3 Replies Latest reply on Nov 6, 2017 6:32 AM by alexanderb12300193
    After Effects and 1800€
    alexanderb12300193
      What do I need the PC for?
      I’m using After Effects, Premiere Pro and Photoshop very intensively. I started alone 2 years ago while studying and by now I put like 10-20 effects on one layer affecting color/distortion/shapes/compositing and my computer can’t afford enough performance to show anything fluently.
      My current system is this one:
      CPU: Intel Core i5-4570 4x 3.20 GHz
      RAM: 16 GB
      GPU: Nvidia Geforce GTX 760  2GB
      Hard Drive: 3TB Seagate 7200rpm
      I want to buy a new one with a budget of 1800€. My total budget is 2000€ but I would like to buy some Plug-ins from RedGiant or VideoCopilot with the rest of 200€ and take some first steps into them although my mainly used programs will be AE, PP and PS.
      It‘s the following computer system:
      CPU: Intel Core i7 7800x 6x3,5GHz (Boost 4GHz)
      Mainboard: ASUS Prime X299-A
      RAM: 2x16GB G.Skill Ripjaws V DDR4-2133
      GPU: MSI Geforce GTX1060 GamingX 6G
      HDD: 2 TB (Project files)
      SSD 1: 256 GB (OS/Programs)
      SSD 2: 256 GB (Cache)
      + some other stuff
      ____
      1500-1700€
      Do you have any suggestions?
      GPU: I do not know exactly if AE uses much of the GPU because I’ve read on the Adobe site that only 15 effects are supported with GPU rendering. Maybe I could swap it with a worse one and concentrate on more RAM?
      SSD: How to split for most efficient workflow? Many people say you need 3 SSDs:
      1. OS and Adobe programs
      2. Files
      3. Cache
      A cheaper solution may be to install OS+Programs  in SSD1, Cache on SSD 2 and Files+Stuff on a HDD?
      CPU: And another question concerning AMD and Intel: Is Intel (like i8xxx) the better choice for video editing? Many professional cutters and Vfx artists recommend Intel instead of AMD because it seems like they have better performance.
      Best regards!
        • 1. Re: After Effects and 1800€
          There's no better performance in a coreXi vs. e.g. a current Ryzen processor. The real issue is simply potential compatibility problems, which however always come down to "bad" drivers. That works both ways, though - you could just as well buy a crooked intel system. So in effect you won't know until you actually have the machine. More RAM doesn't fix much. Yes, AE's dumb preview system may gobble it up, but it won't improve performance otherwise. That is unless you work with huge 4k/ 8k footage or VR panoramas all the time. Other than that any slowdowns, and ultimately also AE's limited GPU usage come down to how the render pipeline works. It's always bound to budge at some point and revert back to CPU rendering. Still, why should that be any reason to not get a decent card? Premiere Pro at least does use it reasonably well within the limitations of editing vs. compositing. And that's the whole point: You will never see perfectly fluid performance in AE due to how it works and what it is supposed to do. It's a completely different thing than Premiere. The rest can be seen either way. I still maintain that using SSDs for caches etc. doesn't necessarily make sense for certain workflows unless you really spend big and get robust, optimized highspeed SSDs. For AE it doesn't make much sense, anyway. Based on your description, rendering teh effects will always take longer than the file I/O, so what would be the point? Those previews won't render faster even with a spanky M2 PCI SSD...
          Mylenium
          • 2. Re: After Effects and 1800€
            alexanderb12300193 Level 1
            Thanks for your answer!
            I think one important point to boost my system is to split up the OS/programs and the project files/cache. In order to my old CPU the new generation will lift the workflow a little bit. I understand that this system is by far not as good as a workstation from HP. I'm asking for the little differences between different CPUs/SSDs.
            • 3. Re: After Effects and 1800€
              Hey, here is an update:
              Mainboard: Intel Z370
              CPU: Intel Core i7 8700K 6x 3.70GHz
              RAM: 32GB DDR4 2400
              GPU: GeForce GTX 1060 6GB (maybe1070ti)
              SSD: 2x 250GB Samsung 960 Evo M.2 2280
              HDD: 2TB Seagate Barracuda
              + others
              What do you think about this?
