2 Replies Latest reply on Oct 23, 2009 12:55 PM by abeytz
    Create angle, reflected, diamond gradient using actionscript
    gghfh
      As you know, in Graphics class there is beginGradientFill method to draw
      gradient:
      beginGradientFill(type:String, colors:Array, alphas:Array, ratios:Array, matrix:Matrix = null, spreadMethod:String = "pad", interpolationMethod:String = "rgb", focalPointRatio:Number = 0):void
      I saw that the first parameter "type:String" only have two values: "linear" or "radial". In photoshop, beside theses there are "angle", "reflected", "diamond" gradient type also.
      So which class (or libraries etc) I can use in order to create "angle", "reflected", "diamond" gradient using fully actionscript?
      Or "angle", "reflected", "diamond" gradient type can not be implemented using AS?
      Could anyone point me to the right direction?
      many thanks and best regards
