0 Replies Latest reply on Nov 7, 2017 12:36 PM by otownb
    Acrobat XI crashing when combining multiple word files
    otownb Level 1
      I have a single user that when she opens acrobat 11 and does combine files into pdf and chooses several word documents and hits combine the app crashes resulting in the below event logs. We have VDI so the program is reinstalled when the user logs in and out and this does not correct the issue and it seems to be isolated to her. Possibly something corrupted in her profile or settings.
      Faulting application name: Acrobat.exe, version: 11.0.14.16, time stamp: 0x56731fe8
      Faulting module name: PDFMakerAPI.dll, version: 11.0.14.16, time stamp: 0x56730e2a
      Exception code: 0xc0000005
      Fault offset: 0x0001ca89
      Faulting process id: 0x1dec
      Faulting application start time: 0x01d357fca54cc0f2
      Faulting application path: C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe
      Faulting module path: C:\Program Files (x86)\Adobe\Acrobat 11.0\PDFMaker\Common\PDFMakerAPI.dll
      Report Id: eb867036-c3ef-11e7-b8cd-0050568ffd0b
      Fault bucket , type 0
      Event Name: APPCRASH
      Response: Not available
      Cab Id: 0
      Problem signature:
      P1: Acrobat.exe
      P2: 11.0.14.16
      P3: 56731fe8
      P4: PDFMakerAPI.dll
      P5: 11.0.14.16
      P6: 56730e2a
      P7: c0000005
      P8: 0001ca89
      P9:
      P10:
      These files may be available here:
      C:\Users\AppData\Local\Microsoft\Windows\WER\ReportArchive\AppCrash_Acrobat.exe_72e27325b6 b8dcff3f82e753e1aef0d1937c7dec_1a531d7f
      Analysis symbol:
      Rechecking for solution: 0
      Report Id: d4522c2f-c3ef-11e7-b8cd-0050568ffd0b
      Report Status: 0
      The crash report from Adobe is as follows
      Version=1
      EventType=APPCRASH
      EventTime=131545556497920566
      ReportType=2
      Consent=1
      ReportIdentifier=d4522c30-c3ef-11e7-b8cd-0050568ffd0b
      IntegratorReportIdentifier=d4522c2f-c3ef-11e7-b8cd-0050568ffd0b
      WOW64=1
      Response.type=4
      Sig[0].Name=Application Name
      Sig[0].Value=Acrobat.exe
      Sig[1].Name=Application Version
      Sig[1].Value=11.0.14.16
      Sig[2].Name=Application Timestamp
      Sig[2].Value=56731fe8
      Sig[3].Name=Fault Module Name
      Sig[3].Value=PDFMakerAPI.dll
      Sig[4].Name=Fault Module Version
      Sig[4].Value=11.0.14.16
      Sig[5].Name=Fault Module Timestamp
      Sig[5].Value=56730e2a
      Sig[6].Name=Exception Code
      Sig[6].Value=c0000005
      Sig[7].Name=Exception Offset
      Sig[7].Value=0001ca89
      DynamicSig[1].Name=OS Version
      DynamicSig[1].Value=6.1.7601.2.1.0.256.4
      DynamicSig[2].Name=Locale ID
      DynamicSig[2].Value=1033
      DynamicSig[22].Name=Additional Information 1
      DynamicSig[22].Value=0a9e
      DynamicSig[23].Name=Additional Information 2
      DynamicSig[23].Value=0a9e372d3b4ad19135b953a78882e789
      DynamicSig[24].Name=Additional Information 3
      DynamicSig[24].Value=0a9e
      DynamicSig[25].Name=Additional Information 4
      DynamicSig[25].Value=0a9e372d3b4ad19135b953a78882e789
      UI[2]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe
      UI[3]=Adobe Acrobat has stopped working
      UI[4]=Windows can check online for a solution to the problem.
