                       Entropy 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Export Color Lookup Tables 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
                       Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
                       FastCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “FastCore.8bx”
                       Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
                       Film Grain 19.0 - from the file “Filter Gallery.8bf”
                       Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
                       Flash 3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Fresco 19.0 - from the file “Filter Gallery.8bf”
                       Glass 19.0 - from the file “Filter Gallery.8bf”
                       Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
                       Google Earth 4 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
                       Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
                       Halide Bottlenecks 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “HalideBottlenecks.8bx”
                       HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
                       HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
                       IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
                       IGES 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
                       JPEG 2000 19.0 - from the file “JPEG2000.8bi”
                       Kurtosis 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Lens Blur 19.0 - from the file “Lens Blur.8bf”
                       Lens Correction 19.0 - from the file “Lens Correction.8bf”
                       Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
                       Liquify 19.0 - from the file “Liquify.8bf”
                       Matlab Operation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
                       Maximum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Mean 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Measurement Core 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MeasurementCore.8me”
                       Median 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
                       Minimum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       MMXCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MMXCore.8bx”
                       Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
                       Multiprocessor Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MultiProcessor Support.8bx”
                       Neon Glow 19.0 - from the file “Filter Gallery.8bf”
                       Note Paper 19.0 - from the file “Filter Gallery.8bf”
                       NTSC Colors 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “NTSC Colors.8bf”
                       Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
                       OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
                       Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
                       Palette Knife 19.0 - from the file “Filter Gallery.8bf”
                       Patchwork 19.0 - from the file “Filter Gallery.8bf”
                       Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
                       PCX 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PCX.8bi”
                       Photocopy 19.0 - from the file “Filter Gallery.8bf”
                       Photoshop 3D Engine 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Photoshop3DEngine.8bi”
                       Photoshop Touch 19.0 - from the file “PSDX.8bi”
                       Picture Package Filter 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
                       Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
                       Pixar 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Pixar.8bi”
                       Plaster 19.0 - from the file “Filter Gallery.8bf”
                       Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
                       PLY 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
                       Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
                       Portable Bit Map 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PBM.8bi”
                       Poster Edges 19.0 - from the file “Filter Gallery.8bf”
                       PRC 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
                       Radiance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Radiance.8bi”
                       Range 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Render Color Lookup Grid 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
                       Reticulation 19.0 - from the file “Filter Gallery.8bf”
                       Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
                       Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
                       Save for Web 19.0 - from the file “Save for Web.8be”
                       ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
                       Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
                       Shear 19.0 - from the file “Standard MultiPlugin.8bf”
                       Skewness 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
                       Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
                       Solarize 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Solarize.8bf”
                       Spaces 19.0 - from the file “Spaces.8li”
                       Spatter 19.0 - from the file “Filter Gallery.8bf”
                       Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
                       Sponge 19.0 - from the file “Filter Gallery.8bf”
                       Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
                       Stained Glass 19.0 - from the file “Filter Gallery.8bf”
                       Stamp 19.0 - from the file “Filter Gallery.8bf”
                       Standard Deviation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       STL 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Sumi-e 19.0 - from the file “Filter Gallery.8bf”
                       Summation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Targa 19.0 - from the file “Standard MultiPlugin.8bf”
                       Texturizer 19.0 - from the file “Filter Gallery.8bf”
                       Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
                       Torn Edges 19.0 - from the file “Filter Gallery.8bf”
                       Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
                       U3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Underpainting 19.0 - from the file “Filter Gallery.8bf”
                       Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
                       Variance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
                       Virtual Reality Modeling Language | VRML 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       Water Paper 19.0 - from the file “Filter Gallery.8bf”
                       Watercolor 19.0 - from the file “Filter Gallery.8bf”
                       Wave 19.0 - from the file “Standard MultiPlugin.8bf”
                       Wavefront|OBJ 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
                       WIA Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WIASupport.8li”
                       Wind 19.0 - from the file “Standard MultiPlugin.8bf”
                       Wireless Bitmap 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WBMP.8bi”
                       ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
                    Optional and third party plug-ins: NONE
                    Duplicate and Disabled plug-ins: NONE
                    Plug-ins that failed to load: NONE
                    Extensions:
                       com.adobe.inapp.purchase  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
                       com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                       New Document  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.fnft\fnft.html”
                       Libraries  2.11.27 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
                       Start  2.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.ccx.start\index.html”
                       Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                       Export As  3.0.13 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                    Installed TWAIN devices: NONE
                    • 7. Re: Blur Gallery in CC2018
                      webukaty Level 1
                      No answers, eh?
                      • 8. Re: Blur Gallery in CC2018
                        webukaty Level 1
                        FYI, this is not solved. Not by a long shot. Also, btw, changes to preferences don't need a restart to take affect.
