11 Replies Latest reply on Dec 4, 2017 3:19 PM by eyamam10
    Brush issue: straight lined circle
    eyamam10
      When i draw freehand curves, the brush starts straight... any one know a fix?
      Window 10, photoshop 2018.
      Wacom hybrid cintiq
        • 1. Re: Brush issue: straight lined circle
          davescm Adobe Community Professional
          Hi
          I couldn't get that to happen here on CC2018, Windows 10 and Intuos Pro.
          What are your brush settings, including smoothing options etc and I will try the same settings
          Dave
          • 2. Re: Brush issue: straight lined circle
            eyamam10 Level 1
            Here is my system info:
            Adobe Photoshop Version: 19.0 20170929.r.165 2017/09/29: 1138933  x64
            Number of Launches: 268
            Operating System: Windows 10 64-bit
            Version: 10 or greater 10.0.16299.15
            System architecture: Intel CPU Family:6, Model:14, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
            Physical processor count: 4
            Logical processor count: 8
            Processor speed: 2592 MHz
            Built-in memory: 65490 MB
            Free memory: 2 MB
            Memory available to Photoshop: 59461 MB
            Memory used by Photoshop: 60 %
            Surface Dial: Enabled.
            Alias Layers: Disabled.
            Modifier Palette: Disabled.
            Highbeam: Enabled.
            Image tile size: 128K
            Image cache levels: 2
            Font Preview: Medium
            TextComposer: Latin
            Display: 1
            Display Bounds: top=0, left=0, bottom=1080, right=1920
            Display: 2
            Display Bounds: top=0, left=1920, bottom=1080, right=3840
            Display: 3
            Display Bounds: top=0, left=-1920, bottom=1080, right=0
            OpenGL Drawing: Enabled.
            OpenGL Allow Old GPUs: Not Detected.
            OpenGL Drawing Mode: Normal
            OpenGL Allow Normal Mode: True.
            OpenGL Allow Advanced Mode: True.
            AIFCoreInitialized=1
            AIFOGLInitialized=1
            OGLContextCreated=1
            NumGLGPUs=1
            NumCLGPUs=1
            NumNativeGPUs=0
            glgpu[0].GLVersion="4.1"
            glgpu[0].IsIntegratedGLGPU=0
            glgpu[0].GLMemoryMB=3072
            glgpu[0].GLName="NVIDIA GeForce GTX 970M"
            glgpu[0].GLVendor="NVIDIA Corporation"
            glgpu[0].GLVendorID=4318
            glgpu[0].GLDriverVersion="22.21.13.8494"
            glgpu[0].GLRectTextureSize=16384
            glgpu[0].GLRenderer="GeForce GTX 970M/PCIe/SSE2"
            glgpu[0].GLRendererID=5080
            glgpu[0].HasGLNPOTSupport=1
            glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_82f0027a 32304e66\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_82f00 27a32304e66\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64_82 f0027a32304e66\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nvcvi.inf_amd64 _82f0027a32304e66\nvldumdx.dll"
            glgpu[0].GLDriverDate="20170718000000.000000-000"
            glgpu[0].CanCompileProgramGLSL=1
            glgpu[0].GLFrameBufferOK=1
            glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.50 NVIDIA"
            glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
            glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
            glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
            glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
            glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
            glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
            glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
            clgpu[0].CLPlatformVersion="1.2"
            clgpu[0].CLDeviceVersion="1.2 CUDA"
            clgpu[0].IsIntegratedCLGPU=0
            clgpu[0].CLMemoryMB=3072
            clgpu[0].CLName="GeForce GTX 970M"
            clgpu[0].CLVendor="NVIDIA Corporation"
            clgpu[0].CLVendorID=4318
            clgpu[0].CLDriverVersion="384.94"
            clgpu[0].CLBandwidth=9.94646e+10
            clgpu[0].CLCompute=1161.62
            License Type: Subscription
            Serial number: 90970216534337418732
            GUIDBucket:
            Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
            Temporary file path: C:\Users\ERICYA~1\AppData\Local\Temp\
            Photoshop scratch has async I/O enabled
            Scratch volume(s):
              Startup, 464.9G, 71.3G free
            Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
            Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
            Installed components:
               A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
