25 Replies Latest reply on Mar 13, 2018 7:18 AM by joshm29708292
    Android build fails with File-Transfer plugin
    umerpasha Level 1
      It started happening today. Last stable build was on Friday.
      If I take out the File-Transfer plugin it works. I tried older version of the plugin but still the same error.
      Build Date: 2017-11-14 00:21:34 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-battery-status@~1.1.1" via npm
      Installing "cordova-plugin-battery-status" at "1.1.2" for android
      Fetching plugin "cordova-plugin-camera" via npm
      Installing "cordova-plugin-camera" at "3.0.0" for android
      Plugin doesn't support this project's cordova-android version. cordova-android: 6.1.2, failed version requirement: >=6.3.0
      Skipping 'cordova-plugin-camera' for android
      Fetching plugin "cordova-plugin-media-capture" via npm
      Installing "cordova-plugin-media-capture" at "2.0.0" for android
      Skipping 'cordova-plugin-media-capture' for android
      Fetching plugin "cordova-plugin-console" via npm
      Installing "cordova-plugin-console" at "1.1.0" for android
      Fetching plugin "cordova-plugin-contacts" via npm
      Installing "cordova-plugin-contacts" at "3.0.0" for android
      Skipping 'cordova-plugin-contacts' for android
      Fetching plugin "cordova-plugin-device" via npm
      Installing "cordova-plugin-device" at "1.1.7" for android
      Fetching plugin "cordova-plugin-device-motion" via npm
      Installing "cordova-plugin-device-motion" at "2.0.0" for android
        [DEPRECATED] - cordova-plugin-device-motion
        With the W3C Device Motion and Orientation API now being supported on iOS, Android and Windows devices, this plugin is not needed any more. Read more about the API at https://www.w3.org/TR/2016/CR-orientation-event-20160818/
      Fetching plugin "cordova-plugin-device-orientation" via npm
      Installing "cordova-plugin-device-orientation" at "2.0.0" for android
        [DEPRECATED] - cordova-plugin-device-orientation
      Fetching plugin "cordova-plugin-dialogs" via npm
      Installing "cordova-plugin-dialogs" at "1.3.4" for android
      Fetching plugin "cordova-plugin-file" via npm
      Installing "cordova-plugin-file" at "5.0.0" for android
      Skipping 'cordova-plugin-file' for android
      Fetching plugin "cordova-plugin-file-transfer" via npm
      Installing "cordova-plugin-file-transfer" at "1.7.0" for android
      Plugin dependency "cordova-plugin-file@5.0.0" already fetched, using that version.
      Fetching plugin "cordova-plugin-geolocation" via npm
      Installing "cordova-plugin-geolocation" at "3.0.0" for android
      Skipping 'cordova-plugin-geolocation' for android
      Fetching plugin "cordova-plugin-globalization" via npm
      Installing "cordova-plugin-globalization" at "1.0.8" for android
      Fetching plugin "cordova-plugin-inappbrowser" via npm
      Installing "cordova-plugin-inappbrowser" at "1.7.2" for android
      Fetching plugin "cordova-plugin-media" via npm
      Installing "cordova-plugin-media" at "4.0.0" for android
      Skipping 'cordova-plugin-media' for android
      Fetching plugin "cordova-plugin-network-information" via npm
      Installing "cordova-plugin-network-information" at "1.3.4" for android
      Fetching plugin "cordova-plugin-splashscreen" via npm
      Installing "cordova-plugin-splashscreen" at "4.1.0" for android
      Fetching plugin "cordova-plugin-vibration" via npm
      Installing "cordova-plugin-vibration" at "2.1.6" for android
      Fetching plugin "cordova-plugin-appversion" via npm
      Installing "cordova-plugin-appversion" at "1.0.0" for android
      Fetching plugin "cordova-plugin-nativesettings" via npm
      Installing "com.phonegap.plugins.nativesettingsopener" at "1.1.0" for android
      Fetching plugin "cordova-plugin-whitelist" via npm
      Installing "cordova-plugin-whitelist" at "1.3.3" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "cordova-plugin-barcodescanner@0.7.1" via npm
      Installing "cordova-plugin-barcodescanner" at "0.7.1" for android
      Fetching plugin "cordova-plugin-compat@^1.0.0" via npm
      Installing "cordova-plugin-compat" at "1.2.0" for android
      Fetching plugin "cordova-plugin-touchid" via npm
      Installing "cordova-plugin-touchid" at "0.4.0" for android
      Fetching plugin "com.toshyodev.imagepicker" via npm
      Installing "com.toshyodev.imagepicker" at "1.0.0" for android
      Subproject Path: CordovaLib
      COMPILE OUTPUT
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :preReleaseBuild UP-TO-DATE
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :CordovaLib:preReleaseBuild UP-TO-DATE
      :CordovaLib:checkReleaseManifest
      :CordovaLib:prepareReleaseDependencies
      :CordovaLib:compileReleaseAidl
      :CordovaLib:compileReleaseNdk UP-TO-DATE
      :CordovaLib:copyReleaseLint UP-TO-DATE
      :CordovaLib:mergeReleaseShaders
      :CordovaLib:compileReleaseShaders
      :CordovaLib:generateReleaseAssets
      :CordovaLib:mergeReleaseAssets
      :CordovaLib:mergeReleaseProguardFiles
      :CordovaLib:packageReleaseRenderscript UP-TO-DATE
      :CordovaLib:compileReleaseRenderscript
      :CordovaLib:generateReleaseResValues
      :CordovaLib:generateReleaseResources
      :CordovaLib:packageReleaseResources
      :CordovaLib:processReleaseManifest
      :CordovaLib:generateReleaseBuildConfig
      :CordovaLib:processReleaseResources
      :CordovaLib:generateReleaseSources
      :CordovaLib:incrementalReleaseJavaCompilationSafeguard
      :CordovaLib:compileReleaseJavaWithJavac
      :CordovaLib:compileReleaseJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      :CordovaLib:processReleaseJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForRelease
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForRelease
      :CordovaLib:mergeReleaseJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForRelease
      :CordovaLib:transformNative_libsWithSyncJniLibsForRelease
      :CordovaLib:bundleRelease
      :prepareComAndroidSupportAnimatedVectorDrawable2340Library
      :prepareComAndroidSupportAppcompatV72340Library
      :prepareComAndroidSupportSupportV42340Library
      :prepareComAndroidSupportSupportVectorDrawable2340Library
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResourceswarning: string 'menu_settings' has no default translation.
      Warning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      /project/src/org/apache/cordova/filetransfer/FileTransfer.java:49: error: package org.apache.cordova.file does not exist
      import org.apache.cordova.file.FileUtils;
      /project/src/org/apache/cordova/filetransfer/FileTransfer.java:851: error: cannot find symbol
        FileUtils filePlugin = (FileUtils) pm.getPlugin("File");
        symbol: class FileUtils
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      3 errors
      :compileDebugJavaWithJavac FAILED
      FAILURE: Build failed with an exception.
      * What went wrong:
      Execution failed for task ':compileDebugJavaWithJavac'.
      > Compilation failed; see the compiler error output for details.