      UI[5]=Check online for a solution and close the program
      UI[6]=Check online for a solution later and close the program
      UI[7]=Close the program
      LoadedModule[0]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe
      LoadedModule[1]=C:\Windows\SysWOW64\ntdll.dll
      LoadedModule[2]=C:\Windows\syswow64\kernel32.dll
      LoadedModule[3]=C:\Windows\syswow64\KERNELBASE.dll
      LoadedModule[4]=C:\Windows\syswow64\USER32.dll
      LoadedModule[5]=C:\Windows\syswow64\GDI32.dll
      LoadedModule[6]=C:\Windows\syswow64\LPK.dll
      LoadedModule[7]=C:\Windows\syswow64\USP10.dll
      LoadedModule[8]=C:\Windows\syswow64\msvcrt.dll
      LoadedModule[9]=C:\Windows\syswow64\ADVAPI32.dll
      LoadedModule[10]=C:\Windows\SysWOW64\sechost.dll
      LoadedModule[11]=C:\Windows\syswow64\RPCRT4.dll
      LoadedModule[12]=C:\Windows\syswow64\SspiCli.dll
      LoadedModule[13]=C:\Windows\syswow64\CRYPTBASE.dll
      LoadedModule[14]=C:\Windows\system32\MSVCR100.dll
      LoadedModule[15]=C:\Windows\system32\MSVCP100.dll
      LoadedModule[16]=C:\Windows\system32\IMM32.DLL
      LoadedModule[17]=C:\Windows\syswow64\MSCTF.dll
      LoadedModule[18]=C:\Windows\system32\vmwsci.dll
      LoadedModule[19]=C:\Windows\system32\ftapihook32.dll
      LoadedModule[20]=C:\Windows\SysWOW64\ftsti.dll
      LoadedModule[21]=C:\Windows\syswow64\ole32.dll
      LoadedModule[22]=C:\Windows\syswow64\OLEAUT32.dll
      LoadedModule[23]=C:\Windows\syswow64\SHLWAPI.dll
      LoadedModule[24]=C:\Windows\system32\PROPSYS.dll
      LoadedModule[25]=C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_ 6.0.7601.18837_none_41e855142bd5705d\Comctl32.dll
      LoadedModule[26]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.dll
      LoadedModule[27]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\AGM.dll
      LoadedModule[28]=C:\Windows\system32\VERSION.dll
      LoadedModule[29]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\CoolType.dll
      LoadedModule[30]=C:\Windows\syswow64\SHELL32.dll
      LoadedModule[31]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\BIB.dll
      LoadedModule[32]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\ACE.dll
      LoadedModule[33]=C:\Windows\system32\UxTheme.dll
      LoadedModule[34]=C:\Windows\syswow64\profapi.dll
      LoadedModule[35]=C:\Windows\system32\ntmarta.dll
      LoadedModule[36]=C:\Windows\syswow64\WLDAP32.dll
      LoadedModule[37]=C:\Windows\system32\CRYPTSP.dll
      LoadedModule[38]=C:\Windows\system32\rsaenh.dll
      LoadedModule[39]=C:\Windows\system32\RpcRtRemote.dll
      LoadedModule[40]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\sqlite.dll
      LoadedModule[41]=C:\Windows\syswow64\CRYPT32.dll
      LoadedModule[42]=C:\Windows\syswow64\MSASN1.dll
      LoadedModule[43]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\AXE8SharedExpat.dll
      LoadedModule[44]=C:\Windows\system32\MPR.dll
      LoadedModule[45]=C:\Windows\System32\drprov.dll
      LoadedModule[46]=C:\Windows\System32\WINSTA.dll
      LoadedModule[47]=C:\Windows\System32\ntlanman.dll
      LoadedModule[48]=C:\Windows\System32\davclnt.dll
      LoadedModule[49]=C:\Windows\System32\DAVHLPR.dll
      LoadedModule[50]=C:\Windows\system32\wkscli.dll
      LoadedModule[51]=C:\Windows\system32\cscapi.dll
      LoadedModule[52]=C:\Windows\system32\netutils.dll
      LoadedModule[53]=C:\Windows\syswow64\CLBCatQ.DLL
      LoadedModule[54]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\Annots.api
      LoadedModule[55]=C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601 .23894_none_5c0be957a009922e\gdiplus.dll
      LoadedModule[56]=C:\Windows\system32\msi.dll
