• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Delete textFrame associated with variable
Engaged ,
Nov 07, 2017 Nov 07, 2017
I am wanting to scan through all open documents and look for a dynamic textFrame variable called   coverPageVolume
When the script finds the textFrame associated with this variable.... I would like it to remove the textFrame.
I can get it to change the contents...but any time I try to get it to remove the textFrame it locks my illustrator up.
What am I doing wrong here?
for (var i = 0; i < documents.length; i++) {
    var currentActiveDoc = app.documents;
    app.activeDocument = currentActiveDoc;
    var theDocVariables = currentActiveDoc.variables
    for (z = 0; z < theDocVariables.length; z++) {
        if (theDocVariables.name == "coverPageVolume") {
            theDocVariables.pageItems[0].remove();
TOPICS
Scripting
Views
498
Translate
Translate
Report
Report
Community guidelines
community guidelines
Valorous Hero , Nov 08, 2017 Nov 08, 2017
Aha, indeed this is what happens to me too. It looks like remove() on all of the items will lock it up like you say.
But, we can do this workaround to select all the items and then run a delete command:
#target illustrator
function test(){
  var doc = app.activeDocument;
  doc.selection = null;
  for(var i=0; i<doc.variables.length; i++){
    if(doc.variables.name == "Variable3"){
      for(var j=0; j<doc.variables.pageItems.length; j++){
        doc.variables.pageItems.selected = true;
Votes
Translate
Translate
Adobe
Valorous Hero ,
Use another for loop:
for(var j=theDocVariables.pageItems.length - 1; j > -1; j--){
     theDocVariables.pageItems.remove();
Votes
Translate
Translate
Report
Report
Engaged ,
Thank you for the input Silly-V !  When I try to run that script it still locks up my illustrator. I believe the issue is I have to delete the variable before I can delete the textFrame? Because when I run the following script it works....it is just slow.
            // Make the textFrame blank
            theDocVariables.pageItems[0].contents = "";
            // Delete the associated variable
            theDocVariables.remove();
    var allText = currentActiveDoc.textFrames;
    var straypoints = [];
    // Check text frame length - Path Cleanup
    for (j = 0; j < allText.length; j++) {
        var itext = allText;
        if (itext.textRange.length == 0)
            straypoints.push(itext);
    // Remove stray items - Path Cleanup
    for (k = 0; k < straypoints.length; k++) {
        straypoints.remove();
        //alert(straypoints.length + " stray points removed");
Any other methods you can think of that would allow me to delete the variable and textFrame?
Votes
Translate
Translate
Report
Report
Valorous Hero ,
#target illustrator
function test(){
  app.executeMenuCommand("clear");
test();
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
this is EXACTLY what I was trying to accomplish! Thank you Silly-V
Votes
Translate
Translate
Report
Report
