2 Replies Latest reply on Nov 8, 2017 8:52 PM by Warren Heaton
    Wrong time code in HEVC encodes
    bill_stephan
      I am attempting to encode a UHD-29.97P HEVC file with .mp4 wrapper. Source is a UHD-29.97P Quicktime ProRes422HQ file. Time code in the first frame of the source file is 00;59;59;29, and that time code needs to carry across to the target HEVC file. Regardless of whether I check or uncheck the Set Start Timecode box, the target HEVC file has NDF time code that starts at 00:00:00:00. This is causing our encodes to be rejected by the customer. How do I get AME to pass the correct time code from the source to the target file?
      I have a sample HEVC encode supplied by the customer that has the correct time code embedded in the file, so this is possible.
      Thank you.
        • 1. Re: Wrong time code in HEVC encodes
          Warren Heaton Adobe Community Professional
          Are you coming from Premiere Pro or adding the QuickTime file to AME directly?
          Try creating a new Sequence from the ProRes QuickTime file in Premiere Pro and manually set the Sequence Start Time to match the source clip start time.  Then send that to Media Encoder using the HVEC Format and Preset.  The Timecode from the Sequence should pass to the exported MP4.
          • 2. Re: Wrong time code in HEVC encodes
            Quick update:
            I just tried adding a ProRes QuickTime directly to AME and exported it to HEVC (H.265) Match Source - High Bitrate and the timecode in the resulting MP4 file matches the original MOV (00;59;59;29 in the MOV and 00;59;59;29 in the MP4).  I am using AME 2017.1.2 Release Build 11.1.2.35 under macOS 10.12.6.