      LoadedModule[57]=C:\Windows\syswow64\SETUPAPI.dll
      LoadedModule[58]=C:\Windows\syswow64\CFGMGR32.dll
      LoadedModule[59]=C:\Windows\syswow64\DEVOBJ.dll
      LoadedModule[60]=C:\Windows\system32\apphelp.dll
      LoadedModule[61]=C:\Windows\system32\NetworkExplorer.dll
      LoadedModule[62]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\cryptocme.dll
      LoadedModule[63]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\ccme_base.dll
      LoadedModule[64]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\ccme_base_non_fips.dll
      LoadedModule[65]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\ccme_asym.dll
      LoadedModule[66]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\ccme_ecc.dll
      LoadedModule[67]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\ccme_ecdrbg.dll
      LoadedModule[68]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\ccme_ecc_accel_fips.dll
      LoadedModule[69]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\Accessibility.api
      LoadedModule[70]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\AcroForm.api
      LoadedModule[71]=C:\Windows\system32\SensApi.dll
      LoadedModule[72]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\AXSLE.dll
      LoadedModule[73]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\DigSig.api
      LoadedModule[74]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\EScript.api
      LoadedModule[75]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\HTML2PDF.api
      LoadedModule[76]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\pdfsettings.dll
      LoadedModule[77]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\Multimedia.api
      LoadedModule[78]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\PPKLite.api
      LoadedModule[79]=C:\Windows\system32\WSOCK32.dll
      LoadedModule[80]=C:\Windows\syswow64\WS2_32.dll
      LoadedModule[81]=C:\Windows\syswow64\NSI.dll
      LoadedModule[82]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\ReadOutLoud.api
      LoadedModule[83]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\Search.api
      LoadedModule[84]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\SendMail.api
      LoadedModule[85]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\Spelling.api
      LoadedModule[86]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\TouchUp.api
      LoadedModule[87]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\Updater.api
      LoadedModule[88]=C:\Windows\syswow64\PSAPI.DLL
      LoadedModule[89]=C:\Windows\syswow64\USERENV.dll
      LoadedModule[90]=C:\Windows\SysWOW64\oleacc.dll
      LoadedModule[91]=C:\Windows\system32\Msftedit.dll
      LoadedModule[92]=C:\Windows\system32\ddraw.dll
      LoadedModule[93]=C:\Windows\system32\DCIMAN32.dll
      LoadedModule[94]=C:\Windows\system32\dwmapi.dll
      LoadedModule[95]=C:\Windows\system32\D3D9.DLL
      LoadedModule[96]=C:\Windows\system32\d3d8thk.dll
      LoadedModule[97]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\AdobeLinguistic.dll
      LoadedModule[98]=C:\Program Files (x86)\Common Files\Adobe\Acrobat\11.0\Linguistics\Providers\Plugins2\AdobeHunspellPlugin\AdobeHunspell Plugin.dll
      LoadedModule[99]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\IA32.api
      LoadedModule[100]=C:\Windows\syswow64\WININET.dll
      LoadedModule[101]=C:\Windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
      LoadedModule[102]=C:\Windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
      LoadedModule[103]=C:\Windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
      LoadedModule[104]=C:\Windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
