9 Replies Latest reply on Nov 3, 2017 6:13 AM by Ps-Design
    Export layer to a folder:
    Ps-Design Level 1
      Hello friends! Would a script.jsx be possible to export only the active layer in the document with its respective transparency "Alpha Channel" within a folder in the path previously established in the script ?: If possible with a "trim" effect with no spaces on the 4 sides in the final file
      Example: "C: //myFolder//myFile.png"
      Thank you!
        • 1. Re: Export layer to a folder:
          SuperMerlin Level 5
          This example saves the selected layer to the main files folder with the layerName.png also with trim.
          #target photoshop;
          if(documents.length) main();
          function main(){
          try{
              var docPath = activeDocument.path;
              }catch(e){
                  alert("You need to save the document before using this script!");
                  return;
          var LayerName = activeDocument.activeLayer.name;
          dupLayers();
          //trim excess alpha
          app.activeDocument.trim(TrimType.TRANSPARENT);
          var saveFile = File(docPath + "/" + LayerName + ".png");
          SavePNG(saveFile);
          app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
          function SavePNG(saveFile){
              pngSaveOptions = new PNGSaveOptions();
          activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
          function dupLayers() {
          var desc143 = new ActionDescriptor();
          var ref73 = new ActionReference();
          ref73.putClass( charIDToTypeID('Dcmn') );
          desc143.putReference( charIDToTypeID('null'), ref73 );
          desc143.putString( charIDToTypeID('Nm  '), activeDocument.activeLayer.name );
          var ref74 = new ActionReference();
          ref74.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
          desc143.putReference( charIDToTypeID('Usng'), ref74 );
          executeAction( charIDToTypeID('Mk  '), desc143, DialogModes.NO );
          • 2. Re: Export layer to a folder:
            Ps-Design Level 1
            How wonderful! Hello SuperMerlin, you always very objective! Thank you. My goal is to create a library and for this to work 100% well, I need to modify the script so that all files are directed to that path: "C: /myfolder/myfile_layer.png". Could you show me how to make it possible? Thank you one more time.
            • 3. Re: Export layer to a folder:
              SuperMerlin Level 5
              Haveing a static file name means the file would be overwritten on the second time the script would be run, this example give you the choice to abort.
              #target photoshop;
              function main(){
              var OutputFolder =Folder("/C/myfolder/");
              if(!OutputFolder.exists) OutputFolder.create();
              var FileName = "myfile_layer.png";
              dupLayers();
              //trim excess alpha
              var saveFile = File(OutputFolder + "/" + FileName);
              if(saveFile.exists){
              var result =  Window.prompt("File exist overwrite file y/n","y");
               if(result == "y"|| result == "Y" ){
                   saveFile.remove();
                   }else{
                       return;
              SavePNG(saveFile);
              • 4. Re: Export layer to a folder:
                SuperMerlin Level 5
                This example will increment each time its run...
                #target photoshop;
                function main(){
                var Name = "myfile_layer";
                var fileList= OutputFolder.getFiles( "myfile_layer*.png").sort().reverse();
                var Suffix = 0;
                if(fileList.length){
                    Suffix = Number(fileList[0].name.replace(/\.[^\.]+$/, '').match(/\d+$/));
                Suffix= zeroPad(Suffix + 1, 3);
                var saveFile = File(OutputFolder + "/" + Name + "_" + Suffix + ".png");
                dupLayers();
                SavePNG(saveFile);
                function zeroPad(n, s) {
                   n = n.toString();
                   while (n.length < s)  n = '0' + n;
                   return n;
                • 5. Re: Export layer to a folder:
                  Ps-Design Level 1
                  SuperMerlin Pardon! the file name.png will not be static, "myfile_layer.png" I used this example only as an illustration: Personal forgiveness.
                  What I really need is to export each selected layer in this path: ("/ C / myfolder /"); whenever I execute the script: Each file will be saved with the one of the respective layer:
                  • 6. Re: Export layer to a folder:
                    SuperMerlin Level 5
                    Ah, in that case the script would be...
                    #target photoshop;
                    function main(){
                    dupLayers();
                    //trim excess alpha
                    var saveFile = File(OutputFolder + "/" + LayerName + ".png");
                    SavePNG(saveFile);
                    • 7. Re: Export layer to a folder:
                      Ps-Design Level 1
                      Wow, how fast! You are a genius SuperMerlin It was perfect. Helped me a lot. Once again thank you very much and a strong arm in you.
                      • 8. Re: Export layer to a folder:
                        r-bin Level 4
                        Why not use the built-in script in Photoshop that is called.
                        in CS6: Menu->File->Scripts->Export Layers to Files...
                        in CC2018:Menu->File->Export->Layers to Files...
                        • 9. Re: Export layer to a folder:
                          Ps-Design Level 1
                          Hello r-bin great suggestion, very last but in my specific case, I need this script because I will have to save each type of layer in different places, even if it is manually, because it is a kind of Library classified by category with different folders. Thanks for listening.
