1 Reply Latest reply on Nov 6, 2017 11:32 AM by ClayUUID
    Multiple property inspector windows
    johnFlashStuffs Level 1
      Hi all.  I have a few different symbols with alpha settings activated in the property inspector window. These symbols are overlapped to adjust the darkness/lightness of the image.  I'd like to view a property inspector window for each symbol (so roughly 4 windows open) at the same time to more easily adjust the alpha slider for each symbol, instead of needing to click into each symbol separately, adjust and then click into the next symbol, adjust and then click into the next symbol, adjust etc...
      Is there a setting or script which can accomplish this? Thanks.
        • 1. Re: Multiple property inspector windows
          ClayUUID Adobe Community Professional
          First, stacking multiple alpha layers is terrible for real-time performance, so whatever it is you're doing, you probably shouldn't be doing it.
          Second, no. The closest thing I can think of offhand is to right-click each symbol on the stage and select Edit in New Window. That will at least save you from having to bounce back and forth in the symbol hierarchy.
