2 Replies Latest reply on Nov 7, 2017 5:59 PM by psxhh
    display
    Mrs David
      got a new computer
      installed the suite onto it
      when I open photoshop, the buttons and everything is as tiny as can be
      I already changed my display settings to make things larger (icons, type, etc etc)
      I restarted my computer after
      but adobe still shows up as tiny buttons and text etc etc
      please help
        • 1. Re: display
          gravey-robber
          This is a problem as old as time for Adobe. Why they continue to ignore high-DPI screens baffles everyone. I had a registry hack to get cc 2017 exactly how I wanted. But I foolishly updated to 2018 and now its back to comically large or comically small ui. Your only solution is to go into Preferences > Interface and change the UI Scaling to 200%. 150% would be perfect on a 4k monitor but you don't get that choice and probably never will.
          • 2. Re: display
            psxhh Level 1
            为朋友YOGA 900笔记本,安装64位 Photoshop CS6完全版,好不易安装好之后,并激活,但显示界面,十分难看,难于使用。如下图:
            解决Photoshop <wbr>CS6在高分辨率下工具栏太小的办法
              原因分析,由于Photoshop CS6对高分辨率显示存在兼容性问题,笔记本最佳分辨率为3200*1800,所以显示出这样界面,据说Photoshop 2014无此情况。
            解决办法如下:
            打开附件文件夹里的 运行命令(win键+R),输入regedit确定进入注册表,
            1、打开注册表编辑器,展开找到:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide,找到 名为名为PreferExternalManifest的文件.
            2.如没有名为PreferExternalManifest文件的,接下来就是在HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curre ntVersion\SideBySide里面,右键新建文件,选择DW 32位的,新建后吧名字改为PreferExternalManifest。
            3.打开PreferExternalManifest文件,键值为1(记住是{10进制}的),然后确定。
            4.在Photoshop的安装目录C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)下将Photoshop.exe.manifest文件,拷入。(Photoshop.exe.manifest文件制作内容。)
            5.重新运行PS界面正常了!
            附件:Photoshop.exe.manifest文件制作内容
            新建文本文件,内容如下:
                      type="win32"
                  name="Microsoft.Windows.Common-Controls"
                  version="6.0.0.0" processorArchitecture="*"
                  publicKeyToken="6595b64144ccf1df"
                  language="*">
                      type="win32"
                  name="Microsoft.VC90.CRT"
                  version="9.0.21022.8"
                  processorArchitecture="amd64"
                  publicKeyToken="1fc8b3b9a1e18e3b">
                          level="asInvoker"
                    uiAccess="false"/>
              http://schemas.microsoft.com/SMI/2005/WindowsSettings">
                falsehttp://schemas.microsoft.com/SMI/2005/WindowsSettings">false>
            保存名件名为Photoshop.exe.manifest