      LoadedModule[105]=C:\Windows\syswow64\normaliz.DLL
      LoadedModule[106]=C:\Windows\syswow64\iertutil.dll
      LoadedModule[107]=C:\Windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
      LoadedModule[108]=C:\Windows\system32\Secur32.dll
      LoadedModule[109]=C:\Windows\system32\api-ms-win-downlevel-advapi32-l2-1-0.dll
      LoadedModule[110]=C:\Windows\syswow64\api-ms-win-downlevel-ole32-l1-1-0.dll
      LoadedModule[111]=C:\Windows\system32\mswsock.dll
      LoadedModule[112]=C:\Windows\System32\wship6.dll
      LoadedModule[113]=C:\Windows\system32\IPHLPAPI.DLL
      LoadedModule[114]=C:\Windows\system32\WINNSI.DLL
      LoadedModule[115]=C:\Windows\system32\api-ms-win-downlevel-shlwapi-l2-1-0.dll
      LoadedModule[116]=C:\Windows\system32\DNSAPI.dll
      LoadedModule[117]=C:\Windows\syswow64\urlmon.dll
      LoadedModule[118]=C:\Windows\system32\jsproxy.dll
      LoadedModule[119]=C:\Windows\SysWOW64\jscript.dll
      LoadedModule[120]=C:\Windows\System32\wshtcpip.dll
      LoadedModule[121]=C:\Windows\system32\rasadhlp.dll
      LoadedModule[122]=C:\Windows\System32\fwpuclnt.dll
      LoadedModule[123]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\ImageConversion.api
      LoadedModule[124]=C:\Windows\system32\mscms.dll
      LoadedModule[125]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\plug_ins\DistillerPI.api
      LoadedModule[126]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\amtlib.dll
      LoadedModule[127]=C:\Windows\system32\WINHTTP.dll
      LoadedModule[128]=C:\Windows\system32\webio.dll
      LoadedModule[129]=C:\Windows\system32\wbem\wbemprox.dll
      LoadedModule[130]=C:\Windows\system32\wbemcomn2.dll
      LoadedModule[131]=C:\Windows\system32\wbem\wbemsvc.dll
      LoadedModule[132]=C:\Windows\system32\wbem\fastprox.dll
      LoadedModule[133]=C:\Windows\system32\NTDSAPI.dll
      LoadedModule[134]=C:\Windows\syswow64\WINTRUST.dll
      LoadedModule[135]=C:\Windows\system32\WindowsCodecs.dll
      LoadedModule[136]=C:\Program Files (x86)\Common Files\TortoiseOverlays\TortoiseOverlays.dll
      LoadedModule[137]=C:\Windows\system32\api-ms-win-core-synch-l1-2-0.DLL
      LoadedModule[138]=C:\Program Files\TortoiseSVN\bin\TortoiseStub32.dll
      LoadedModule[139]=C:\Program Files\TortoiseSVN\bin\TortoiseSVN32.dll
      LoadedModule[140]=C:\Program Files\TortoiseSVN\bin\libsvn_tsvn32.dll
      LoadedModule[141]=C:\PROGRA~2\MICROS~1\Office15\GROOVEEX.DLL
      LoadedModule[142]=C:\Windows\system32\ATL100.DLL
      LoadedModule[143]=C:\PROGRA~2\MICROS~1\Office15\1033\GrooveIntlResource.dll
      LoadedModule[144]=C:\Windows\system32\EhStorShell.dll
      LoadedModule[145]=C:\Windows\system32\srvcli.dll
      LoadedModule[146]=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat Elements\ContextMenu.dll
      LoadedModule[147]=C:\Windows\system32\WINSPOOL.DRV
      LoadedModule[148]=C:\Windows\system32\mfc100u.dll
      LoadedModule[149]=C:\Windows\system32\MSIMG32.dll
      LoadedModule[150]=C:\Windows\system32\MFC100ENU.DLL
      LoadedModule[151]=C:\Program Files (x86)\Adobe\Acrobat 11.0\PDFMaker\Common\AdobePDFMakerX.dll
      LoadedModule[152]=C:\Windows\syswow64\COMDLG32.dll
      LoadedModule[153]=C:\Windows\system32\oledlg.dll
      LoadedModule[154]=C:\Windows\system32\WINMM.dll
      LoadedModule[155]=C:\Program Files (x86)\Adobe\Acrobat 11.0\PDFMaker\Common\PDFMakerAPI.dll
      LoadedModule[156]=C:\Windows\system32\SXS.DLL
      FriendlyEventName=Stopped working
      ConsentKey=APPCRASH
      AppName=Adobe Acrobat
      AppPath=C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Acrobat.exe
