2 Replies Latest reply on Nov 13, 2017 1:46 AM by jacekj59956765
    Horizontal display problem
      Hi, i'm just starting with javascript and i have a problem.
      How do I make the ink List display horizontally with breaks like this:
      Now I have:
      And I can not figure out how to do it ...
      var docRef=app.activeDocument;
      //Create 100% CMYK colors to be assigned to the process inks.
      var processCyan = new CMYKColor();
      processCyan.black = 0;
      processCyan.cyan = 100;
      processCyan.magenta = 0;
      processCyan.yellow = 0;
      var processMagenta = new CMYKColor();
      processMagenta.black = 0;
      processMagenta.cyan = 0;
      processMagenta.magenta = 100;
      processMagenta.yellow = 0;
      var processYellow = new CMYKColor();
      processYellow.black = 0;
      processYellow.cyan = 0;
      processYellow.magenta = 0;
      processYellow.yellow = 100;
      var processBlack = new CMYKColor();
      processBlack.black = 100;
      processBlack.cyan = 0;
      processBlack.magenta = 0;
      processBlack.yellow = 0;
      //Prompt the user for the desired text size.
      var SepTextSize=Window.prompt("Enter the desired text size in points:", 9);
      //Variable for specifying font by name.//Ensure the size will be interpreted as a number, not as text.
      var sepTextSize=parseFloat(SepTextSize);
      //Vertical and horizontal location for the labels.
      var sepTextTop=sepTextSize;
      var sepTextX= 6;
      var sepTextY = sepTextSize/2;
      var sepTextFont = textFonts.getByName("MyriadPro-Cond");
      //Loop through the members of the document's inkList.
      var inkRef=docRef.inkList[i]; //Variable for the current ink.
           var inkRefName=inkRef.name; //Variable for the current ink's name.
            //Create a pointText object for the current ink's label.
           var sepTextLabel = docRef.textFrames.pointText([sepTextX,sepTextY]);
      sepTextLabel.contents = inkRefName; //Set its content to the name of the ink.
          sepTextLabel.textRange.characterAttributes.size=sepTextSize; //Set its text size as was specified by user.
          sepTextLabel.textRange.characterAttributes.leading=sepTextSize;//Set its leading 100% of its text size.
          sepTextLabel.textRange.characterAttributes.textFont = sepTextFont
          switch (inkRef.inkInfo.kind) {
              case InkType.CYANINK://If the current ink is Cyan.
              sepTextLabel.textRange.characterAttributes.fillColor=processCyan;//Fill the characters with processCyan.
          sepTextLabel.contents = "Cyan " + '\r' + docRef.inkList[i].inkInfo.frequency + "lpi"  + "/" + docRef.inkList[i].inkInfo.angle; // nazwa inku
              case InkType.MAGENTAINK://If the current ink is Magenta.
              sepTextLabel.textRange.characterAttributes.fillColor=processMagenta;//Fill the characters with processMagenta.
              sepTextLabel.contents = "Magenta" ;
              case InkType.YELLOWINK://If the current ink is Yellow.
              sepTextLabel.textRange.characterAttributes.fillColor=processYellow;//Fill the characters with processYellow.
              sepTextLabel.contents = "Yellow" ;
              case InkType.BLACKINK://If the current ink is Black.
              sepTextLabel.textRange.characterAttributes.fillColor=processBlack;//Fill the characters with processBlack.
              sepTextLabel.contents = "Black" ;
              case InkType.CUSTOMINK://If the current ink is a spot color.
              sepTextLabel.textRange.characterAttributes.fillColor=docRef.swatches.getByName(inkRefName ).color;//Fill it with the Swatch that is named the same as the ink.
              sepTextLabel.contents = inkRefName + '\r' + docRef.inkList[i].inkInfo.frequency + "lpi"  + "/" + docRef.inkList[i].inkInfo.angle;
              sepTextLabel.textRange.characterAttributes.fillColor=docRef.swatches.getByName("[Registra tion]").color;//Fill the characters with Registration.
              }//end switch}//end for
        • 1. Re: Horizontal display problem
          CarlosCanto Adobe Community Professional & MVP
          you're adding all text frames at the same location, [sepTextX, sepTextY]
          you need to increase X position (sepTextX) after each pass. So, ink 2 will be your current x position + the width of the text frame + any spacing you want between frames
          // declare a variable for spacing before you start your loop
          var spacing = 15;
          then way at the end of the the loop, before the closing curly brace, increase you X position, so ink 2 gets added correctly
              sepTextX = sepTextX + sepTextLabel.width + spacing;
          } // closing for loop curly brace
          • 2. Re: Horizontal display problem
            jacekj59956765 Level 1
            You are genius!
            Thanks, you helped me a lot, now I understand that
