11 Replies Latest reply on Nov 5, 2017 12:10 PM by D Fosse
    Camera raw - Revert to original raw file
    aleio Level 1
      Hi, I'm using camera raw with Photoshop CS6. I have edited some raw files and then saved the new images as jpeg. After that I just exit from camera raw without saving anything. If I reopen the raw file I can't see the original one but the edited one. Even if I re copy my files from my camera memory card and open them with camera raw I still see the edited ones. I've tryed this solution Revert to original photo in Camera Raw but it didn't work for me. Any suggestion? Thanks a lot
        • 1. Re: Camera raw - Revert to original raw file
          Chuck Uebele Adobe Community Professional & MVP
          Look in your computers file system manager either Explorer or Finder. Go to where your file is located. Is there an file with an XMP ending with the same name as your file? If so, delete it.
          • 2. Re: Camera raw - Revert to original raw file
            D Fosse Adobe Community Professional & MVP
            Press the Alt key, and the "Cancel"-button changes to "Reset". This resets the file to defaults.
            The procedure in the link is for setting new defaults. That's not what you want here.
            • 3. Re: Camera raw - Revert to original raw file
              aleio Level 1
              Thanks for your answers. I've already deleted all the .xmp files and the reset button unfortunately doesn't do anything once the file has been closed and reopened.
              • 4. Re: Camera raw - Revert to original raw file
                It just occurred to me that, by following the procedure in that link above, you have set new defaults based on your modified file. That's why resetting doesn't do anything.
                You need to undo that! Open a file, any file, and zero out all settings. Then open the menu and click on "Camera Raw Defaults". This time, you're creating a new default without any adjustments applied.
                IOW you applied a solution to a different problem than the one you had... and as a result got even more lost. So you have to retrace your steps and undo what you did.
                • 5. Re: Camera raw - Revert to original raw file
                  aleio Level 1
                  Thanks @D Fosse for your explanation. I understand what you mean, but I'm not sure this is the case because I've already all of my settings set to zero, except for the ones that are not set to zero by default. The values I've changed the first time I edited the file are not reflected in the settings values but I can see the effect of that editing in the image. (e.g. the first time I edited my raw file I set the exposure to +0,9, now if I open my file the exposure value is set to 0 but the photo looks like the exposure is set to +0,9). I forgot to mention that if I open the raw file with the standard windows image viewer I see the original unedited image. This makes me think that somewhere there must me some camera raw cached values that I can't delete. (not sure if it's relevant but if I've already deleted the content of AppData\Local\Adobe\CameraRaw\Cache)
                  • 6. Re: Camera raw - Revert to original raw file
                    Trevor.Dennis Adobe Community Professional (Moderator)
                    Another thought, are these RAW files DNG by any chance?   If so, then they store the edits within the file.  This is very much a long shot, and you have already mentioned deleting the sidecar files — DNG files do not need or have sidecar files, so that tends to rule out this being behind the issue.
                    Another thought, is there a camera profile set in ACR?
                    • 7. Re: Camera raw - Revert to original raw file
                      Jeff Arola Adobe Community Professional
                      You could try in Bridge CS6 highlighting a photo or photos and then go to Edit>Develop Settings>Clear Settings.
                      • 8. Re: Camera raw - Revert to original raw file
                        Doug.S Level 3
                        to start from scratch, import your original files from camera memory card to a new folder location (different than where you placed the first time or where you replaced them), then start with new ACR  default settings and follow info for reset etc.
                        Doug
                        • 9. Re: Camera raw - Revert to original raw file
                          aleio Level 1
                          Thanks Doug. I've tried this but I still see the edited image, even if I open the file from the memory card itself.
                          • 10. Re: Camera raw - Revert to original raw file
                            aleio Level 1
                            The files are CR2 and I have no camera profile set.
                            • 11. Re: Camera raw - Revert to original raw file
                              I'm beginning to suspect you're looking at the camera-processed jpeg, and excpect ACR to match this. It won't.
                              This camera-processed jpeg is also embedded in the raw file, and is what you see in other photo viewers.
                              It's important to understand that there is no such thing as an "original" when it comes to raw files. It has to be interpreted and processed to produce a useful image. A raw file in it native state is just a very dark, very compressed grayscale image.
                              Canon's processing algorithms (which produce the jpeg preview) are proprietary and not accessible to anyone else. But there is nothing more "correct" about Canon's interpretation of the data, than anyone else's interpretation. Adobe's defaults are by design conservative, intended to preserve as much of the original data as possible. The rest is up to you.
