3 Replies Latest reply on Dec 11, 2017 4:32 AM by sivaramakumar Pedaprolu
    Comparing 2 string values
    associationp15747777 Level 1
      Hello
      I'm stuck with something that should have been easy to do: I need to compare 2 values and do different things depending on the result.
      The 2 values type are string.
      My first idea was to use a simple "equal" condition in the filtering window.
      But checking the result, I realised that 2 empty field were seen as "non-equal" whereas they should have been equal.
      I tried to use the IfEquals function but no luck as well
      Any idea how to simply check if 2 fields as identifical  ? Assuming that a null field is equivalent to an empty field ?
      Thanks for your insights
