Hello! I am a designer. I am NOT GOOD WITH CODE!! So... I am looking for a way to make animations.. sometimes fancy sometimes just animate buttons. Then I would like to export to be used in Xcode. Is this possible through using Flash Builder... or some other software? If I have to use flash code thats ok because I did that years and years ago and can probably pick it up again. But I am just looking for a way to export it to be used in Xcode so I don't have to build the animation through whatever code Xcode is using... swift... CSS... whatever. Thanks!!
Hi Summer...
I used to do a lot of flash... years ago...
now I use :
Animate CC = excellent for use in Websites and iOS app.
- easily integration everywhere with no need of premium ressources (.Ai)
- only one really trouble I found, there is no scrollable text block ! So for an iOS app with local webview it's a big problem.
Hype 3 = excellent to use in website, but for iOS app...
- I got a lot of difficulty to fit with all iPhones & iPad sizes.
- but they got an issue which work for scrollable block te
...Copy link to clipboard
Hi Summer...
now I use :
- but they got an issue which work for scrollable block text on iOS (but that not fit on every sizes, I really learn all about constraint but it don't work).
My heart goes to Animate CC, (easy to integrate to Xcode in Universal size) but I still have trouble to integrate a scrollable text block to my animations.
If you need some help to create a WebView in Xcode 9 for a local html (made with Animate CC : html+JavaScript)... may i can help you... for me, animations match perfectly in all Apple sized (from 5s to iPad pro 2nd generation).
I hope my answer was useful.
