1 Reply Latest reply on Jul 27, 2006 5:23 AM by BobMelnyk
    Simple (?) Motion Tween Problem
    saringei
      I am unable to do more than one transition for a fade-in/fade-out effect. I'm trying to do a simple transition of 5 different bitmap images, with each fading out, followed by another fading in, etc... I've tried saving the bitmaps as symbols in the library. Still no luck.
      Any suggestions would be much appreciated.
        • 1. Re: Simple (?) Motion Tween Problem
          BobMelnyk
          Saringei,
          I'm sure there is a better way to do this (maybe with actionscript), but you can acheieve this effect by putting each fade in/fade out in a separate layer. for example, have image1 fade in and out in layer 1 going from frame 1 to frame 10, then image2 goes in layer 2 from frame 11 to frame 20, etc. Like I said, there is probably a better way that maybe someone else can suggest, but I'm pretty sure this will work.
          Bob