      * Try:
      Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 6.438 secs
      Error: /project/gradlew: Command failed with exit code 1 Error output:
      3 errors
      * What went wrong:
      * Try:
        at ChildProcess.whenDone (/project/cordova/node_modules/cordova-common/src/superspawn.js:169:23)
        at emitTwo (events.js:106:13)
        at ChildProcess.emit (events.js:191:7)
        at maybeClose (internal/child_process.js:877:16)
        at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
        • 1. Re: Android build fails with File-Transfer plugin
          vangroover Adobe Employee
          there are a few new cordova plugins that are not backwards compatible with older versions of cordova. that is what is causing the issue.
          we are working on a solution to do this automatically but we are trying to get xcode 9 provisioned first.
          1. ALWAYS ALWAYS ALWAYS lock the version of the plugins you add to your project
          2. ALWAYS ALWAYS ALWAYS lock the version of the plugins you add to your project
          3. run npm info cordova-plugin-XXXXXXXX engines versions
          4. lock the version of the plugins you add to your project
          the result of that command will list out the dependency requirements for the plugin. you must then pick the latest version that is satisfied by a cordovaDepenency OR is not listed as having a dependency.
          • 2. Re: Android build fails with File-Transfer plugin
            alexd1057411
            Can you fix it?
            Cant Build my program anymore after this issue.
            Thanks in advance
            • 3. Re: Android build fails with File-Transfer plugin
              duncana50866232
              In the meantime use the version e.g. below:
              <plugin name="cordova-plugin-file-transfer" spec="~1.6.1" />
              • 4. Re: Android build fails with File-Transfer plugin
                neptunes72895978
                Still when locking the plugin versions  to  "the one that makes it build successfully"  (in my case with CLI-6.5.0  in PGB),  then the plugins do not work as expected.
                For example, try building using CLi 6.5.0,  set    <plugin name="cordova-plugin-camera" spec="~2.4.1" />
                and try to use the camera.. unfortunately it will not work.
                • 5. Re: Android build fails with File-Transfer plugin
                  crf121359 Level 1
                  I have the same issue!! The iOS build works fine but the Android Build fails!
                  Someone on this post said something in the lines of "ALWAYS, ALWAYS ALWAYS....." but they did not mention anythIng about the fact that older version of plugins do not work with the latest Cordova or PGB!
                  This is causing a huge problem for everyone and it would be good for PGB developers to at least give us the courtesy of a simple notification so we'd know where we stand with this and not leaving us all in the dark. I've been trying to figure out why all of a sudden the android build stopped working for the past 2 days!!
                  • 6. Re: Android build fails with File-Transfer plugin
                    mchag Level 1
                    Hello UmerPash,
                    Can you try below configuration it should resolve your issue.
                    <plugin name="cordova-plugin-file-transfer" spec="~1.6.1" source="npm"/>
                    Chagu
                    • 7. Re: Android build fails with File-Transfer plugin
                      umeshs3040718
                      hi, you can try below version it work for me.
                      <gap:plugin name="cordova-plugin-file-transfer"  source="npm"  spec="~1.6.3"/>
                      • 8. Re: Android build fails with File-Transfer plugin
                        canados Level 1
                        Same problem for me, also I used the force version statement
                        • 9. Re: Android build fails with File-Transfer plugin
                          nathans54396327 Level 1
                          I too was having the same problems: Android build failing with no version forced for plugins cordova-plugin-file or cordova-plugin-file-transfer.
                          So, I forced versions by doing the following:
                          <plugin name="cordova-plugin-file" spec="4.3.3"/>
                          <plugin name="cordova-plugin-file-transfer" spec="1.6.3"/>
                          And now it builds for both iOS and Android. (CLI 7.0.1, haven't tried 6.5.X)
                          • 10. Re: Android build fails with File-Transfer plugin
                            umerpasha Level 1
                            Problem is not just one version of a plug-in. See the log above. Problem is with all plug-ins while using CLI 650. Something has changed in CLI itself. It was working fine a week before. Even if I use the config.xml with the locked versions and CLI 650,it fails to build.
                            • 11. Re: Android build fails with File-Transfer plugin
                              umerpasha Level 1
                              Any changes to plugins that can break current build should be communicated properly. I can understand this about 3rd party plugins but phonegap's built-in plug-ins should not just start malfunctioning with the same versions. I tried going back one step to previous versions of all plugins and still get problems. It'd probably be okay to find the right version that works if you had a couple of plug-ins used but my app uses 12 plugins. It takes too long doing hit and trial for each plug-in going down version by version. Also, I will have to test the whole app again both for android and iOS if anything was a miss in one of those previous versioned plugins.
                              • 12. Re: Android build fails with File-Transfer plugin
                                umerpasha Level 1
                                CLI 750 throwing Android build error as well
                                • 13. Re: Android build fails with File-Transfer plugin
                                  umerpasha Level 1
                                  Here is the list of versions of plugins to use with CLI 6.5.0. Checked and worked fine for both iOS and android. Removed orientation and motion as they are DEPRECATED.
                                  <plugin name="cordova-plugin-battery-status" source="npm" spec="1.2.5"/>
                                  <plugin name="cordova-plugin-camera" source="npm" spec="2.4.1"/>
                                  <plugin name="cordova-plugin-contacts" source="npm" spec="2.3.1" />
                                  <plugin name="cordova-plugin-media-capture" source="npm" spec="1.4.3"/>
                                  <plugin name="cordova-plugin-console" source="npm" spec="1.1.0" />
                                  <plugin name="cordova-plugin-device" source="npm" spec="1.1.7"/>
                                  <plugin name="cordova-plugin-dialogs" source="npm" spec="1.3.4" />
                                  <plugin name="cordova-plugin-file" source="npm" spec="4.3.3"/>
                                  <plugin name="cordova-plugin-file-transfer"  source="npm" spec="1.6.3" />
                                  <plugin name="cordova-plugin-geolocation" source="npm" spec="2.4.3"  />
                                  <plugin name="cordova-plugin-globalization" source="npm" spec="1.0.8" />
                                  <plugin name="cordova-plugin-inappbrowser" source="npm" spec="1.7.2" />
                                  <plugin name="cordova-plugin-media" source="npm" spec="3.0.1" />
                                  <plugin name="cordova-plugin-network-information" source="npm" spec="1.3.4" />
                                  <plugin name="cordova-plugin-splashscreen" source="npm" spec="4.1.0" />
                                  <plugin name="cordova-plugin-vibration" source="npm" spec="2.1.6"/>
                                  <plugin name="cordova-plugin-appversion" source="npm" spec="1.0.0" />
                                  <plugin name="cordova-plugin-nativesettings" source="npm" spec="1.1.0" />
                                  <plugin name="cordova-plugin-whitelist" source="npm" spec="1.3.2"  />
                                  2 people found this helpful
                                  • 14. Re: Android build fails with File-Transfer plugin
                                    sakhiwom20480800 Level 1
                                    Hi All, also experienced the same issue
                                    I used the below to resolve this:
                                    And now it builds for both iOS and Android. (CLI 7.0.1)
                                    Thanks nathans54396327
                                    • 15. Re: Android build fails with File-Transfer plugin
                                      neilm64907889 Level 1
                                      Thanks been a massive help.
                                      • 16. Re: Android build fails with File-Transfer plugin
                                        itaye24957416
                                        Looks much better and even works
                                        • 17. Re: Android build fails with File-Transfer plugin
                                          umeshs7319483
                                          HI,
                                          I am facing problem with file transfer plugin. in filetransfer.Download(). getting error code 3 message in android only.
                                          below is my code.
