2 Replies Latest reply on Nov 27, 2017 9:40 AM by twinbrush
    Applying Color to Open SVG Font
    adamvlaw
      I just discovered Open SVG (Color Font) format. I purchased a hand-painted font in this format, but it seems I can only use it as a black font. There are no other options in the glyph menu either. Is there some trick I am not doing that would let me colorize an Open SVG font? What am I missing here? I feel dumb. I hate that.
      Best,
      Adam
        • 1. Re: Applying Color to Open SVG Font
          MikeGondek Adobe Community Professional & MVP
          If they did not include other glyphs then you will have to recolor using a nonsvg method
          1. outline the font to shapes and use recolor artwork
          2. draw a rectangle on top, fill with a color, and choose a blending mode like color. Unfortunately you will need to mask unless your have a background color the will not be affected (eg.: black)
          • 2. Re: Applying Color to Open SVG Font
            twinbrush Level 2
            Hey Adam,
            It all depends too on what version of Illustrator you are running. Color SVG fonts are only compatible with a few programs at the minute:
            Illustrator CC 2018+ and Photoshop CC 2017+ are Adobe’s only apps that officially support & display color fonts (InDesign CC 2018 got unofficial support)
            The black appearance that you are getting is an indicator that your version doesn't support the Open color svg format and it is using the simpler, backwards compatible format.
            Hope that helps
            Rian
            Twinbrush
