1 Reply Latest reply on Jun 16, 2008 6:26 AM by SujitG
    Flex Messaging
    ParomitaDey15 Level 1
      We have used Flex messaging in an Flex/Java based application (Flex 2.0.1). The messaging works fine in our production/QA server. But when we deployed the application to the production server, which can be accessed by a public IP, the messaging feature failed. Nevertheless, if we connect the production server using a VPN connection and use an internal IP to run the application, the messaging is working but does not work when the same application is accessed using the public IP.
      We have used rtmp channel for messaging and we have opened the port used in both the public IP as well as the internal IP.
      <channel-definition id="my-rtmp" class="mx.messaging.channels.RTMPChannel">
      <endpoint uri="rtmp://{server.name}:2037" class="flex.messaging.endpoints.RTMPEndpoint"/>
      <properties>
      <idle-timeout-minutes>20</idle-timeout-minutes>
      </properties>
      </channel-definition>
      Still we have the same problem. We are unable to find the reason for the dubious behavior.
      Could anyone please help us to resolve this problem. What possibly could be going wrong?
      Thanks and Regards,
      Paromita
        • 1. Re: Flex Messaging
          SujitG Level 2
          Can you please try recompiling/cleaning your Flex project with your server name replaced in the end point URL of your services-config.xml. i.e change the end point URL to rtmp:servername:2037 and clean your Flex project.
          Hope this helps.