                                          var mimeType = options.mimeType || 'application/pdf';
                                          window.requestFileSystem(LocalFileSystem.PERSISTENT, 0,
                                          function (fileSystem) {
                                              var fileTransfer = new FileTransfer();
                                          var fileName = fileSystem.root.toURL() + options.fileName;
                                          fileTransfer.download(
                                          options.url,
                                          fileName,
                                          function (entry) {
                                              cordova.plugins.fileOpener2.open(
                                          decodeURI(entry.toURL()),
                                          mimeType,
                                          error: function (errorObj) {
                                          Ext.Viewport.unmask();
                                          alert('Error status: ' + errorObj.status + ' - Error message: ' + errorObj.message);
                                          function (error) {
                                          Ext.Msg.alert('Error', "download error source " + error.source + "<br />" + "download error target " + error.target + "<br />" + "upload error code" + error.code);
                                          function (error) {
                                          Ext.Msg.alert('Error', error);
                                          • 18. Re: Android build fails with File-Transfer plugin
                                            Hey man, any chance you can paste your config.xml here, im having problems with Android only, IOS is fine - it compiles fine, but some of my app buttons are not working in Android (fine in IOS) -  trying to trouble shoot just about anything
                                            • 19. Re: Android build fails with File-Transfer plugin
                                              jeroen511
                                              For anyone who tried this:
                                              But it didn't work, here's something to try:
                                              -go to the plugins folder (same location as www) and edit fetch.json
                                              -there find cordova-plugin-file and cordova-plugin-file-transfer and remove the ^ symbol. So you have something like cordova-plugin-file@4.3.3
                                              I also messed with ios.json, but I don't think that matter.
                                              What seemed to happen for me was that cordova kept downloading the wrong plugins based on the fetch.json and ignored anything in the confix.xml. I also found some old plugins in there which were still being downloaded.
                                              In any case, I hope this works for anyone else experiencing the same problem.
                                              • 20. Re: Android build fails with File-Transfer plugin
                                                umeshs7319483 Level 1
                                                1. Check your Phonegape dashboard build version. it should be 6.5.0 with(android 4.5.0 and other take default build platform version) do not used 7.0.1
                                                2. Then in config xml use
                                                Or
                                                <gap:plugin name="cordova-plugin-file"  source="npm" spec="~4.3.3"/>
                                                • 21. Re: Android build fails with File-Transfer plugin
                                                  alexandrer52996637
                                                  Estou com o mesmo problema. Complicado!
                                                  • 23. Re: Android build fails with File-Transfer plugin
                                                    roofdecc Level 1
                                                    I have just tried using config settings suggested by umerpasha for building with android and it fails every time i feel like this is only recently. I am trying to upload from phonegap build with no luck
                                                    config.xml
                                                        <preference name="phonegap-version"           value="cli-6.5.0" />
                                                    log
                                                    Build Date: 2017-12-20 15:29:10 +0000
                                                    PLUGIN OUTPUT
                                                    Fetching plugin "cordova-open" via npm
                                                    Installing "cordova-open" at "1.0.12" for android
                                                    Fetching plugin "cordova-plugin-statusbar" via npm
                                                    Installing "cordova-plugin-statusbar" at "2.3.0" for android
                                                    Plugin "cordova-plugin-file-transfer" already installed on android. Making it top-level.
                                                    Fetching plugin "cordova-plugin-camera@2.4.1" via npm
                                                    Installing "cordova-plugin-camera" at "2.4.1" for android
                                                    Fetching plugin "cordova-plugin-compat@^1.1.0" via npm
                                                    COMPILE OUTPUT
                                                    The Task.leftShift(Closure) method has been deprecated and is scheduled to be removed in Gradle 5.0. Please use Task.doLast(Action) instead.
                                                    at build_7wixtwdqfouum25jxm0lsrdoy.run(/project/build.gradle:137)
                                                    The JavaCompile.setDependencyCacheDir() method has been deprecated and is scheduled to be removed in Gradle 4.0.
                                                    The TaskInputs.source(Object) method has been deprecated and is scheduled to be removed in Gradle 4.0. Please use TaskInputs.file(Object).skipWhenEmpty() instead.
                                                    The ProjectDependency.getProjectConfiguration() method has been deprecated and is scheduled to be removed in Gradle 4.0.
                                                    ModuleDependency.getConfiguration() has been deprecated and is scheduled to be removed in Gradle 4.0. Use ModuleDependency.getTargetConfiguration() instead.
                                                    :checkDebugManifest
                                                    :prepareComAndroidSupportSupportV42411Library
                                                    :compileDebugAidl
                                                    Note: /project/src/org/apache/cordova/filetransfer/FileTransfer.java uses unchecked or unsafe operations.
                                                    3 errors
                                                    * What went wrong:
                                                    * Try:
                                                    BUILD FAILED
                                                    Total time: 1.548 secs
                                                    3 errors
                                                    * What went wrong:
                                                    * Try:
                                                    • 24. Re: Android build fails with File-Transfer plugin
                                                      umerpasha Level 1
                                                      Hi Roofdec. Looking at your log, it appears as if you have specified the plugins twice. See this section of your log:
                                                      You see how it is fetching 170 for file transfer and 500 for file plugin? and then it says, it is already fetched so using the latest? PPlease post your config.xml if problem persists. I checked the plugins I posted with CLI 650 at my end again and it compiled fine.
                                                      • 25. Re: Android build fails with File-Transfer plugin
                                                        joshm29708292 Level 1
                                                        Below is my log output, I have tried versions 1.5.1 and 1.6.3 of the file transfer plugin to no avail on Android.  Everything seems to be working fine on iOS.  I can get version 1.5.1 to work properly if I use cli 7.0.1 but failed on 7.1.0 and 8.0.0.  I have also pasted the plugins that I have in my config file as well.
