Hello!
I have been using DW CS6 for many years, and on F12 always got the preview on the testing server (which also is the remote server).
I have now installed DW CC 2018, and there I get the preview on a local site http://127.0.0.1:65498/preview With the title "Device Preview".
I have checked the old (CS6) and new (CC) configurations, and cannot find the difference. The site definitions are exported from CS6 and imported into CC through XML *.ste - files.
I would very much like the preview to happen on the remote site.
Michael
The F12 shortcut was given to Live Preview in CC2017 and continues to be one of the inaccessible keyboard shortcuts in the preferences, so there's no way built into the program interface to change it back to the old Preview in Browser. That doesn't mean you can't change it though. If you have full admin access to your computer, you can make a tiny text change to one of DW's program files to permanently give F12 back to Preview in Browser.
To re-map the old Preview in Browser (Open in Browser) to
...Copy link to clipboard
To re-map the old Preview in Browser (Open in Browser) to F12 rather than Live Preview...
1. Close DW and go to...
Windows: C: > Program Files > Adobe > Adobe Dreamweaver CC 2017 > configuration > Menus > MM
Mac: Applications > Adobe Dreamweaver CC 2017 > configuration > Menus > MM
(I think, I don't have a Mac to test)
2. Open the file "PIB_Dynamic.js"
2a. As always, make a backup in case something goes sideways. Add _old at the end of the file name.
3. Search for the text "dw.browseDocument". There are 3 spots with that code, but the first two are just comments. The right one should be on or about line 433, and change the text "isPIB" to "true"
The finished line of code will look like...
dw.browseDocument(dw.getDocumentPath('document'),theBrowser, "-1"/*help argument*/, false /*use temp doc*/, true);
4. Save the file to your desktop
5. Drag the file into the original location from Step 1. You will be prompted for your Admin credentials in order to make the copy/replacement
did you try right click on the document TAB and then from the drop down menu choosing "open from browser > the browser of your choice"
This works! thanks, and together with Jon's answer I guess I get it the way I want!!
The reason I posted the above is because Live Preview uses Adobe's servers to show you your page, live as you make edits (usually). Because of that, you get the odd IP address in the location bar and links to other pages may or may not work.
Going back to using Preview in Browser instead of Live Preview will use your local file, on your local machine and give you either the file// or localhost (testing server) address just like the older versions of DW did.
the link that I gave link to the old preview, not the preview in a browser... so that way one get the real URL and not the DW generated one
Yep, and the instructions I posted above will turn...
"right click on the document TAB and then from the drop down menu choosing "open from browser > the browser of your choice"
...into...
Hit F12
Thanks Jon !
You just make my day !
I confirm this hack working here in DW CC 2018 (10136).
