3 Replies Latest reply on Jan 6, 2009 10:46 AM by W_Bell
    Component ScrollBar rollover
    W_Bell Level 1
      I have a scroll bar button for a video component that looks the same as the UIScroll except it has no mouseover or press events coded and I have been trying variations of code to no avail.
      The scrollBar comes as part of a "List component" for use with a video player. The component inspector only gives you links for the scroll, track & arrow buttons.
      I am trying to add the mouse over effects and I am having a problem getting the code to talk to the buttons.
        • 1. Re: Component ScrollBar rollover
          this.ScBar1.onRollOver = function(){
          this.gotoAndStop(2);
          etc...
          • 2. Re: Component ScrollBar rollover
            W_Bell Level 1
            Your suggestion will not fire the frame and I have tried every combination I think possible and still, I can not get the Scroll to move with the mouseover. However, I got the Mouseover by omitting the instance name and just using
            //***********************************************************List5 ScrollBar
            this.onRollOver = function(){
            I think there must be a problem with focus or something that causes the scrollbar not to work when the mouseover works. Maybe if I add the drag command or whatever it is, the scroll may work with the mouseover.
            Any suggestions?
            • 3. Re: Component ScrollBar rollover
              W_Bell Level 1
              Well I made a buttons for the UIScrollBar arrows from the 3 states in the ScrollBar Library and they work fine.
              This won't work for the scroll Button as it will not scroll if you use a Button instance.
              What I am tring to achieve in this thread is a button state highlight without using a style like Halo Blue.
