3 Replies Latest reply on Jan 8, 2009 7:46 AM by Newsgroup_User
    AdvancedDataGrid editable cells as objects
    willkanoff
      I use AdvancedDataGrid every cell of which is an instance of GridCell class.
      Function to display data:
      function dataGridCellLabelFunc(item : Object, col:AdvancedDataGridColumn) : String {
      if (item[col.dataField] is DateGridCell)
      return GridCell(item[col.dataField]).value;
      For editing itemEditor CellEditor (editorField = "cell"):
      public class CellEditor extends UIComponent
      implements IListItemRenderer, IDropInListItemRenderer, IFocusManagerComponent {
      private var _cellEditor:TextInput;
      public function get cell(): GridCell {
      var dgOwner: AdvancedDataGrid = owner as AdvancedDataGrid;
      var dgColumn:AdvancedDataGridColumn =
      dgOwner.columns[AdvancedDataGridListData(listData).columnIndex];
      var c: GridCell = GridCell(data[dgColumn.dataField]);
      if (c.value != Number(_cellEditor.text)) {
      c.value = Number(_cellEditor.text);
      // otherwise calculated cells do not work correctly
      dgOwner.dataProvider.itemUpdated(data, dgColumn.dataField, null, c);
      return c;
      It appears that the data change after editing takes almost a second (with 20 rows and 14 columns in the table).
      I found that commenting out the following line helps:
      //dgOwner.dataProvider.itemUpdated(data, dgColumn.dataField, null, c);
      but then calculated cells and dataProvider listeners do not work...
      Reducing rowCount down to 4 also eliminates the delay...
      Is there a way to use this approach in AdvancedDataGrid table without significant processing delay in the calculated cells?
      Thanks...