                                                        <plugin name="cordova-plugin-network-information" source="npm" version="1.3.4" />
                                                        <plugin name="cordova-plugin-splashscreen" source="npm" version="4.1.0" />
                                                        <plugin name="cordova-plugin-whitelist" source="npm" version="1.3.3" />
                                                        <plugin name="cordova-plugin-console" source="npm" version="1.1.0" />
                                                        <plugin name="cordova-plugin-media-capture" source="npm" version="1.4.3" />
                                                        <plugin name="cordova-plugin-contacts" source="npm" version="2.3.1" />
                                                        <plugin name="cordova-plugin-device" source="npm" version="1.1.7" />
                                                        <plugin name="cordova-plugin-geolocation" source="npm" version="2.4.3" />
                                                        <plugin name="cordova-plugin-inappbrowser" source="npm" version="1.7.2" />
                                                        <plugin name="cordova-plugin-media" source="npm" version="3.0.1" />
                                                        <plugin name="cordova-plugin-dialogs" source="npm" version="1.3.4" />
                                                        <plugin name="cordova-plugin-camera-with-exif" source="npm" />
                                                        <plugin name="cordova-plugin-file-transfer" source="npm" version="1.5.1" />
                                                        <plugin name="cordova-plugin-file" source="npm" version="4.3.3" />
                                                        <plugin name="cordova-plugin-zip" source="npm" version="3.1.0" />
                                                        <plugin name="cordova-plugin-x-toast" source="npm" version="2.6.0" />
                                                        <plugin name="cordova-plugin-background-fetch" source="npm" version="5.3.0" />
                                                        <plugin name="uk.co.workingedge.phonegap.plugin.launchnavigator" source="npm" version="4.1.5"/>
                                                        Build Date: 2018-03-13 14:01:41 +0000
                                                        PREPARE OUTPUT
                                                        Android Studio project detected
                                                        Generating platform-specific config.xml from defaults for android at /app/src/main/res/xml/config.xml
                                                        Merging project's config.xml into platform-specific android config.xml
                                                        Merging and updating files from [, ../platform_www] to ../app/src/main/assets/www
                                                          copy FullSizeRender.jpg ../app/src/main/assets/www/FullSizeRender.jpg (new file)
                                                          mkdir ../app/src/main/assets/www/Images
                                                          copy Images/wait_dots_green.gif ../app/src/main/assets/www/Images/wait_dots_green.gif (new file)
                                                          copy Images/wait_dots_red.gif ../app/src/main/assets/www/Images/wait_dots_red.gif (new file)
                                                          copy _instantUpdateSettings.js ../app/src/main/assets/www/_instantUpdateSettings.js (new file)
                                                          copy _phoneGapSettings.js ../app/src/main/assets/www/_phoneGapSettings.js (new file)
                                                          mkdir ../app/src/main/assets/www/a5images
                                                          copy a5images/boxsize8x8fillUp5FDiagonalWhite3A232552C2392C239.png ../app/src/main/assets/www/a5images/boxsize8x8fillUp5FDiagonalWhite3A232552C2392C239.png (new file)
                                                          copy a5images/logo.png ../app/src/main/assets/www/a5images/logo.png (new file)
                                                          copy a5images/null1x1.png ../app/src/main/assets/www/a5images/null1x1.png (new file)
                                                          copy a5images/windowbuttonclose.png ../app/src/main/assets/www/a5images/windowbuttonclose.png (new file)
                                                          mkdir ../app/src/main/assets/www/a5v12src
                                                          mkdir ../app/src/main/assets/www/a5v12src/etruck2.WebProjects
                                                          mkdir ../app/src/main/assets/www/a5v12src/etruck2.WebProjects/Default.WebProject
                                                          mkdir ../app/src/main/assets/www/a5v12src/etruck2.WebProjects/Default.WebProject/PhoneGapProjec ts
                                                          mkdir ../app/src/main/assets/www/a5v12src/etruck2.WebProjects/Default.WebProject/PhoneGapProjec ts/timekeeper
                                                          copy baseline.zip ../app/src/main/assets/www/baseline.zip (new file)
                                                          copy config.xml ../app/src/main/assets/www/config.xml (new file)
                                                          mkdir ../app/src/main/assets/www/cordova-js-src
                                                          mkdir ../app/src/main/assets/www/cordova-js-src/android
                                                          copy ../platform_www/cordova-js-src/android/nativeapiprovider.js ../app/src/main/assets/www/cordova-js-src/android/nativeapiprovider.js (new file)
                                                          copy ../platform_www/cordova-js-src/android/promptbasednativeapi.js ../app/src/main/assets/www/cordova-js-src/android/promptbasednativeapi.js (new file)
                                                          copy ../platform_www/cordova-js-src/exec.js ../app/src/main/assets/www/cordova-js-src/exec.js (new file)
                                                          copy ../platform_www/cordova-js-src/platform.js ../app/src/main/assets/www/cordova-js-src/platform.js (new file)
                                                          mkdir ../app/src/main/assets/www/cordova-js-src/plugin
                                                          mkdir ../app/src/main/assets/www/cordova-js-src/plugin/android
                                                          copy ../platform_www/cordova-js-src/plugin/android/app.js ../app/src/main/assets/www/cordova-js-src/plugin/android/app.js (new file)
                                                          copy ../platform_www/cordova.js ../app/src/main/assets/www/cordova.js (updated file)
                                                          mkdir ../app/src/main/assets/www/css/A5System
                                                          mkdir ../app/src/main/assets/www/css/A5System/GenericStyles
                                                          mkdir ../app/src/main/assets/www/css/A5System/GenericStyles/Default
                                                          copy css/A5System/GenericStyles/Default/AccordionTitle.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/AccordionTitle.png (new file)
                                                          copy css/A5System/GenericStyles/Default/AccordionTitleHover.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/AccordionTitleHover.png (new file)
                                                          copy css/A5System/GenericStyles/Default/ListHighlight.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/ListHighlight.png (new file)
                                                          copy css/A5System/GenericStyles/Default/ListSelected.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/ListSelected.png (new file)
                                                          copy css/A5System/GenericStyles/Default/TabBottomSelected.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/TabBottomSelected.png (new file)
                                                          copy css/A5System/GenericStyles/Default/TabLeftSelected.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/TabLeftSelected.png (new file)
                                                          copy css/A5System/GenericStyles/Default/TabRightSelected.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/TabRightSelected.png (new file)
                                                          copy css/A5System/GenericStyles/Default/TabTopSelected.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/TabTopSelected.png (new file)
                                                          copy css/A5System/GenericStyles/Default/TabbandBackground.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/TabbandBackground.png (new file)
                                                          copy css/A5System/GenericStyles/Default/WindowButtonGrad.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/WindowButtonGrad.png (new file)
                                                          copy css/A5System/GenericStyles/Default/WindowButtonsGrad.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/WindowButtonsGrad.png (new file)
                                                          copy css/A5System/GenericStyles/Default/WindowMainGrad.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/WindowMainGrad.png (new file)
                                                          copy css/A5System/GenericStyles/Default/WindowTrans.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/WindowTrans.png (new file)
