Can I run Premiere on my old Macbook Pro?
2,26 GHz Intel Core 2 Duo
8 Go 1067 MHz DDR3
NVIDIA GeForce 9400M 256 Mo
OSX 10.11.6
Thanks a lot.
P.
It will install, but it won't run well. It will give extremely slow performance. So much so that you will become frustrated using it.
Not a good idea. Thanks a lot. Can I have access to an older version of Premiere?
Adobe now only sells CC by subscription with access to CS6, but that won't run well either.
If you find Premiere Pro CS4, it may run, but you will only be able to edit SD, not HDV or HD.
Thanks for your time.
You're welcome.
Moved to the Hardware Forum.
You will get no GPU Acceleration with that 256MB 9400M
With that P8400 2-core CPU and no hyperthreading I doubt that even Premiere Elements would work.
It all depends on your media, lots of current media is highly compressed and require massive CPU power to decode
