5 Replies Latest reply on May 22, 2008 11:33 PM by smscentral
    error loading module using ModuleManager
    smscentral
      Hi all,
      I load a module using ModuleManager.getModule(modname) in a flex application.
      module is loaded successfully.
      and when i try to click the links in the module,it connects to HTTPService and gets the data successfully but before showing data i get the following error:
      #1009: Cannot access a property or method of a null object reference.
      i try to debug and i see this in debug mode
      TypeError: Error #1009: Cannot access a property or method of a null object reference.
      at mx.rpc::AbstractInvoker$cinit()
      at global$init()
      at global$init()
      at mitto.core::MittoBackendRequest()
      at mitto.core::MittoBackendRequest$/CreateBackendRequest()
      at component.MXML::ListUsersComponent/entitiesList()
      at UserModule/linkToListUsers()
      at UserModule/__listUsers_click()
      what is this at mx.rpc::AbstractInvoker$cinit()
      at global$init()
      at global$init() ??/
      when i click continue when the error pops up, i get back to the list with my data in datagrid.
      Any suggestion would be helpful.
        • 1. Re: error loading module using ModuleManager
          atta707 Level 2
          can you show some working code that shows the problem?
          • 2. Re: error loading module using ModuleManager
            smscentral Level 1
            thanks for ur time.
            i am loading the module using module manager
            public function loadModule(filePath:String):void {
            mittoAppInstance = MittoApp.getInstance();
            moduleInfo = ModuleManager.getModule(filePath);
            moduleInfo.addEventListener(ModuleEvent.READY, modReadyEventHandler);
            moduleInfo.addEventListener(ModuleEvent.PROGRESS,modProgressEventHandler);
            moduleInfo.addEventListener(ModuleEvent.ERROR, modErrorEventHandler);
            moduleInfo.load();
            MittoApp.getInstance().progressbar.visible = true;
            //get the instance of module , call method on that object, add it to the main application
            private function modReadyEventHandler(e:ModuleEvent):void {
            moduleInstance = this.getModuleInstance();
            this.addToApplication();
            //get the instance of the module
            public function getModuleInstance():Object{
            return moduleInfo.factory.create() as Object;
            //add module to mitto application
            public function addToApplication():void{
            mittoAppInstance.main.addChild(moduleInstance as DisplayObject);
            and my module has some links
            <mx:ControlBar>
            <mx:LinkButton id="addUser" label="Add User" click="linkToAddUser();"/>
            <mx:LinkButton id="listUsers" label="List Users" click="linkToListUsers();"/>
            <mx:LinkButton id="editpermissions" label="Edit Permission" click="selectUser()"/>
            </mx:ControlBar>
            public function linkToListUsers():void{
            listUsersInstance = new ListUsersComponent()
            listUsersInstance.list_url="usermanagement";
            listUsersInstance.action="listusers";
            listUsersInstance.entitiesList();
            this.remove();
            usermain.addChild(listUsersInstance);
            and as i click on list users..i get the exception 1009.
            • 3. Re: error loading module using ModuleManager
              atta707 Level 2
              So far so good! The exception source is actually going beyond this code: in the MittoBackendRequest.CreateBackendRequest() method.
              have tried to debug this method?
              • 4. error loading module using ModuleManager
                smscentral Level 1
                thanks
                renderer code attached
                • 5. Re: error loading module using ModuleManager
                  smscentral Level 1
                  hi...
                  i try to debug that mittobackendrequest but as and when i click my link..it shows up the error..
                  at global$init()
                  at global$init()
                  mittobackend request class :