                                                          copy css/A5System/GenericStyles/Default/WindowTransHighlight.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/WindowTransHighlight.png (new file)
                                                          copy css/A5System/GenericStyles/Default/WindowTransHighlightBottom.png ../app/src/main/assets/www/css/A5System/GenericStyles/Default/WindowTransHighlightBottom. png (new file)
                                                          copy css/A5System/GenericStyles/Default/style.css ../app/src/main/assets/www/css/A5System/GenericStyles/Default/style.css (new file)
                                                          mkdir ../app/src/main/assets/www/css/A5System/Images
                                                          copy css/A5System/Images/designModeDropOff.png ../app/src/main/assets/www/css/A5System/Images/designModeDropOff.png (new file)
                                                          copy css/A5System/Images/designModeDropOn.png ../app/src/main/assets/www/css/A5System/Images/designModeDropOn.png (new file)
                                                          copy css/A5System/Images/designModeIcons.png ../app/src/main/assets/www/css/A5System/Images/designModeIcons.png (new file)
                                                          copy css/A5System/Images/designModeIconsHover.png ../app/src/main/assets/www/css/A5System/Images/designModeIconsHover.png (new file)
                                                          copy css/A5System/Images/designModeTip.png ../app/src/main/assets/www/css/A5System/Images/designModeTip.png (new file)
                                                          copy css/A5System/Images/menuCheck.png ../app/src/main/assets/www/css/A5System/Images/menuCheck.png (new file)
                                                          copy css/A5System/Images/menuRadio.png ../app/src/main/assets/www/css/A5System/Images/menuRadio.png (new file)
                                                          copy css/A5System/Images/resizeThumb.gif ../app/src/main/assets/www/css/A5System/Images/resizeThumb.gif (new file)
                                                          copy css/A5System/Images/spinner1.gif ../app/src/main/assets/www/css/A5System/Images/spinner1.gif (new file)
                                                          copy css/A5System/Images/spinner2.gif ../app/src/main/assets/www/css/A5System/Images/spinner2.gif (new file)
                                                          copy css/A5System/Images/tabclose.png ../app/src/main/assets/www/css/A5System/Images/tabclose.png (new file)
                                                          copy css/A5System/Images/tabcloseHover.png ../app/src/main/assets/www/css/A5System/Images/tabcloseHover.png (new file)
                                                          copy css/A5System/Images/wait.gif ../app/src/main/assets/www/css/A5System/Images/wait.gif (new file)
                                                          mkdir ../app/src/main/assets/www/css/A5System/Vista
                                                          copy css/A5System/Vista/theme.css ../app/src/main/assets/www/css/A5System/Vista/theme.css (new file)
                                                          copy css/A5System/Vista/theme.js ../app/src/main/assets/www/css/A5System/Vista/theme.js (new file)
                                                          mkdir ../app/src/main/assets/www/css/A5System/Vista/tree
                                                          copy css/A5System/Vista/tree/bc.png ../app/src/main/assets/www/css/A5System/Vista/tree/bc.png (new file)
                                                          copy css/A5System/Vista/tree/bch.png ../app/src/main/assets/www/css/A5System/Vista/tree/bch.png (new file)
                                                          copy css/A5System/Vista/tree/bo.png ../app/src/main/assets/www/css/A5System/Vista/tree/bo.png (new file)
                                                          copy css/A5System/Vista/tree/boh.png ../app/src/main/assets/www/css/A5System/Vista/tree/boh.png (new file)
                                                          copy css/A5System/Vista/tree/n.png ../app/src/main/assets/www/css/A5System/Vista/tree/n.png (new file)
                                                          mkdir ../app/src/main/assets/www/css/A5System/default
                                                          copy css/A5System/default/theme.css ../app/src/main/assets/www/css/A5System/default/theme.css (new file)
                                                          copy css/A5System/default/theme.js ../app/src/main/assets/www/css/A5System/default/theme.js (new file)
                                                          mkdir ../app/src/main/assets/www/css/A5System/default/tree
                                                          copy css/A5System/default/tree/b.png ../app/src/main/assets/www/css/A5System/default/tree/b.png (new file)
                                                          copy css/A5System/default/tree/bc.png ../app/src/main/assets/www/css/A5System/default/tree/bc.png (new file)
                                                          copy css/A5System/default/tree/bcf.png ../app/src/main/assets/www/css/A5System/default/tree/bcf.png (new file)
                                                          copy css/A5System/default/tree/bcl.png ../app/src/main/assets/www/css/A5System/default/tree/bcl.png (new file)
                                                          copy css/A5System/default/tree/bo.png ../app/src/main/assets/www/css/A5System/default/tree/bo.png (new file)
                                                          copy css/A5System/default/tree/bof.png ../app/src/main/assets/www/css/A5System/default/tree/bof.png (new file)
                                                          copy css/A5System/default/tree/bol.png ../app/src/main/assets/www/css/A5System/default/tree/bol.png (new file)
                                                          copy css/A5System/default/tree/l.png ../app/src/main/assets/www/css/A5System/default/tree/l.png (new file)
                                                          copy css/A5System/default/tree/lf.png ../app/src/main/assets/www/css/A5System/default/tree/lf.png (new file)
                                                          copy css/A5System/default/tree/ll.png ../app/src/main/assets/www/css/A5System/default/tree/ll.png (new file)
                                                          copy css/A5System/default/tree/n.png ../app/src/main/assets/www/css/A5System/default/tree/n.png (new file)
                                                          mkdir ../app/src/main/assets/www/css/A5System/reportStyles
                                                          copy css/A5System/reportStyles/Minimal.css ../app/src/main/assets/www/css/A5System/reportStyles/Minimal.css (new file)
                                                          copy css/A5System/reportStyles/RoundedBandedBlue.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedBandedBlue.css (new file)
                                                          copy css/A5System/reportStyles/RoundedBandedGray.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedBandedGray.css (new file)
                                                          copy css/A5System/reportStyles/RoundedBandedOlive.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedBandedOlive.css (new file)
                                                          copy css/A5System/reportStyles/RoundedBandedTan.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedBandedTan.css (new file)
                                                          copy css/A5System/reportStyles/RoundedBlue.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedBlue.css (new file)
                                                          copy css/A5System/reportStyles/RoundedGray.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedGray.css (new file)
                                                          copy css/A5System/reportStyles/RoundedOlive.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedOlive.css (new file)
                                                          copy css/A5System/reportStyles/RoundedTan.css ../app/src/main/assets/www/css/A5System/reportStyles/RoundedTan.css (new file)
                                                          copy css/A5System/reportStyles/SquareBanded.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareBanded.css (new file)
                                                          copy css/A5System/reportStyles/SquareBandedBlue.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareBandedBlue.css (new file)
                                                          copy css/A5System/reportStyles/SquareBandedGray.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareBandedGray.css (new file)
                                                          copy css/A5System/reportStyles/SquareBandedOlive.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareBandedOlive.css (new file)
                                                          copy css/A5System/reportStyles/SquareBandedTan.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareBandedTan.css (new file)
                                                          copy css/A5System/reportStyles/SquareBlue.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareBlue.css (new file)
                                                          copy css/A5System/reportStyles/SquareGray.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareGray.css (new file)
                                                          copy css/A5System/reportStyles/SquareOlive.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareOlive.css (new file)
                                                          copy css/A5System/reportStyles/SquareTan.css ../app/src/main/assets/www/css/A5System/reportStyles/SquareTan.css (new file)
