1 Reply Latest reply on Jun 15, 2018 8:52 AM by peterhinson
    Cannot import any video files
    andrewn49761271
      Hello,
      I have tried importing video files from three different sources, each gives me the error "This file appears to be unsupported or damaged".
      The files are from Leica D-LUX Type 109, GoPro HERO5 Session, iPhone 7 Plus. They all open perfectly in QuickTime and VLC.
      Here is the output from ffprobe on the files to show the codecs being used:
      $ ffprobe -i LeicaDLUX.MP4
      Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'LeicaDLUX.MP4':
        Metadata:
          major_brand     : mp42
          minor_version   : 1
          compatible_brands: mp42avc1
          creation_time   : 2017-06-28T12:41:12.000000Z
        Duration: 00:00:19.68, start: 0.000000, bitrate: 20474 kb/s
          Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 20296 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc (default)
          Metadata:
          Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 125 kb/s (default)
          Metadata:
      $ ffprobe -i GoPro.MP4
      Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'GoPro.MP4':
        Metadata:
          major_brand     : mp41
          minor_version   : 538120216
          compatible_brands: mp41
          creation_time   : 2017-10-08T13:49:24.000000Z
          firmware        : HD5.03.02.51.00
        Duration: 00:08:52.01, start: 0.000000, bitrate: 60190 kb/s
          Stream #0:0(eng): Video: h264 (High) (avc1 / 0x31637661), yuvj420p(pc, bt709), 1920x1080 [SAR 1:1 DAR 16:9], 59993 kb/s, 90 fps, 90 tbr, 90k tbn, 180 tbc (default)
          Metadata:
            handler_name    : GoPro AVC
            encoder         : GoPro AVC encoder
          Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 128 kb/s (default)
          Metadata:
            handler_name    : GoPro AAC
          Stream #0:2(eng): Data: none (gpmd / 0x646D7067), 34 kb/s (default)
          Metadata:
            handler_name    : GoPro MET
          Stream #0:3(eng): Data: none (fdsc / 0x63736466), 17 kb/s (default)
          Metadata:
            handler_name    : GoPro SOS
      $ ffprobe -i iPhone.MOV
      Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'iPhone.MOV':
        Metadata:
          major_brand     : qt
          minor_version   : 0
          compatible_brands: qt
          creation_time   : 2017-11-13T01:40:32.000000Z
          com.apple.quicktime.location.ISO6709: -33.8881+151.1936+025.233/
          com.apple.quicktime.make: Apple
          com.apple.quicktime.model: iPhone 7 Plus
          com.apple.quicktime.software: 11.0.2
          com.apple.quicktime.creationdate: 2017-11-13T12:40:32+1100
        Duration: 00:00:05.53, start: 0.000000, bitrate: 15030 kb/s
          Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1920x1080, 14922 kb/s, 30 fps, 30 tbr, 600 tbn, 1200 tbc (default)
          Metadata:
            rotate          : 90
            handler_name    : Core Media Data Handler
            encoder         : H.264
          Side data:
            displaymatrix: rotation of -90.00 degrees
          Stream #0:1(und): Audio: aac (LC) (mp4a / 0x6134706D), 44100 Hz, mono, fltp, 95 kb/s (default)
          Metadata:
          Stream #0:2(und): Data: none (mebx / 0x7862656D), 0 kb/s (default)
          Metadata:
          Stream #0:3(und): Data: none (mebx / 0x7862656D), 0 kb/s (default)
          Metadata:
      Am I doing something wrong? Does Lightroom not support video files? Any advice on this matter would be greatly appreciated!
