Hi I have make one site with DW one years ago. Now I have open the template for create a new file but the system response is <<" There is an error at line 307 column 8 (absolute position 17264) of F:template.dwt" : unexpected end of file.>> At the line 307 is only last tag </html>. I have controlled the file with BlockNote, but dont I see error. Who can help me?
HTML comments look like this.
<!--VALID COMMENT-->
Try running the Template through code validation. The code errors are likely above line 307.
the result is :
The document is not mappable to XML 1.0 due to two consecutive hyphens in a comment. [html5]] ( the comments)
Saw <!-- within a comment. Probable cause: Nested comment (not allowed). [html5] another comment
The navigation role is unnecessary for element nav . [html5] ? <nav class="navbar navbar-default navbar-static-top tm_navbar clearfix" role="navigation">
Article lacks heading. Consider using h2 - h6 elements to add identifying headings to all articles. [html5]] ? <article class="slider">
OK !
Thanks Nancy, for your help! Now works.
