• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Enable / Disable cfform validation.
New Here ,
Jun 19, 2008 Jun 19, 2008
I am using cfform for a CC payment form, and validating the CC number etc.. with the cfform "validate=credicard" paramater. This is all fine as usual.
I have a toggle in my form to show or hide particular fields depending on a radio button selected (Pay CC or Bank Tfr). If the CC payment fields are hidden (user has selected to pay by Bank Tfr), I don't want the validation for those fields to run. If they select CC payment, the validation should run. Validation is onSubmit.
I am trying to find a way of disabling or re-enabling the validation on given cfform fields. Have scoured the net, forums etc.. but just can't find anything.
Does anyone know how this could be acheived?
Many Thanks in advance.
TOPICS
Advanced techniques
Views
971
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer ,
Jun 26, 2008 Jun 26, 2008
You can actually validate the fields rather than using the onSubmit of cfform.
E.g:- Use the validate parameter in the cfinput
Votes
Translate
Translate
Report
Report
New Here ,
Hi AbhiFusion, thanks for your suggestion, but I don't know if I am sure I understand what you are suggesting. Could you elaborate?
Votes
Translate
Translate
Report
Report
Explorer ,
Just for example:-
You must be using a text field so that user can enter the credit card number. And this is what you want to validate. In this case use following code
Votes
Translate
Translate
Report
Report
New Here ,
That's exactly what I am doing.
My question though is how can I turn this validation OFF. I am validating the field, but if the user selects to pay by an option other than Credit Card, I need to be able to 'turn off' the validation process so that I can submit the form with this field empty.
Votes
Translate
Translate
Report
Report
Explorer ,
In that case, you can use the parameter onValidate and use a Javascript function which would check that if radio button is selected then what validation it has to do.
Ofcourse you would then need to embed the creditcard validation code in the javascript
Votes
Translate
Translate
Report
Report
Advocate ,
Jun 30, 2008 Jun 30, 2008
LATEST
A porr mans way to fix it would be to have you radio button onClick event set the value of the CC field to "0" the same time you hide or disable the field and set it to "" when you make it visible or enable the field.
"0" passes the Adobe CC check.
Votes
Translate
Translate
Report
Report
Resources
Documentation
