3 Replies Latest reply on Nov 8, 2017 12:06 PM by ChristopherBellach
    How do add a B&W image to a layer mask using Photoshop JS Script?
    ChristopherBellach
      I am trying to generate a Photoshop script that automatically crops a black and white image. Then I want to take that cropped image and put it into a layer mask. The goal is to generate an opacity mask I can us in my application.
      I have code to crop the image and I have found code to add a layer mask (though I don't quite understand what the code is doing). But I am failing to find code to edit the layer mask.
      Here are the steps in the Photoshop UI I am trying to replicate
      1. Crop image to desired dimensions
      2. Copy the cropped image
      3. Start a new document without a background layer
      4. Add layer mask to the only layer
      5. Alt-Click the layer mask to edit it
      6. Paste the copy from step 2 into the layer mask
      7. Export as PNG
      Any help would be greatly appreciated. Here is the code I have so far
      var dir = new Folder('Some Directory')
      var files = dir.getFiles("*.psd");
      for (var i = 0; i < files.length; i++) {
         var doc = app.open(files[i]);
        doc.flatten();
         var bounds = [96, 155, 722, 613];
        doc.crop(bounds);
        doc.selection.selectAll();
        doc.selection.copy();
         var blankLayer = doc.artLayers.add();
        doc.activeLayer = blankLayer;
        newColor = new SolidColor;
        newColor.rgb.red = 255;
        newColor.rgb.green = 255;
        newColor.rgb.blue = 255;
        doc.selection.fill(newColor);
        doc.selection.deselect();
        makeMask();
         //Open Layer Mask for Edit
        doc.paste();
        savePng(doc);
        doc.close(SaveOptions.DONOTSAVECHANGES);
      function savePng(doc) {
         var file = new File(doc.path + '/' + doc.name + '.png')
         var opts = new PNGSaveOptions();
        doc.saveAs(file, opts, true);
      // FUNCTION MAKE MASK ()
      function makeMask()
        var id4556 = charIDToTypeID( "setd" );
        var desc983 = new ActionDescriptor();
        var id4557 = charIDToTypeID( "null" );
        var ref657 = new ActionReference();
        var id4558 = charIDToTypeID( "Chnl" );
        var id4559 = charIDToTypeID( "fsel" );
        ref657.putProperty( id4558, id4559 );
        desc983.putReference( id4557, ref657 );
        var id4560 = charIDToTypeID( "T " );
        var ref658 = new ActionReference();
        var id4561 = charIDToTypeID( "Chnl" );
        var id4562 = charIDToTypeID( "Chnl" );
        var id4563 = charIDToTypeID( "Trsp" );
        ref658.putEnumerated( id4561, id4562, id4563 );
        desc983.putReference( id4560, ref658 );
        executeAction( id4556, desc983, DialogModes.NO );
        var id4564 = charIDToTypeID( "Mk " );
        var desc984 = new ActionDescriptor();
        var id4565 = charIDToTypeID( "Nw " );
        var id4566 = charIDToTypeID( "Chnl" );
        desc984.putClass( id4565, id4566 );
        var id4567 = charIDToTypeID( "At " );
        var ref659 = new ActionReference();
        var id4568 = charIDToTypeID( "Chnl" );
        var id4569 = charIDToTypeID( "Chnl" );
        var id4570 = charIDToTypeID( "Msk " );
        ref659.putEnumerated( id4568, id4569, id4570 );
        desc984.putReference( id4567, ref659 );
        var id4571 = charIDToTypeID( "Usng" );
        var id4572 = charIDToTypeID( "UsrM" );
        var id4573 = charIDToTypeID( "RvlS" );
        desc984.putEnumerated( id4571, id4572, id4573 );
        executeAction( id4564, desc984, DialogModes.NO );
      // FUNCTION APPLY LAYER MASK()
      function applyLayerMask()
        var id1949 = charIDToTypeID( "Dlt " );
        var desc398 = new ActionDescriptor();
        var id1950 = charIDToTypeID( "null" );
        var ref291 = new ActionReference();
        var id1951 = charIDToTypeID( "Chnl" );
        var id1952 = charIDToTypeID( "Chnl" );
        var id1953 = charIDToTypeID( "Msk " );
        ref291.putEnumerated( id1951, id1952, id1953 );
        desc398.putReference( id1950, ref291 );
        var id1954 = charIDToTypeID( "Aply" );
        desc398.putBoolean( id1954, true );
        executeAction( id1949, desc398, DialogModes.NO );
        • 1. Re: How do add a B&W image to a layer mask using Photoshop JS Script?
          You are making things harder then need be. You can automate a centered crop to a specific aspect ratio. Cropping though is normally an interactive process where you choose the composition you want.  A simple action can do the rest of your automation. The simplest way  is to record an action. Add  a new empty layer Shift+Ctrl+Alt+N.  Stamp the visible layers into to the new empty layer Shift+Alt+Ctrl+E. The move that layer to to top of the layer stack  Shift+Ctrl+] the step may need to be inserted or forced to record. Load the Luminosity Channel as a selection Alt+Ctrl+2.  Add the selection as a layer mask click the add layer mask icon in the layers palette on menu layer>Layer Mask>Reveal Selection. You could also record these steps with the Scriprlistener Plug-in as a Photoshop script.
          • 2. Re: How do add a B&W image to a layer mask using Photoshop JS Script?
            ChristopherBellach Level 1
            Thanks for the response.
            The cropping isn't the part I am trying to answer. The scenario I am trying to solve for is I have a folder with hundreds of psd files that are laid out in a similar way except for the area I have selected to crop. So I want to cut out that part and put it into a layer mask. The image above is what I am trying to accomplish.
            The cropping code in the example is exactly what I need and works fine. The problem I am having is I need to find a way to script adding the cropped image to the layer mask.
            Admittedly, I may be attacking this the wrong way. Essentially what I want to accomplish is and opacity mask from the gray scale images where white is opaque and black is transparent. Photoshop accomplishes this when I paste the gray scale image image into the layer mask. But if there is another way to accomplish this through a script where I can process hundred of files, I would be glad to learn how.
            • 3. Re: How do add a B&W image to a layer mask using Photoshop JS Script?
              I believe the ScriptingListener plug-in is what I needed. Thanks