                                                          mkdir ../app/src/main/assets/www/css/CSSIcons
                                                          mkdir ../app/src/main/assets/www/css/CSSIcons/font-awesome
                                                          mkdir ../app/src/main/assets/www/css/CSSIcons/font-awesome/css
                                                          copy css/CSSIcons/font-awesome/css/font-awesome.min.css ../app/src/main/assets/www/css/CSSIcons/font-awesome/css/font-awesome.min.css (new file)
                                                          mkdir ../app/src/main/assets/www/css/CSSIcons/font-awesome/fonts
                                                          copy css/CSSIcons/font-awesome/fonts/fontawesome-webfont.eot ../app/src/main/assets/www/css/CSSIcons/font-awesome/fonts/fontawesome-webfont.eot (new file)
                                                          copy css/CSSIcons/font-awesome/fonts/fontawesome-webfont.svg ../app/src/main/assets/www/css/CSSIcons/font-awesome/fonts/fontawesome-webfont.svg (new file)
                                                          copy css/CSSIcons/font-awesome/fonts/fontawesome-webfont.ttf ../app/src/main/assets/www/css/CSSIcons/font-awesome/fonts/fontawesome-webfont.ttf (new file)
                                                          copy css/CSSIcons/font-awesome/fonts/fontawesome-webfont.woff ../app/src/main/assets/www/css/CSSIcons/font-awesome/fonts/fontawesome-webfont.woff (new file)
                                                          copy css/CSSIcons/font-awesome/fonts/fontawesome-webfont.woff2 ../app/src/main/assets/www/css/CSSIcons/font-awesome/fonts/fontawesome-webfont.woff2 (new file)
                                                          mkdir ../app/src/main/assets/www/css/CSSIcons/materialIcons
                                                          mkdir ../app/src/main/assets/www/css/CSSIcons/materialIcons/css
                                                          copy css/CSSIcons/materialIcons/css/materialIcons.css ../app/src/main/assets/www/css/CSSIcons/materialIcons/css/materialIcons.css (new file)
                                                          mkdir ../app/src/main/assets/www/css/CSSIcons/materialIcons/fonts
                                                          copy css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.eot ../app/src/main/assets/www/css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.eot (new file)
                                                          copy css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.ttf ../app/src/main/assets/www/css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.ttf (new file)
                                                          copy css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.woff ../app/src/main/assets/www/css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.woff (new file)
                                                          copy css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.woff2 ../app/src/main/assets/www/css/CSSIcons/materialIcons/fonts/MaterialIcons-Regular.woff2 (new file)
                                                          mkdir ../app/src/main/assets/www/css/_sharedStyles
                                                          copy css/_sharedStyles/style.css ../app/src/main/assets/www/css/_sharedStyles/style.css (new file)
                                                          copy css/demoapp_index.css ../app/src/main/assets/www/css/demoapp_index.css (new file)
                                                          mkdir ../app/src/main/assets/www/css/iOS
                                                          copy css/iOS/winClose.png ../app/src/main/assets/www/css/iOS/winClose.png (new file)
                                                          mkdir ../app/src/main/assets/www/css/iOS7
                                                          copy css/iOS7/A5_iOS7Icons.eot ../app/src/main/assets/www/css/iOS7/A5_iOS7Icons.eot (new file)
                                                          copy css/iOS7/A5_iOS7Icons.ttf ../app/src/main/assets/www/css/iOS7/A5_iOS7Icons.ttf (new file)
                                                          copy css/iOS7/A5_iOS7Icons.woff ../app/src/main/assets/www/css/iOS7/A5_iOS7Icons.woff (new file)
                                                          copy css/iOS7/iOS7Icons.woff ../app/src/main/assets/www/css/iOS7/iOS7Icons.woff (new file)
                                                          copy css/iOS7/spinlistOver.png ../app/src/main/assets/www/css/iOS7/spinlistOver.png (new file)
                                                          copy css/iOS7/style.css ../app/src/main/assets/www/css/iOS7/style.css (new file)
                                                          copy css/iOS7/style.dat ../app/src/main/assets/www/css/iOS7/style.dat (new file)
                                                          copy css/iOS7/style.js ../app/src/main/assets/www/css/iOS7/style.js (new file)
                                                          copy css/iOS7/style.json ../app/src/main/assets/www/css/iOS7/style.json (new file)
                                                          copy css/iOS7/style.sass ../app/src/main/assets/www/css/iOS7/style.sass (new file)
                                                          delete ../app/src/main/assets/www/css/index.css (no source)
                                                          copy flat_grey_red_fxg_vector_4x.png ../app/src/main/assets/www/flat_grey_red_fxg_vector_4x.png (new file)
                                                          copy flat_grey_red_plasso_vector_4x.png ../app/src/main/assets/www/flat_grey_red_plasso_vector_4x.png (new file)
                                                          copy icon.png ../app/src/main/assets/www/icon.png (new file)
                                                          copy icon200_white_transparent.png ../app/src/main/assets/www/icon200_white_transparent.png (new file)
                                                          rmdir ../app/src/main/assets/www/img (no source)
                                                          delete ../app/src/main/assets/www/img/cordova.png (no source)
                                                          delete ../app/src/main/assets/www/img/logo.png (no source)
                                                          copy index.html ../app/src/main/assets/www/index.html (updated file)
                                                          mkdir ../app/src/main/assets/www/javascript
                                                          copy javascript/A5jQueryWithUI.js ../app/src/main/assets/www/javascript/A5jQueryWithUI.js (new file)
                                                          copy javascript/a5.js ../app/src/main/assets/www/javascript/a5.js (new file)
                                                          copy javascript/a5_url.js ../app/src/main/assets/www/javascript/a5_url.js (new file)
                                                          rmdir ../app/src/main/assets/www/js (no source)
                                                          delete ../app/src/main/assets/www/js/index.js (no source)
                                                          mkdir ../app/src/main/assets/www/res
                                                          mkdir ../app/src/main/assets/www/res/icon
                                                          copy res/icon.png ../app/src/main/assets/www/res/icon.png (new file)
                                                          mkdir ../app/src/main/assets/www/res/icon/android
                                                          copy res/icon/android/appicon.png ../app/src/main/assets/www/res/icon/android/appicon.png (new file)
                                                          copy res/icon/android/icon-144-xxhdpi.png ../app/src/main/assets/www/res/icon/android/icon-144-xxhdpi.png (new file)
                                                          copy res/icon/android/icon-192-xxxhdpi.png ../app/src/main/assets/www/res/icon/android/icon-192-xxxhdpi.png (new file)
                                                          copy res/icon/android/icon-36-lpdi.png ../app/src/main/assets/www/res/icon/android/icon-36-lpdi.png (new file)
                                                          copy res/icon/android/icon-48-mpdi.png ../app/src/main/assets/www/res/icon/android/icon-48-mpdi.png (new file)
                                                          copy res/icon/android/icon-72-hdpi.png ../app/src/main/assets/www/res/icon/android/icon-72-hdpi.png (new file)
                                                          copy res/icon/android/icon-96-xhdpi.png ../app/src/main/assets/www/res/icon/android/icon-96-xhdpi.png (new file)
                                                          copy res/icon/android/marketplaceArtwork.png ../app/src/main/assets/www/res/icon/android/marketplaceArtwork.png (new file)
                                                          mkdir ../app/src/main/assets/www/res/icon/ios
                                                          copy res/icon/ios/appicon.png ../app/src/main/assets/www/res/icon/ios/appicon.png (new file)
                                                          copy res/icon/ios/icon-40-2x.png ../app/src/main/assets/www/res/icon/ios/icon-40-2x.png (new file)
                                                          copy res/icon/ios/icon-40.png ../app/src/main/assets/www/res/icon/ios/icon-40.png (new file)
                                                          copy res/icon/ios/icon-50-2x.png ../app/src/main/assets/www/res/icon/ios/icon-50-2x.png (new file)
                                                          copy res/icon/ios/icon-50.png ../app/src/main/assets/www/res/icon/ios/icon-50.png (new file)