               ACE.dll   ACE 2017/09/19-18:51:44   79.586793   79.586793
               AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
               AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
               AdobeOwl.dll   Adobe Owl   5.2.11
               AdobePDFL.dll   PDFL 2017/09/01-01:08:01   79.239219   79.239219
               AdobePIP.dll   Adobe Product Improvement Program   7.4.1.60.45263
               AdobeSVGAGM.dll   AdobeSVGAGM   79.586793   79.586793
               AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
               AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
               AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
               adobe_caps.dll   Adobe CAPS   10,0,0,6
               AGM.dll   AGM 2017/09/19-18:51:44   79.586793   79.586793
               ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
               AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
               amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
               ARE.dll   ARE 2017/09/19-18:51:44   79.586793   79.586793
               AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
               AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
               Bib.dll   BIB 2017/09/19-18:51:44   79.586793   79.586793
               BIBUtils.dll   BIBUtils 2017/09/19-18:51:44   79.586793   79.586793
               boost_date_time.dll   photoshopdva   11.1.0
               boost_filesystem.dll   photoshopdva   11.1.0
               boost_signals.dll   photoshopdva   11.1.0
               boost_system.dll   photoshopdva   11.1.0
               boost_threads.dll   photoshopdva   11.1.0
               cg.dll   NVIDIA Cg Runtime   3.0.00007
               cgGL.dll   NVIDIA Cg Runtime   3.0.00007
               CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
               CoolType.dll   CoolType 2017/09/19-18:51:44   79.586793   79.586793
               CRClient.dll   Adobe Crash Reporter Client DLL   1.6.1.0
               dnssd.dll   Bonjour   3,0,0,2
               dvaaudiodevice.dll   photoshopdva   11.1.0
               dvacore.dll   photoshopdva   11.1.0
               dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
               dvamarshal.dll   photoshopdva   11.1.0
               dvamediatypes.dll   photoshopdva   11.1.0
               dvametadata.dll   photoshopdva   11.1.0
               dvametadataapi.dll   photoshopdva   11.1.0
               dvametadataui.dll   photoshopdva   11.1.0
               dvaplayer.dll   photoshopdva   11.1.0
               dvatransport.dll   photoshopdva   11.1.0
               dvaui.dll   photoshopdva   11.1.0
               dvaunittesting.dll   photoshopdva   11.1.0
               dynamiclink.dll   photoshopdva   11.1.0
               ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1133690   81.1133690
               icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
               igestep30.dll   IGES Reader   9.3.0.113
               imslib.dll   IMSLib DLL   10.0.0.22
               JP2KLib.dll   JP2KLib 2017/08/23-01:11:25   79.267771   79.267771
               libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
               libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
               libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
               LogSession.dll   LogSession   7.4.1.60.45263
               mediacoreif.dll   photoshopdva   11.1.0
               MPS.dll   MPS 2017/09/01-01:08:01   79.586120   79.586120
               pdfsettings.dll   Adobe PDFSettings   1.04
               Photoshop.dll   Adobe Photoshop CC 2018   19.0
               Plugin.dll   Adobe Photoshop CC 2018   19.0
               PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.0.0
               PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.0.0.55
               PSArt.dll   Adobe Photoshop CC 2018   19.0
               PSCloud.dll                                                   1.0.0.1
               PSViews.dll   Adobe Photoshop CC 2018   19.0
               SCCore.dll   ScCore 2017/08/31-12:13:14   81.1133690   81.1133690
               SVGRE.dll   SVGRE   79.586793   79.586793
               svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
               tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
               tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
               TfFontMgr.dll   FontMgr   9.3.0.113
               TfKernel.dll   Kernel   9.3.0.113
               TFKGEOM.dll   Kernel Geom   9.3.0.113
               TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
               updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
               VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
               VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
               WRServices.dll   WRServices Thu Jan 07 2016 04:50:10   Build 0.21960   0.21960
               wu3d.dll   U3D Writer   9.3.0.113
            Required plug-ins:
               3D Studio 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Accented Edges 19.0 - from the file “Filter Gallery.8bf”
               Adaptive Wide Angle 19.0 - from the file “Adaptive Wide Angle.8bf”
               Angled Strokes 19.0 - from the file “Filter Gallery.8bf”
               Average 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Average.8bf”
               Bas Relief 19.0 - from the file “Filter Gallery.8bf”
               BMP 19.0 - from the file “Standard MultiPlugin.8bf”
               Camera Raw 10.0 - from the file “Camera Raw.8bi”
               Camera Raw Filter 10.0 - from the file “Camera Raw.8bi”
               Chalk && Charcoal 19.0 - from the file “Filter Gallery.8bf”
               Chrome 19.0 - from the file “Filter Gallery.8bf”
               Cineon 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Cineon.8bi”
               Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
               Collada 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Color Halftone 19.0 - from the file “Standard MultiPlugin.8bf”
               Colored Pencil 19.0 - from the file “Filter Gallery.8bf”
               CompuServe GIF 19.0 - from the file “Standard MultiPlugin.8bf”
               Conté Crayon 19.0 - from the file “Filter Gallery.8bf”
               Craquelure 19.0 - from the file “Filter Gallery.8bf”
               Crop and Straighten Photos 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “CropPhotosAuto.8li”
               Crop and Straighten Photos Filter 19.0 - from the file “Standard MultiPlugin.8bf”
               Crosshatch 19.0 - from the file “Filter Gallery.8bf”
               Crystallize 19.0 - from the file “Standard MultiPlugin.8bf”
               Cutout 19.0 - from the file “Filter Gallery.8bf”
               Dark Strokes 19.0 - from the file “Filter Gallery.8bf”
               De-Interlace 19.0 - from the file “Standard MultiPlugin.8bf”
               Dicom 19.0 - from the file “Dicom.8bi”
               Difference Clouds 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Clouds.8bf”
               Diffuse Glow 19.0 - from the file “Filter Gallery.8bf”
               Displace 19.0 - from the file “Standard MultiPlugin.8bf”
               Dry Brush 19.0 - from the file “Filter Gallery.8bf”
               Eazel Acquire 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “EazelAcquire.8ba”
               Entropy 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Export Color Lookup Tables 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
               Extrude 19.0 - from the file “Standard MultiPlugin.8bf”
               FastCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “FastCore.8bx”
               Fibers 19.0 - from the file “Standard MultiPlugin.8bf”
               Film Grain 19.0 - from the file “Filter Gallery.8bf”
               Filter Gallery 19.0 - from the file “Filter Gallery.8bf”
               Flash 3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Fresco 19.0 - from the file “Filter Gallery.8bf”
               Glass 19.0 - from the file “Filter Gallery.8bf”
               Glowing Edges 19.0 - from the file “Filter Gallery.8bf”
               Google Earth 4 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Graphic Pen 19.0 - from the file “Filter Gallery.8bf”
               Halftone Pattern 19.0 - from the file “Filter Gallery.8bf”
               Halide Bottlenecks 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “HalideBottlenecks.8bx”
               HDRMergeUI 19.0 - from the file “HDRMergeUI.8bf”
               HSB/HSL 19.0 - from the file “Standard MultiPlugin.8bf”
               IFF Format 19.0 - from the file “Standard MultiPlugin.8bf”
               IGES 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Ink Outlines 19.0 - from the file “Filter Gallery.8bf”
               JPEG 2000 19.0 - from the file “JPEG2000.8bi”
               Kurtosis 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Lens Blur 19.0 - from the file “Lens Blur.8bf”
               Lens Correction 19.0 - from the file “Lens Correction.8bf”
               Lens Flare 19.0 - from the file “Standard MultiPlugin.8bf”
               Liquify 19.0 - from the file “Liquify.8bf”
               Matlab Operation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
               Maximum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Mean 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Measurement Core 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MeasurementCore.8me”
