I want to change the color of a Movieclip with a Mouse click. I have two areas. When I click on on one Area, the second should change in this color, wich I wrote in the Code.
But I don't know how to write this code in Javascript (please no answers in HTML)...
I should be able to write the color in hexadecimal.
Please can someone help me.. It's very important.
Thank you
in your click listener (if you bind(this)), you can use (if you want blue):
this.your_movieclip.shape.graphics._fill.style = "#0000FF";
The code does not work
I have this code:
this.Marine_2.addEventListener("click", fl_MouseClickHandler_8.bind(this));
function fl_MouseClickHandler_8()
this.flaeche2.shape.graphics._fill.style = "#0000FF";
Is this wrong? what do I have to do?
one (or both) of your objects are not defined. use the console to see where you made the error.
How do I define a object? Is "flaeche2" my object? Its a movieclip on the stage.
"Uncaught TypeError: Cannot read property 'shape' of undefined"
This happens, when I click on "Marine_2"
Whats does that mean?
on your stage, click what you think is Marine_2 and check the properties panel. that object should have an instance name of Marine_2 in the top-most field. likewise for flaeche2. (and case-counts!)
Thank you 🙂 it works. But now I have a new error.. "Uncaught TypeError: Cannot set property 'style' of null" What is that?
open you console to see what line of code is triggering that error.
if you don't know what the console is, what browser are you using to test?
this.bise1.shape.graphics._fill.style = "#0000FF";
makes the error... and i don't know why...
And I test it with chrome
on your stage, click what you think is bise1 and check the properties panel. that object should have an instance name of bise1 in the top-most field.
(p.s when using the adobe forums, please mark helpful/correct responses, if there are any.)
It has this name... thats why I am so confused...
remove the bise1 movieclip from all keyframes that contain it.
create a new layer and add a keyframe where you first want bise1 to appear. assign its instance name.
add other keyframe where needed and add you code where needed.
retest.
I don't know, what you mean It says every time the same... "Uncaught TypeError: Cannot set property 'style' of null"
what don't you understand about message 11?
Hi, Kglad...
Its me again. I've tried the code. I have two movieclips name btnSet and theStar. When btnSet clicked, theStar suppose to be change color (as I wish). But really nothing happen with theStar (not even change the color).
This is the code :
And this is error message when button btnSet is clicked :
What I'm missing ?
create a new fla
create and add a btnSet movieclip to frame 0
create and add a (eg, red) theStar movieclip to frame 0.
double check their instance names (in the properties panel)
copy and past the code you showed
test > click btnSet
did you see the red theStar turn blue?
Your fla is working perfect anyway. But everytime I created new fla, that code didn't work. Until I found this thread : https://community.adobe.com/t5/animate-discussions/change-color-tint-fill-of-a-symbol-in-an-animate-...
So, I replace the code to :
this.redStar.shape_1.graphics._fill.style = "#0000FF";
And it works!
By the way I use Animate 2019. Is that code only work in latest version of Animate?
still confused....
are you using an old animate version?
I use Adobe Animate CC 2019.
that's the problem. cc 2019 does some illogical stuff.
This is great stuff.
