• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
I'm having trouble setting height between lines of text "Photoshop 2018"
New Here ,
Nov 07, 2017 Nov 07, 2017
I did the update of photoshop and then started with this problem when setting height between lines of text, when I try to add or increase it just does not go or gets uncontrolled the parameters that I try to change and I can not change. If you can help me thank you very much!
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to specific Program forum... Mod]
Views
176
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Nov 07, 2017 Nov 07, 2017
There is a bug in the leading value entry which Adobe have acknowledged and are working on a fix.
In the meantime there is a workaround :
a. Enter the leading value in the Properties panel.
b. When you hit enter the value in the properties panel box will change to something different (that is a bug) but will now show correctly in the Character panel
c. The value applied to the text will be the same as you entered and now shown in the character panel
Note : The workaround does not work backwards - you
Votes
Translate
Translate
Adobe
Community Expert ,
Note : The workaround does not work backwards - you must enter in the properties box.
Dave
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thanks for the help, I was able to do what I needed using the same function in the Properties panel, I used to use the Character panel.
Votes
Translate
Translate
Report
Report