                                                          copy res/icon/ios/icon-57-2x.png ../app/src/main/assets/www/res/icon/ios/icon-57-2x.png (new file)
                                                          copy res/icon/ios/icon-57.png ../app/src/main/assets/www/res/icon/ios/icon-57.png (new file)
                                                          copy res/icon/ios/icon-60-2x.png ../app/src/main/assets/www/res/icon/ios/icon-60-2x.png (new file)
                                                          copy res/icon/ios/icon-60-3x.png ../app/src/main/assets/www/res/icon/ios/icon-60-3x.png (new file)
                                                          copy res/icon/ios/icon-60.png ../app/src/main/assets/www/res/icon/ios/icon-60.png (new file)
                                                          copy res/icon/ios/icon-72-2x.png ../app/src/main/assets/www/res/icon/ios/icon-72-2x.png (new file)
                                                          copy res/icon/ios/icon-72.png ../app/src/main/assets/www/res/icon/ios/icon-72.png (new file)
                                                          copy res/icon/ios/icon-76-2x.png ../app/src/main/assets/www/res/icon/ios/icon-76-2x.png (new file)
                                                          copy res/icon/ios/icon-76.png ../app/src/main/assets/www/res/icon/ios/icon-76.png (new file)
                                                          copy res/icon/ios/icon-83.5-2x.png ../app/src/main/assets/www/res/icon/ios/icon-83.5-2x.png (new file)
                                                          copy res/icon/ios/icon-small-2x.png ../app/src/main/assets/www/res/icon/ios/icon-small-2x.png (new file)
                                                          copy res/icon/ios/icon-small-3x.png ../app/src/main/assets/www/res/icon/ios/icon-small-3x.png (new file)
                                                          copy res/icon/ios/icon-small.png ../app/src/main/assets/www/res/icon/ios/icon-small.png (new file)
                                                          mkdir ../app/src/main/assets/www/res/icon/ios/itunes
                                                          copy res/icon/ios/itunes/iTunesArtwork.png ../app/src/main/assets/www/res/icon/ios/itunes/iTunesArtwork.png (new file)
                                                          copy res/icon/ios/itunes/iTunesArtwork@2x.png ../app/src/main/assets/www/res/icon/ios/itunes/iTunesArtwork@2x.png (new file)
                                                          mkdir ../app/src/main/assets/www/res/icon/windows-phone
                                                          copy res/icon/windows-phone/appicon.png ../app/src/main/assets/www/res/icon/windows-phone/appicon.png (new file)
                                                          copy res/icon/windows-phone/icon-173-tile.png ../app/src/main/assets/www/res/icon/windows-phone/icon-173-tile.png (new file)
                                                          copy res/icon/windows-phone/icon-48.png ../app/src/main/assets/www/res/icon/windows-phone/icon-48.png (new file)
                                                          copy res/icon/windows-phone/icon-62-tile.png ../app/src/main/assets/www/res/icon/windows-phone/icon-62-tile.png (new file)
                                                          copy res/icon/windows-phone/icon-tile-173.png ../app/src/main/assets/www/res/icon/windows-phone/icon-tile-173.png (new file)
                                                          copy res/icon/windows-phone/icon-tile-62.png ../app/src/main/assets/www/res/icon/windows-phone/icon-tile-62.png (new file)
                                                          copy res/icon/windows-phone/logo.png ../app/src/main/assets/www/res/icon/windows-phone/logo.png (new file)
                                                          copy res/icon/windows-phone/smallLogo.png ../app/src/main/assets/www/res/icon/windows-phone/smallLogo.png (new file)
                                                          copy res/icon/windows-phone/square150x150logo.scale-100.png ../app/src/main/assets/www/res/icon/windows-phone/square150x150logo.scale-100.png (new file)
                                                          copy res/icon/windows-phone/square150x150logo.scale-240.png ../app/src/main/assets/www/res/icon/windows-phone/square150x150logo.scale-240.png (new file)
                                                          copy res/icon/windows-phone/square30x30logo.scale-100.png ../app/src/main/assets/www/res/icon/windows-phone/square30x30logo.scale-100.png (new file)
                                                          copy res/icon/windows-phone/square310x310logo.scale-100.png ../app/src/main/assets/www/res/icon/windows-phone/square310x310logo.scale-100.png (new file)
                                                          copy res/icon/windows-phone/square44x44logo.scale-100.png ../app/src/main/assets/www/res/icon/windows-phone/square44x44logo.scale-100.png (new file)
                                                          copy res/icon/windows-phone/square44x44logo.scale-240.png ../app/src/main/assets/www/res/icon/windows-phone/square44x44logo.scale-240.png (new file)
                                                          copy res/icon/windows-phone/square71x71logo.scale-100.png ../app/src/main/assets/www/res/icon/windows-phone/square71x71logo.scale-100.png (new file)
                                                          copy res/icon/windows-phone/square71x71logo.scale-240.png ../app/src/main/assets/www/res/icon/windows-phone/square71x71logo.scale-240.png (new file)
                                                          copy res/icon/windows-phone/storelogo.scale-100.png ../app/src/main/assets/www/res/icon/windows-phone/storelogo.scale-100.png (new file)
                                                          copy res/icon/windows-phone/storelogo.scale-240.png ../app/src/main/assets/www/res/icon/windows-phone/storelogo.scale-240.png (new file)
                                                          copy res/icon/windows-phone/wide310x150logo.scale-100.png ../app/src/main/assets/www/res/icon/windows-phone/wide310x150logo.scale-100.png (new file)
                                                          copy res/icon/windows-phone/wide310x150logo.scale-240.png ../app/src/main/assets/www/res/icon/windows-phone/wide310x150logo.scale-240.png (new file)
                                                          mkdir ../app/src/main/assets/www/res/screen
                                                          mkdir ../app/src/main/assets/www/res/screen/android
                                                          copy res/screen/android/marketplaceArtworkFeature.png ../app/src/main/assets/www/res/screen/android/marketplaceArtworkFeature.png (new file)
                                                          copy res/screen/android/screen-hdpi-landscape.png ../app/src/main/assets/www/res/screen/android/screen-hdpi-landscape.png (new file)
                                                          copy res/screen/android/screen-hdpi-portrait.png ../app/src/main/assets/www/res/screen/android/screen-hdpi-portrait.png (new file)
                                                          copy res/screen/android/screen-hdpi-universal.9.png ../app/src/main/assets/www/res/screen/android/screen-hdpi-universal.9.png (new file)
                                                          copy res/screen/android/screen-ldpi-landscape.png ../app/src/main/assets/www/res/screen/android/screen-ldpi-landscape.png (new file)
                                                          copy res/screen/android/screen-ldpi-portrait.png ../app/src/main/assets/www/res/screen/android/screen-ldpi-portrait.png (new file)
                                                          copy res/screen/android/screen-ldpi-universal.9.png ../app/src/main/assets/www/res/screen/android/screen-ldpi-universal.9.png (new file)
                                                          copy res/screen/android/screen-mdpi-landscape.png ../app/src/main/assets/www/res/screen/android/screen-mdpi-landscape.png (new file)
                                                          copy res/screen/android/screen-mdpi-portrait.9.png ../app/src/main/assets/www/res/screen/android/screen-mdpi-portrait.9.png (new file)
                                                          copy res/screen/android/screen-mdpi-portrait.png ../app/src/main/assets/www/res/screen/android/screen-mdpi-portrait.png (new file)
                                                          copy res/screen/android/screen-mdpi-universal.9.png ../app/src/main/assets/www/res/screen/android/screen-mdpi-universal.9.png (new file)
                                                          copy res/screen/android/screen-xhdpi-landscape.png ../app/src/main/assets/www/res/screen/android/screen-xhdpi-landscape.png (new file)
                                                          copy res/screen/android/screen-xhdpi-n7-landscape.png ../app/src/main/assets/www/res/screen/android/screen-xhdpi-n7-landscape.png (new file)
                                                          copy res/screen/android/screen-xhdpi-n7-portrait.png ../app/src/main/assets/www/res/screen/android/screen-xhdpi-n7-portrait.png (new file)
                                                          copy res/screen/android/screen-xhdpi-portrait.png ../app/src/main/assets/www/res/screen/android/screen-xhdpi-portrait.png (new file)
                                                          copy res/screen/android/screen-xhdpi-universal.9.png ../app/src/main/assets/www/res/screen/android/screen-xhdpi-universal.9.png (new file)
                                                          copy res/screen/android/screen-xxhdpi-landscape.png ../app/src/main/assets/www/res/screen/android/screen-xxhdpi-landscape.png (new file)
