4 Replies Latest reply on Nov 14, 2017 1:21 PM by deanwarren30621
    How can I hide or make visible checkboxes based on a single checkbox selection?
    deanwarren30621
      I am creating a form to ask:
      Have you had any of the following in the past 12 months? (Check all that apply or check here if None [ ]<--named "None Apply" )
      checkbox.1  Problem maintaining balance.
      checkbox.2  Mental health problems.
      checkbox.3  Shortness of breath
      checkbox.4  Chemical Dependency
      checkbox.5  Needed emergency care
      checkbox.6  Other (Explain: [TextboxOther])
      My checkbox JS is as follows:
      #1 var oAll = this.getField("checkbox");
      #2 var aAll = oAll.getArray();
      #3
      #4 //if "None Apply" checkbox is not checked[Off] then checkbox.1-6 remain visible. If checked then hide checkbox.[1-6] if unchecked become visible again.
      #5 if (event.target.value !== "Off") {
      #6 //set the check boxes to hidden if none apply;
      #7 for(var i = 0; i < aAll.length; i++){
      # 8 this.getField("aAll.[i]").display = display.hidden;
      #9    console.println(aAll.[i].value);
      #10 }
      #11 }
      #12 else {
      #13 //set the check boxes to visible if the none box not checked;
      #14 for(var i = 0; i < aAll.length; i++){
      #15 this.getField("aAll.[i]").display = display.visible;
      #16 }
      # 17}
      I am getting a syntax error in line 11 that I cannot see for the life of me.  Slowly going bald...
        • 1. Re: How can I hide or make visible checkboxes based on a single checkbox selection?
          Thom Parker Adobe Community Professional
          There are a number of issues with your code, get rid of it all.
          I'm assuming that the script is for a "MouseUp" action on the "None" checkbox?
          If so, then this script will work
          this.getField("checkbox").display = (event.target.value=="Off")?display.visible:display.hidden;
          • 2. Re: How can I hide or make visible checkboxes based on a single checkbox selection?
            deanwarren30621 Level 1
            Hey Thom,
            First off, Whoa! I have been ghosting the forums a while and I never thought I would have you answer my stupid newbie question! I always wonder at how you can do the same task in on or 2 lines of code that it takes me half a page to do. Thanks for your attention!!!
            Yes, the script is for a "MouseUp" action on the "None" checkbox.
            I ended up using a simple If then else that works:
            //choose check box and hide checkboxes beneath this one
            if ((this.getField("None Apply").value) !== "Off") {
            this.getField("Check Box1").display = display.hidden;
            this.getField("Check Box2").display = display.hidden;
            this.getField("Check Box3").display = display.hidden;
            this.getField("Check Box4").display = display.hidden;
            this.getField("Check Box5").display = display.hidden;
            this.getField("Check Box6").display = display.hidden;
            this.getField("Other Issues").display = display.hidden;
            else {
            this.getField("Check Box1").display = display.visible;
            this.getField("Check Box2").display = display.visible;
            this.getField("Check Box3").display = display.visible;
            this.getField("Check Box4").display = display.visible;
            this.getField("Check Box5").display = display.visible;
            this.getField("Check Box6").display = display.visible;
            How does the code you suggested work?
            |-----------I get this part ok--------|    |-is this shorthand for if ("None Apply" == "Off") then display.visible else display.hidden--|
            How can I do the this with the variable names I have listed here?
            What naming convention should I normally use for multiple fields or checkboxes?
            Where in the Adobe Acrobat DC SDK should I be focusing my attention?
            I don't want you to write my code for me, I want to figure out how to create a workable solution so I can be an effective coder myself.
            Again, I am a big fan and I appreciate your input and suggestions.
            Thank you,
            Dean
            • 3. Re: How can I hide or make visible checkboxes based on a single checkbox selection?
              In the original post the field names use the "dot" notation, which groups the fields together. I'm assuming you know how this is able to work on all the field in the group at the same time.
              That said, using numbers and the field type for the field names is not syntactically incorrect, but it is stylistically unsound.
              It would be better to use names like "Condition.balance", "Condition.mentalHealth", etc.
              The conditional operator <condition>?<true option>:<false option>  is just shorthand for an "if/then" statement.  You'll find it listed in any core JS reference under operators.
              event.target.value refers to the committed value of the field on which the event is occurring. i.e MouseUp happens after the value is committed to the check box
              • 4. Re: How can I hide or make visible checkboxes based on a single checkbox selection?
                Awesome!
                Thank you Sir! Your explination also clarifies how I can actually use the field names to my advantage. While I roughly understood the "dot" notation this makes it a great deal clearer.
                Best Regards,
                Dean
