3 Replies Latest reply on Nov 7, 2017 11:24 AM by christophecuny
    Paint back pixels from one layer to another?
    christophecuny Level 1
      Hello everyone. I have looked at some forum posts and tried to do this with the clone stamp tool but failed miserably so far.
      I am cutting out an illustration from its background. It's messy and I have used a range of tools, from the eraser to masking via quick selections. Some of my edits have eaten into the illustration itself and since I used some destructive edits, I can't just play with a mask. Since I have the original layer available, I wondered how I would go about painting back some of the pixels erased in error, sampling from the original illustration layer.
      Would someone please give me some pointers?
      Thank you
      Chris
      Using PS CC 2015 on Windows 10 x64
        • 1. Re: Paint back pixels from one layer to another?
          davescm Adobe Community Professional
          To paint from one layer to another using the clone tool do the following ;
          1. Set the clone tool to aligned and current layer
          2. In the layers panel click on the layer you want to sample from
          3. Set your brush size and Alt click anywhere on the image
          4. In the layers panel switch to the layer you want to clone to
          5. In the clone source panel type 0 into both the x offset and y offset boxes (do this even if they say "0" already)
          6. Brush onto image - the brush will be aligned to the layer below
          An alternative method is to paint with the history brush.
          1. Set your original image as the source in the history panel
          2. Paint onto the new layer in the image with the history brush tool
          Dave
          • 2. Re: Paint back pixels from one layer to another?
            D Fosse Adobe Community Professional & MVP
            If you have the (imperfect) cut-out on a separate layer, above the full image, I'd just use that to make a mask, and go from there.
            • Duplicate the base layer.
            • Ctrl-click the cutout layer to load it as a selection.
            • Target the duplicate layer, and click the layer mask icon. This automatically loads an active selection as a layer mask.
            • Delete the cutout layer, you don't need it anymore. Now you can just work on the mask, and paint back if you overdo.
            • 3. Re: Paint back pixels from one layer to another?
              Thank you both. I don't know how to set two answers as correct, but let me know idf there is a way. Great methods. I really appreciate the help.
              Best.
              Chris
