0 Replies Latest reply on May 15, 2008 6:06 AM by garag
    XML node inserting
    garag
      Hi
      is it possible use the function insertChildAfter() (or another useful function) to insert a node under the root node?
      For example, suppose that the initial xml is the following:
      var xml:XML =
      <menu>
      <item>burger</item>
      <item>soda</item>
      </menu>;
      and I would insert the node
      <aaa>bbb</aaa>
      just under the root and before the other nodes already placed under the root. The expected result is this:
      <menu>
      <aaa>bbb</aaa>
      <item>burger</item>
      <item>soda</item>
      </menu>
      How is it possible to do in flex3?
      Thank you very much.
      Regards
