5 Replies Latest reply on Nov 13, 2017 9:29 AM by Jantzen.Belliston
    DTM Library Download
      Hi all,
      I need to download all my page load rules from DTM.
      I've already searched on this forum and found this:  Allow directly downloading library I've already read the official page on Library Management
      When I go to Library Download and click Download URLs and then visit the URL, I get this File not found." (yes, that single " is there at the end)
      Nothing I've found addresses this at all. Can someone help me?
        • 1. Re: DTM Library Download
          AbhijeetKMishra Adobe Employee
          The Library Download is one of the 'deployment options'. It lets you self-host your DTM library files. With the Library Download hosting option, dynamic tag management sends a ping (an HTTP post) to your system to let your servers know there has been an update to the library files.
          Your IT team can create a cron job, or other scripted process, so your servers can pick up the changed files. In this way, whenever a change is made in dynamic tag management, the files you are hosting on your servers can be updated automatically. Post this setup is complete, the URL is generated and it's used by DTM to make an HTTP POST call.
          If you already have this setup for your DTM company, please contact your IT team who would have access to the library location within your environment and would be able to share the library files with you.
          • 2. Re: DTM Library Download
            jubals62417259 Level 1
            That doesn't seem like a relevant response.
            I know the Library Download is a hosting option, but if I'm staging the files myself, I need to download the files first. Whether or not the update occurs via POST isn't relevant. I can't download the files in the first place, because it gives me that weird file not found." response.
            • 3. Re: DTM Library Download
              Jantzen.Belliston Adobe Employee
              Are you trying to download the staging or production environment? If your trying to download production, have you published your library at least once? The production library is not built until your first publish. This could be why you are seeing a not found error.
              • 4. Re: DTM Library Download
                Ah, I think I understand, Jantzen. Thank you for your answer. None of this seems clear from the interface or the documentation, so it's good to have some insight.
                Does it have to be "built" to a real URL or will a placeholder suffice? Because the link I'm trying to download from is Adobe hosted, not on our system.
                • 5. Re: DTM Library Download
                  I assume a placeholder would work. If not, you could always just enable Akamai and have the library built there until you are able to setup the self hosted option to your liking.
