• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to stop getting prompts for password in Adobe Pro for Mac
New Here ,
Nov 13, 2017 Nov 13, 2017
Since I downloaded a trial version of Adobe Acrobat Pro for Mac (2015.006.30355), I have been plagued with dozens of prompts like the following. I hit Always Allow, but the prompts keep coming at unexpected moments. Any idea how to solve this? Apple seems to be saying that they don't recognize the developer.
TOPICS
General troubleshooting
Views
55.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee , Nov 29, 2017 Nov 29, 2017
Hi all,
Please note that we have released a patch today that should mitigate the repeated pop-up issue for most configurations. However, there are a few leftover cases for which we are actively working with Apple to address them.
This update will be automatically pushed to all existing installations of Acrobat and Reader. If you want, you may also manually trigger the update by opening the application and going to Help > Check for Updates.
More information about this release is here: https://helpx.adobe.com/acrobat/release-note/acrobat-dc-november-29-2017.html
Votes
Translate
Translate
Adobe Employee ,
Nov 15, 2017 Nov 15, 2017
Hello Jjjjp,
We apologize for the inconvinience caused, as per the description above, you are getting the prompts to enter the password as shown in the screenshot, Is that correct?
Please try the following steps:
  • Please enter the computer password and click on "Always allow".
If above does not work, then please try the following steps:
    1. Go to ‘Keychain access’. Select 'login' from left side pane > search for 'v4.services.acrobat.com' from the corresponding list > double click on it > select 'Access control'.
    2. If there’s any entry of 'com.apple.Webkit.Plugin.64.xpc' delete it by clicking on '-'. Press 'Save changes' and provide your password.
          c.Then manually get the plugin added. For that please click on '+' and traverse to the location /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices and select 'com.apple.WebKit.Plugin.64.xpc'.
          d.Press 'Save changes' and provide your password.
If this also does not work, then try:
  • Open keychain. Right click on 'Login' from left-hand pane and select 'change settings for keychain login'.
  • Make sure both the options are unchecked as shown in the images below. If the options are checked then ‘login’ keychain might be getting locked after some time and that’s why it’s asking for the  password to unlock it whenever it needs to access ‘login’ keychain.
Hope this helps. Please do let us know  if this did not work.
Regards,
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks, Anand. Yes, you're understanding of my issue is correct. I just tried step 2 (step 1 already having been followed on multiple occasions) and will let you know if the problem returns and step 3 doesn't handle it. (The appearance of the prompts has been fairly random and can occur some time after I have quit the program.)
Votes
Translate
Translate
Report
Report
New Here ,
Sep 07, 2018 Sep 07, 2018
I have a "v3.services issue on mine...none of these fixes works.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hello Joek,
We're sorry for the trouble you had, make sure that you have the latest version Acrobat installed, check for any pending updates of Acrobat from help>check for updates, reboot the machine after updating Acrobat.
What is the current dot version of Acrobat installed? To identify refer to  Identify the product and its version for Acrobat and Reader DC
What is the version of the OS installed?
Let us know how it goes and share your observation.
Anand Sri.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Thank you, Jerry, for trying the troubleshooting steps. Hope the issue gets fixed.
Keep us posted with the results.
Regards,
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 16, 2017 Nov 16, 2017
I received only one prompt after following step 2. I have since then switched from a trial to an ongoing subscription purchased (and downloaded anew) as part of a license through my university. One prompt and nothing since, so in all likelihood problem resolved. Thanks.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Nov 17, 2017 Nov 17, 2017
That's so awesome to hear. Give us a shout if you need any assistance with this or Acrobat/Reader in future.
Regards,
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 20, 2017 Nov 20, 2017
FYI, the problem has not actually gone away. Today I have received about four such prompts at random times. Lat time it happened I was in Preview with Adobe Acrobat DC also opened, but I can't say whether this is part of any pattern. I have been through all three steps. In Step 2, those boxes were unchecked to begin.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Nov 28, 2017 Nov 28, 2017
Hello Jerry,
Sorry for the delay in response to your query and apologize for the inconvenience caused. I am following up to check is the issue is resolved or you still getting the prompt/pop-up at random times.
Let us know the status.
Regards,
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Thanks. A senior program manager got in touch with me. She said there will be a patch in an upcoming update that should address the issue. The problem does persist, but I elected to wait rather than to install the unofficial patch.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi all,
Please try it out and let us know your feedback.
Thanks for your patience and support!
-ashu
Votes
Translate
Translate
Report
Report
New Here ,
Nov 30, 2017 Nov 30, 2017
Sorry to have to report that I just got one of those random pop-ups. Acrobat DC was open at the time. I updated yesterday.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Thank you for the update. Please keep us posted on  the status.
- Anand Sri.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Oct 12, 2018 Oct 12, 2018
This is most annoying and still happening to me. CC says everything is up to day? What now? The box appears for everything I try to do like 100 times every 5 minutes.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hi Verovine,
I am sorry for the trouble you had, if you are still experiencing the issue, I will request you to contact the support team so that they can schedule a remote session for further investigation and assist you in a better manner. For Chat support, use the URL Contact Customer Care
I have also shared  the direct contact details for Call Support by direct message, please check your email inbox.
Anand Sri.
Votes
Translate
Translate
Report
Report
New Here ,
Nov 16, 2018 Nov 16, 2018
Like verovine, I am getting this prompt constantly and CC says everything is up to date. I am running High Sierra 10.13.5 and Acrobat DC 19.008.20080. I clicked on "contact Customer Care" as you suggested for verovine, but all it offered me was the community forum. Can you suggest anything, Anand?
Thanks!
Votes
Translate
Translate
Report
Report
New Here ,
Nov 23, 2018 Nov 23, 2018
same here!  i updated to Indesign and Photoshop 2019 and since then, i'm going crazy with all the pop-ups.  i'm trying to uninstall everything and start all over again after.  i hope it works because that's a real turn off.
Votes
Translate
Translate
Report
Report
Dec 12, 2018 Dec 12, 2018
This is so rediculous!!!
Votes
Translate
Translate
Report
Report
Updating got me in all sorts of trouble which took weeks for me to sort and finally begin work again thinking I'M NEVER UPDATING AGAIN. And now you are saying we have to update (A G A I N) and risk being messed up again? Just to solve an update issue you have obviously across the board with all users????????????????????? Please explain!!!!!
Votes
Translate
Translate
Report
Report
New Here ,
Mar 24, 2022 Mar 24, 2022
I solved this problem brilliantly:
* Uninstall and not using creative cloud ...
To Adobe: This should not happen. I get this all the time and it can not be stopped.
Votes
Translate
Translate
Report
Report
Aug 21, 2022 Aug 21, 2022
So, not using creative cloud solves the problem? You don't mean unistall the apps like photoshop and indesign, correct? I never thought of that. Do the apps still work?
Votes
Translate
Translate
Report
Report
New Here ,
May 25, 2023 May 25, 2023
LATEST
This is a burdensome glitch, and none of these suggestions works. It seems to be an issue with Macintosh computers only.
Votes
Translate
Translate
Report
Report
