1. Re: Can't open any file in Photoshop!
kglad Nov 9, 2017 8:15 PM (in response to veror47012991)reset your preferences - https://forums.adobe.com/thread/375776
[moved from Adobe Creative Cloud to Photoshop General Discussion]
2. Re: Can't open any file in Photoshop!
veror47012991 Nov 10, 2017 3:39 AM (in response to kglad)1 person found this helpfulNope, didn't help
3. Re: Can't open any file in Photoshop!
master mo Nov 10, 2017 3:45 AM (in response to veror47012991)Can you access the cooler settings from the Edit menu?
I'm sure you've done this, but worth a double check.
Quit Ps, hold in Mac: Command, Option, Shift while starting up Photoshop.
Keep the keys in till you get the dialog.
A dialog box will appear asking if you wish to delete the preferences/settings file.
Choose Yes.
HTH
4. Re: Can't open any file in Photoshop!
veror47012991 Nov 10, 2017 3:58 AM (in response to master mo)Did it. Will do it again now
5. Re: Can't open any file in Photoshop!
veror47012991 Nov 10, 2017 4:03 AM (in response to master mo)1 person found this helpfulok. now it opens files from the top menu in ps: file - open
but if you drag and drop, or try to open file straight from finder, or right click - open with - nothing
6. Re: Can't open any file in Photoshop!
master mo Nov 10, 2017 4:57 AM (in response to veror47012991)cool, progress.
Let's try repair the disk permissions on your drive.
Can you run First Aid on your hard drive.
Go to Applications > Utilities > Disk Utility.
Then choose First Aid.
Click OK.
Tes tao see if it helps
7. Re: Can't open any file in Photoshop!
veror47012991 Nov 10, 2017 1:06 PM (in response to master mo)Done. Same window appeared when started Ps Could not synchronize the color settings because the color settings file could not be found.
8. Re: Can't open any file in Photoshop!
veror47012991 Nov 14, 2017 7:56 AM (in response to veror47012991)Still have a problem. Anyone?
9. Re: Can't open any file in Photoshop!
roctorio Nov 19, 2017 3:03 AM (in response to veror47012991)I have the same issue. I've deleted the .psp file and I'm using Photoshop CC 2018 which was recently updated to version 19.0.1.
I can't open anything, and when I try to create a new file, the tools doesn't respond.
10. Re: Can't open any file in Photoshop!
kathypills Dec 12, 2017 2:20 PM (in response to master mo)Tried this. It didn't work. Still won't open any files.
11. Re: Can't open any file in Photoshop!
alexc60662478 Jan 10, 2018 10:24 AM (in response to roctorio)I'm also having this exact same issue, same version of PS. Nothing suggested so far fixes it.
12. Re: Can't open any file in Photoshop!
kathypills Jan 10, 2018 11:52 AM (in response to alexc60662478)What finally worked for me was to uninstall any of the PS versions on my computer. Then I re-downloaded it. Now it works.
13. Re: Can't open any file in Photoshop!
alexc60662478 Jan 12, 2018 3:26 AM (in response to kathypills)1 person found this helpfulI've tried reinstalling (and deleting all my preferences) but it's exactly the same.
I've noticed while I can't open any file by dragging it in or double clicking, I can go File > open and it does open files and seems to work as normal.
I've also noticed that the Creative Cloud app seems to think PS is not installed on my machine - it has a blue 'install' button next to it. If I click it it seems to start downloading then... nothing... then goes back to the blue install button.
14. Re: Can't open any file in Photoshop!
typegirly Feb 13, 2018 3:59 PM (in response to veror47012991)FWIW I was having the same problems mentioned in several comments above. Even that of CC not acknowledging that I even had all the apps on my computer. So I did what I used to always do as my first precautionary measure…I zapped my PRAM. After doing so the computer finished booting and CC was then telling my PS needed to be updated (all other apps were normal). I updated. Then I double-clicked on my file, held my breath…and the file opened. Error seems to be gone.
