3 Replies Latest reply on Nov 4, 2017 8:27 AM by perljamz10
    Javascript w/ Illustrator CS5: Simultaneous x, y Object Duplication
    perljamz10 Level 1
      Hi!
      I am trying to accomplish the duplication of an object so many times across a page, and then that duplicated set down the page.  Unfortunately, only the starting single object gets duplicated and I end up with an upside down L.  I know what I am doing wrong, I just don't know enough to fix it.
      I attached the code below.  I found it somewhere else and modified it a bit for my needs.  Somehow I need to group the initially created horizontal array, and then vertically duplicate that group, I'm ignorant on how to do this.  Hopefully someone can help me out.  Maintaining the simplicity and efficiency of the code is key.
      if (app.selection[0] != null) {
        var myDoc = app.activeDocument,
        selectedArt = myDoc.selection[0],
        xclone = 4, // set number of duplicates
               yclone = 6,
        horOffset = 162,  // set horizontal offset
        verOffset = -162,  // set vertical offset
        myDuplicate,
        i = 0
               j = 0
        for (i;i < xclone;i++){
        myDuplicate = selectedArt.duplicate();
        myDuplicate.position = [selectedArt.position[0] + horOffset * (i + 1), selectedArt.position[1] + verOffset * (0)];
          for (j;j < yclone;j++){
        myDuplicate.position = [selectedArt.position[0] + horOffset * (0), selectedArt.position[1] + verOffset * (j + 1)];
      else {
        alert("You must have the object you want to duplicate selected.");
