6 Replies Latest reply on Nov 11, 2017 1:59 AM by sabahatu1546489
    Mutually exclusive
    sabahatu1546489 Level 1
      Hi there,
      I have been trying to mutually exclude two Activites. For that I followed this tutorial Profile Scripts in Adobe Target - YouTube
      All the steps were followed as described in the video but the profile script doesn't seem to work. It displays groupA and groupB in the audience list but when added to the Activity, it displays 0 visitors under reports.
      We have tried launching 2 Activities to 50% on with GoupA and other with GroupB as an audience but still doesn't work some times it displays the variation (which I ignore blaming my browser) and open incoginto to test again. The report tab always show zero visitors.
      Could you please tell what I missing apart from put the twoGroups code in the profile script and creating the audience of it?
      Could you also tell what is the "Not in other tests" Visitor Profile really do? Is it the same as Mutually exclusive?
        • 1. Re: Mutually exclusive
          ryanr8 Adobe Employee
          Can you share what your profile script looks like and the corresponding audience definition?
          For "not in other test" it is an out-of-the-box profile which just enables you to create an audience for anyone who isn't already in any other test you have live on your site. So if you ONLY have the 2 tests running that you want to be mutually exclusive it could work. You create 1 test and throttle the audience to 50% of all visitors. Then create a 2nd test with an audience "not in other test" and allow 100% of visitors in. That would acheive a mutually exclusive test - but it only works in the case when you only have 2 active tests.
          • 2. Re: Mutually exclusive
            HI ryanr8
            Please find the code below:  also please tell me whether it will consider the Background Activity set to 100% (for adding cookie) as a test to mutually exclude from?
            var random_number = Math.floor(Math.random()+99);
            if(random_number<=49){return "GroupA";}else{return "GroupB";}
            • 3. Re: Mutually exclusive
              That profile looks fine. You then need to create two audiences one for the GroupA response and one for the GroupB response. Your rule should be something like: visitor profile > twoGroups > contains: GroupA.
              Is that how your audiences are defined? Then I'd replace the "all visitors" audience with one of these for each activity.
              • 4. Re: Mutually exclusive
                ryanr8 Hi, I followed the exact same procedure. Please see the use case when it doesn't work
                First Activity: Homepage
                Audience: Homepage URL and Group B
                1 Snaggy - easy screenshots
                2 Snaggy - easy screenshots
                First tried 100% then reduce it to 5%
                Second Activity: About us
                Audience: ABout us Link and Group A
                1- Snaggy - easy screenshots
                2- Snaggy - easy screenshots
                Traffic 100%
                When I launched the Homepage activity to 100%, then I could only see the Homepage variation running but not About us.
                When I reduced the Homepage traffic to 5%, so the about us page will get rest of the traffic. but still about us Activity is not running
                • 5. Re: Mutually exclusive
                  Hi sabahatu1546489,
                  You shouldn't modify the throttle rates in this use case. Your groupA/groupB audiences already control that. Set both activities to 100% of traffic (i.e., eligible traffic). If you get into the home page activity your visitor should not be able to see the about us activity. Keep that in mind when you QA. You will need to delete cookies (or use a new browser or incognito window) to appear as a new visitor and then you'll have only a 50/50 chance to get into the About us activity. Consequently, it may take a few trys of deleting cookies to get in the activity. This is normal and expected in this situation.
                  • 6. Re: Mutually exclusive
                    Yes I totally get that. The thing is if we want to Mutually exclude two Activities on two "different" pages like Homepage and About us, In that case the throttle rate would be low on the main page (Homepage) so the next page (About us) would get some unique traffic. Without Mutually Exclusive script, the visitors who qualify for Homepage will also qualify for About us page Activity (provided that other audience criteria is same too, if there is any). Am I right in my thinking?
                    So with the use case, two Activities on two different pages:
                    If HP throttle is 5% and About us is 100%, with Mutually Exclusion, should I not expect to definitely see About us Activity if I don't fall under 5% of HP. If I do, I won't qualify for about us. correct?
                    - Not working. I don't fall under 5% of HP but still don't see About us activity either.
                    If I am right in my thinking, plesae let me know whats the way forward?
