4 Replies Latest reply on May 21, 2008 7:55 AM by Newsgroup_User
    copy paste
    Level 7
      is there a way to copy somthing at _level0 and paste it on the same
      position inside another clip with different coordinates? I know I can do
      this on one level but this would be so great if it would work inside
      different coordinates.
      TIA
        • 1. copy paste
          Yes. It's possible I'm not reading the situation correctly, but if I am, it may be as simple as using the Paste in Place option.
          If that doesn't result as you hoped, what you may need to do is write down the x/y coordinates in the level your copying from, and after pasting the object into its new home you'd have to manually enter those same coordinates in the properties panel.
          • 2. Re: copy paste
            Level 7
            NedWebs wrote:
            > Yes, what have you tried that doesn't work... it's possible I'm not reading the situation correctly.
            Take a clip from the main timeline (_level0) ctrl+c
            go inside another clip, in the middle of the stage
            and press ctrl+shift+v
            The copied clip have the same offset as in _leven0 plus the position of
            the clip where the paste-timeline lies. I want flash to automaticly
            calculate that difference. I guess it is not possible but maybe...
            • 3. Re: copy paste
              FSL_DiGi Level 1
              ya its possible, did it before!
              • 4. Re: copy paste
                Level 7
                how?
                ctrl+v places it in the middle
                ctrl+shift+v puts it on the same coordinates, whisout shifting the
                position from the parent clip.
                but how correct this automaticly?
