5 Replies Latest reply on Nov 5, 2017 5:27 PM by jane-e
    Rotated pages won't crop
    devinp82654734
      I am trying to resize a complete document to make all pages the same size. To achieve this I am using the crop tool to change the pages to a custom size. Yet certain pages will not resize no matter what. It turns out these are pages composed primarily of image(s), which Acrobat tried to rotate to landscape after text-recognition. However, I've also tried resizing prior to text recognition, and after removing hidden information. No matter what these pages absolutely will not resize! Can anyone say why?
        • 1. Re: Rotated pages won't crop
          jane-e Adobe Community Professional
          Try using the crop tool on one of the pages again. Cropping is temporary, and you can get the original back by uncropping unless you have deleted hidden information.
          Is the original info still there or not?
          You can cancel the crop to not make any changes. You are just looking right now.
          • 2. Re: Rotated pages won't crop
            devinp82654734 Level 1
            It depends on which version of the document. In one version, before text-recognition, I have also tried multiple times to delete the hidden cropped information then resizing. The cropped info is checked and Acrobat says it will be removed when the document is saved, but that never happens. It won't go away until I run text-recognition. So I haven't found a way to attempt the resize on the non-text-recognized pages, though I did also try running "Protection--Remove Hidden Information" on a version of the document after text-recognition, so maybe I actually did. In short, neither removing hidden information or resizing seems to work like it is supposed to. Yesterday I finally did what I essentially sought to do by printing as a pdf under the highest quality settings. This removed the hidden info, resized everything, and then I ran text-recognition.
            • 3. Re: Rotated pages won't crop
              So is it solved now?
              • 4. Re: Rotated pages won't crop
                Yes, in a roundabout way.
                • 5. Re: Rotated pages won't crop
                  I think it was the hidden information with the crop. You might test it later if you have time or are so inclined.
                  But at least it's working now, yay!