               Median 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Mezzotint 19.0 - from the file “Standard MultiPlugin.8bf”
               Minimum 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               MMXCore Routines 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MMXCore.8bx”
               Mosaic Tiles 19.0 - from the file “Filter Gallery.8bf”
               Multiprocessor Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “MultiProcessor Support.8bx”
               Neon Glow 19.0 - from the file “Filter Gallery.8bf”
               Note Paper 19.0 - from the file “Filter Gallery.8bf”
               NTSC Colors 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “NTSC Colors.8bf”
               Ocean Ripple 19.0 - from the file “Filter Gallery.8bf”
               OpenEXR 19.0 - from the file “Standard MultiPlugin.8bf”
               Paint Daubs 19.0 - from the file “Filter Gallery.8bf”
               Palette Knife 19.0 - from the file “Filter Gallery.8bf”
               Patchwork 19.0 - from the file “Filter Gallery.8bf”
               Paths to Illustrator 19.0 - from the file “Standard MultiPlugin.8bf”
               PCX 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PCX.8bi”
               Photocopy 19.0 - from the file “Filter Gallery.8bf”
               Photoshop 3D Engine 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Photoshop3DEngine.8bi”
               Photoshop Touch 19.0 - from the file “PSDX.8bi”
               Picture Package Filter 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “ChannelPort.8bf”
               Pinch 19.0 - from the file “Standard MultiPlugin.8bf”
               Pixar 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Pixar.8bi”
               Plaster 19.0 - from the file “Filter Gallery.8bf”
               Plastic Wrap 19.0 - from the file “Filter Gallery.8bf”
               PLY 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Pointillize 19.0 - from the file “Standard MultiPlugin.8bf”
               Polar Coordinates 19.0 - from the file “Standard MultiPlugin.8bf”
               Portable Bit Map 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “PBM.8bi”
               Poster Edges 19.0 - from the file “Filter Gallery.8bf”
               PRC 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Radial Blur 19.0 - from the file “Standard MultiPlugin.8bf”
               Radiance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Radiance.8bi”
               Range 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Render Color Lookup Grid 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Export3DLUT.8be”
               Reticulation 19.0 - from the file “Filter Gallery.8bf”
               Ripple 19.0 - from the file “Standard MultiPlugin.8bf”
               Rough Pastels 19.0 - from the file “Filter Gallery.8bf”
               Save for Web 19.0 - from the file “Save for Web.8be”
               ScriptingSupport 19.0 - from the file “ScriptingSupport.8li”
               Shake Reduction 19.0 - from the file “Shake Reduction.8bf”
               Shear 19.0 - from the file “Standard MultiPlugin.8bf”
               Skewness 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Smart Blur 19.0 - from the file “Standard MultiPlugin.8bf”
               Smudge Stick 19.0 - from the file “Filter Gallery.8bf”
               Solarize 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “Solarize.8bf”
               Spaces 19.0 - from the file “Spaces.8li”
               Spatter 19.0 - from the file “Filter Gallery.8bf”
               Spherize 19.0 - from the file “Standard MultiPlugin.8bf”
               Sponge 19.0 - from the file “Filter Gallery.8bf”
               Sprayed Strokes 19.0 - from the file “Filter Gallery.8bf”
               Stained Glass 19.0 - from the file “Filter Gallery.8bf”
               Stamp 19.0 - from the file “Filter Gallery.8bf”
               Standard Deviation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               STL 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Sumi-e 19.0 - from the file “Filter Gallery.8bf”
               Summation 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Targa 19.0 - from the file “Standard MultiPlugin.8bf”
               Texturizer 19.0 - from the file “Filter Gallery.8bf”
               Tiles 19.0 - from the file “Standard MultiPlugin.8bf”
               Torn Edges 19.0 - from the file “Filter Gallery.8bf”
               Twirl 19.0 - from the file “Standard MultiPlugin.8bf”
               U3D 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Underpainting 19.0 - from the file “Filter Gallery.8bf”
               Vanishing Point 19.0 - from the file “VanishingPoint.8bf”
               Variance 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “statistics.8ba”
