• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How do I detect if a certain object is touching a certain color?
New Here ,
Nov 02, 2017 Nov 02, 2017
So basically I'm attempting to make a two player game:
One player is the circle the other is a square. I want the square to be the only thing that can go through the color red, but when it covers up the red:
The circle SHOULD be able to go through it. I thought that the easiest way to do this would be through detecting if the circle is touching a certain color (red) but I'm not sure how do that, if it is the best way.
Hopefully that made sense. Any help would be appreciated
TOPICS
ActionScript
Views
1.8K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Nov 02, 2017 Nov 02, 2017
Hi!
I made a working example: https://goo.gl/LhKdeE
Here is the code:
import flash.display.MovieClip;
import flash.events.KeyboardEvent;
import flash.ui.Keyboard;
import flash.events.Event;
import flash.display.DisplayObject;
var friction:Number = 0.85;
var p1:Object =
     target:circle,
     upKey:Keyboard.W,
     rightKey:Keyboard.D,
     downKey:Keyboard.S,
     leftKey:Keyboard.A,
     upPressed:false,
     rightPressed:false,
     downPressed:false,
     leftPressed:false,
     keyForce:1,
     speedX:0,
Votes
Translate
Translate
Community Expert ,
LATEST
Hi!
Here is the code:
var p1:Object =
     target:circle,
     upKey:Keyboard.W,
     downKey:Keyboard.S,
     leftKey:Keyboard.A,
     upPressed:false,
     rightPressed:false,
     downPressed:false,
     leftPressed:false,
     keyForce:1,
     speedX:0,
     speedY:0,
     maxSpeedX:10,
     maxSpeedY:10,
     color:"red"
var p2:Object =
     target:square,
     upKey:Keyboard.UP,
     rightKey:Keyboard.RIGHT,
     downKey:Keyboard.DOWN,
     leftKey:Keyboard.LEFT,
     upPressed:false,
     rightPressed:false,
     downPressed:false,
     leftPressed:false,
     keyForce:1,
     speedX:0,
     speedY:0,
     maxSpeedX:15,
     maxSpeedY:15,
     color:"red"
function keyHandler(e:KeyboardEvent):void
     if (e.type == KeyboardEvent.KEY_DOWN)
          if (e.keyCode == p1.upKey)
               p1.upPressed = true;
          if (e.keyCode == p1.rightKey)
               p1.rightPressed = true;
          if (e.keyCode == p1.downKey)
               p1.downPressed = true;
          if (e.keyCode == p1.leftKey)
               p1.leftPressed = true;
          if (e.keyCode == p2.upKey)
               p2.upPressed = true;
          if (e.keyCode == p2.rightKey)
               p2.rightPressed = true;
          if (e.keyCode == p2.downKey)
               p2.downPressed = true;
          if (e.keyCode == p2.leftKey)
               p2.leftPressed = true;
if (e.type == KeyboardEvent.KEY_UP)
               p1.upPressed = false;
               p1.rightPressed = false;
               p1.downPressed = false;
               p1.leftPressed = false;
               p2.upPressed = false;
               p2.rightPressed = false;
               p2.downPressed = false;
               p2.leftPressed = false;
function enterFrameHandler(e:Event):void
     movePlayer(p1);
     movePlayer(p2);
     checkCollision(p1.target, p2.target);
     checkCollision(p2.target, p1.target);
     if (div.colors.currentLabel != p2.color)
          checkCollision(p1.target, div);
          checkCollision(p2.target, div);
     else
          if (!p2.target.hitTestObject(div))
function movePlayer(p:Object):void
     if (p.upPressed)
          p.speedY -= p.keyForce;
     if (p.rightPressed)
          p.speedX += p.keyForce;
     if (p.downPressed)
          p.speedY += p.keyForce;
     if (p.leftPressed)
          p.speedX -= p.keyForce;
     p.speedX *= friction;
     p.speedY *= friction;
     if (p.speedX > p.maxSpeedX)
          p.speedX = p.maxSpeedX;
     else if (p.speedX < -p.maxSpeedX)
          p.speedX = -p.maxSpeedX;
     if (p.speedY > p.maxSpeedY)
          p.speedY = p.maxSpeedY;
     else if (p.speedY < -p.maxSpeedY)
          p.speedY = -p.maxSpeedY;
     p.target.x += p.speedX;
     p.target.y += p.speedY;
function checkCollision(p:Object, obstacle:Object):void
     if (p.hitTestObject(obstacle))
          // horizontal collisions
          if (p.x < obstacle.x - obstacle.width * 0.5 || p.x > obstacle.x + obstacle.width * 0.5)
               if (p.x <= obstacle.x)
                    p.x = obstacle.x - p.width * 0.5 - obstacle.width * 0.5;
               else if (p.x > obstacle.x)
                    p.x = obstacle.x + p.width * 0.5 + obstacle.width * 0.5;
          // vertical collisions
          else if (p.y < obstacle.y - obstacle.height * 0.5 || p.y > obstacle.y + obstacle.height * 0.5)
               if (p.y <= obstacle.y)
                    p.y = obstacle.y - p.height * 0.5 - obstacle.height * 0.5;
               else if (p.y > obstacle.y)
                    p.y = obstacle.y + p.height * 0.5 + obstacle.height * 0.5;
stage.addEventListener(KeyboardEvent.KEY_DOWN, keyHandler);
stage.addEventListener(KeyboardEvent.KEY_UP, keyHandler);
stage.addEventListener(Event.ENTER_FRAME, enterFrameHandler);
Notice that I used frames to check for the colors.
I hope it helps!
Votes
Translate
Translate
Report
Report