               Virtual Reality Modeling Language | VRML 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               Water Paper 19.0 - from the file “Filter Gallery.8bf”
               Watercolor 19.0 - from the file “Filter Gallery.8bf”
               Wave 19.0 - from the file “Standard MultiPlugin.8bf”
               Wavefront|OBJ 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “U3D.8bi”
               WIA Support 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WIASupport.8li”
               Wind 19.0 - from the file “Standard MultiPlugin.8bf”
               Wireless Bitmap 19.0 (20170929.r.165 2017/09/29: 1138933) - from the file “WBMP.8bi”
               ZigZag 19.0 - from the file “Standard MultiPlugin.8bf”
            Optional and third party plug-ins: NONE
            Duplicate and Disabled plug-ins: NONE
            Plug-ins that failed to load: NONE
            Extensions: NONE
            Installed TWAIN devices: NONE
            • 3. Re: Brush issue: straight lined circle
              eyamam10 Level 1
              i realized this happens when i create a new layer. so what i did was i used the eraser side of my pen and it goes back to clean lines without the straight.
              is there a way that i dont have to flip my stylus each time i create a new layer so i can have good lines?
              • 4. Re: Brush issue: straight lined circle
                Hi
                I don't see anything wrong with your system settings - what brush settings are you using ? I will try the same
                Dave
                • 5. Re: Brush issue: straight lined circle
                  eyamam10 Level 1
                  i know its not the brush, its the system.
                  It occurs consistantly when i'm switching between other apps and photoshop, from on screen to another screen. i have a 3 screen setup,
                  • 6. Re: Brush issue: straight lined circle
                    Hi
                    I also use three screens here without any issues. The difference is between the Intuos Pro that I am using and the Cintiq that you are using. Hopefully someone with a similar system set up will come along to help you
                    Dave
                    • 7. Re: Brush issue: straight lined circle
                      Trevor.Dennis Adobe Community Professional
                      What are your Smoothing settings?
                      Have you tried turning Smoothing off?
                      Are you using Lazy Nezumi Pro?  If so, are you using Photoshop _and_ LNP smoothing?
                      Do you have the grid turned on?
                      Does this happen when using the mouse?
                      Are your Wacom drivers up to date?
                      Are you using the Windows Ink, or WinTab API?   WinTab generally works better with Windows 8.1 and 10.  (LINK)
                      • 8. Re: Brush issue: straight lined circle
                        Do you have your other hand resting on the tablet when using the brush?   It might be that the tablet is interpreting, (or trying to) the two pressure areas as a Gesture.  Turn off gestures on Photoshop Preferences, or keep the other hand clear of the tablet.
                        Also check your Pen & Touch > Press & Hold settings in Control Panel.
                        [EDIT]  Just to add that like Dave, I also use three screens with Windows 10, and have no issue.  I have a Cintiq Companion 2 I could hook up if all else fails, but its a PITA to do that, so last resort.  If there is anyone reading this that uses a Wacom tablet with Touch capabilities, then can you give us some feedback please.  Intuos 5 Touch, for instance.
                        • 9. Re: Brush issue: straight lined circle
                          eyamam10 Level 1
                          tried the winTab, no luck.
                          and i dont rest my hand on tablet.
                          it consistantly happens when i go to chrome on my third monitor, click or type in chrome. then come back to photoshop on my second screen -cintiq - and try drawing with pen. maybe its my wireless mouse?
                          • 10. Re: Brush issue: straight lined circle
                            eyamam10 Level 1
                            Its the MOUSE! I tried toggle display on cintiq and it drew fine, then i tried the mouse and it was the culpit...
                            thank you all
                            any reccomends on a better wireless mouse?
                            • 11. Re: Brush issue: straight lined circle
                              eyamam10 Level 1
                              i figured it out.
                              Turn off all apps that sync: Google Drive, Dropbox, Etc.
                              no more brush lag.