                                                          copy res/screen/android/screen-xxhdpi-n7-landscape.png ../app/src/main/assets/www/res/screen/android/screen-xxhdpi-n7-landscape.png (new file)
                                                          copy res/screen/android/screen-xxhdpi-n7-portrait.png ../app/src/main/assets/www/res/screen/android/screen-xxhdpi-n7-portrait.png (new file)
                                                          copy res/screen/android/screen-xxhdpi-portrait.png ../app/src/main/assets/www/res/screen/android/screen-xxhdpi-portrait.png (new file)
                                                          copy res/screen/android/screen-xxhdpi-universal.9.png ../app/src/main/assets/www/res/screen/android/screen-xxhdpi-universal.9.png (new file)
                                                          copy res/screen/android/screen-xxxhdpi-landscape.png ../app/src/main/assets/www/res/screen/android/screen-xxxhdpi-landscape.png (new file)
                                                          copy res/screen/android/screen-xxxhdpi-portrait.png ../app/src/main/assets/www/res/screen/android/screen-xxxhdpi-portrait.png (new file)
                                                          copy res/screen/android/screen-xxxhdpi-universal.9.png ../app/src/main/assets/www/res/screen/android/screen-xxxhdpi-universal.9.png (new file)
                                                          mkdir ../app/src/main/assets/www/res/screen/ios
                                                          copy res/screen/ios/Default@2x~universal~anyany.png ../app/src/main/assets/www/res/screen/ios/Default@2x~universal~anyany.png (new file)
                                                          copy res/screen/ios/Default@2x~universal~comany.png ../app/src/main/assets/www/res/screen/ios/Default@2x~universal~comany.png (new file)
                                                          copy res/screen/ios/Default@2x~universal~comcom.png ../app/src/main/assets/www/res/screen/ios/Default@2x~universal~comcom.png (new file)
                                                          copy res/screen/ios/Default@3x~universal~anyany.png ../app/src/main/assets/www/res/screen/ios/Default@3x~universal~anyany.png (new file)
                                                          copy res/screen/ios/Default@3x~universal~anycom.png ../app/src/main/assets/www/res/screen/ios/Default@3x~universal~anycom.png (new file)
                                                          copy res/screen/ios/Default@3x~universal~comany.png ../app/src/main/assets/www/res/screen/ios/Default@3x~universal~comany.png (new file)
                                                          copy res/screen/ios/screen-ipad-landscape-2x.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-landscape-2x.png (new file)
                                                          copy res/screen/ios/screen-ipad-landscape.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-landscape.png (new file)
                                                          copy res/screen/ios/screen-ipad-portrait-2x.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-portrait-2x.png (new file)
                                                          copy res/screen/ios/screen-ipad-portrait.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-portrait.png (new file)
                                                          copy res/screen/ios/screen-ipad-pro-landscape-3x.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-pro-landscape-3x.png (new file)
                                                          copy res/screen/ios/screen-ipad-pro-portrait-3x.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-pro-portrait-3x.png (new file)
                                                          copy res/screen/ios/screen-ipad-pro10-landscape-3x.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-pro10-landscape-3x.png (new file)
                                                          copy res/screen/ios/screen-ipad-pro10-portrait-3x.png ../app/src/main/assets/www/res/screen/ios/screen-ipad-pro10-portrait-3x.png (new file)
                                                          copy res/screen/ios/screen-iphone-landscape-568h-2x.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-landscape-568h-2x.png (new file)
                                                          copy res/screen/ios/screen-iphone-landscape-667h-2x.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-landscape-667h-2x.png (new file)
                                                          copy res/screen/ios/screen-iphone-landscape-736h-3x.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-landscape-736h-3x.png (new file)
                                                          copy res/screen/ios/screen-iphone-portrait-2x.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-portrait-2x.png (new file)
                                                          copy res/screen/ios/screen-iphone-portrait-568h-2x.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-portrait-568h-2x.png (new file)
                                                          copy res/screen/ios/screen-iphone-portrait-667h-2x.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-portrait-667h-2x.png (new file)
                                                          copy res/screen/ios/screen-iphone-portrait-736h-3x.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-portrait-736h-3x.png (new file)
                                                          copy res/screen/ios/screen-iphone-portrait.png ../app/src/main/assets/www/res/screen/ios/screen-iphone-portrait.png (new file)
                                                          copy res/screen/ios/screen-iphonex-landscape.png ../app/src/main/assets/www/res/screen/ios/screen-iphonex-landscape.png (new file)
                                                          copy res/screen/ios/screen-iphonex-portrait.png ../app/src/main/assets/www/res/screen/ios/screen-iphonex-portrait.png (new file)
                                                          mkdir ../app/src/main/assets/www/res/screen/windows-phone
                                                          copy res/screen/windows-phone/portrait.png ../app/src/main/assets/www/res/screen/windows-phone/portrait.png (new file)
                                                          copy res/screen/windows-phone/screen-portrait.jpg ../app/src/main/assets/www/res/screen/windows-phone/screen-portrait.jpg (new file)
                                                          copy res/screen/windows-phone/screen-portrait.png ../app/src/main/assets/www/res/screen/windows-phone/screen-portrait.png (new file)
                                                          copy res/screen/windows-phone/screen.scale-240.png ../app/src/main/assets/www/res/screen/windows-phone/screen.scale-240.png (new file)
                                                          copy res/screen/windows-phone/splashscreenphone.scale-240.png ../app/src/main/assets/www/res/screen/windows-phone/splashscreenphone.scale-240.png (new file)
                                                          copy res/splash.9.png ../app/src/main/assets/www/res/splash.9.png (new file)
                                                          copy res/splash.png ../app/src/main/assets/www/res/splash.png (new file)
                                                          copy screen.png ../app/src/main/assets/www/screen.png (new file)
                                                          copy splash.9.png ../app/src/main/assets/www/splash.9.png (new file)
                                                          copy splash.png ../app/src/main/assets/www/splash.png (new file)
                                                          copy version.json ../app/src/main/assets/www/version.json (new file)
                                                        Wrote out android application name "eTruckBiz" to /app/src/main/res/values/strings.xml
                                                        android-versionCode not found in config.xml. Generating a code based on version in config.xml (5.4.0): 50400
                                                        Wrote out Android package name "com.etruckbiz.timekeeper" to /app/src/main/java/com/etruckbiz/timekeeper/eTruckBiz.java
                                                        Found extra default icon: res/icon/android/icon-36-ldpi.png (ignoring in favor of icon.png)
                                                        Found extra default icon: res/icon/android/icon-48-mdpi.png (ignoring in favor of icon.png)
                                                        Found extra default icon: res/icon/android/icon-72-hdpi.png (ignoring in favor of icon.png)
                                                        Found extra default icon: res/icon/android/icon-96-xhdpi.png (ignoring in favor of icon.png)
                                                        Found extra default icon: res/icon/android/icon-144-xxhdpi.png (ignoring in favor of icon.png)
                                                        Found extra default icon: res/icon/windows-phone/icon-48.png (ignoring in favor of icon.png)
                                                        Found extra default icon: res/icon/windows-phone/icon-62-tile.png (ignoring in favor of icon.png)
                                                        Updating icons at ../app/src/main/res
                                                          copy res/icon/ios/icon-72.png ../app/src/main/res/mipmap-hdpi/icon.png (updated file)
                                                          delete ../app/src/main/res/mipmap-ldpi/icon.png (no source)
                                                          copy icon.png ../app/src/main/res/mipmap-mdpi/icon.png (updated file)
                                                          delete ../app/src/main/res/mipmap-xhdpi/icon.png (no source)
                                                          copy res/icon/ios/icon-72-2x.png ../app/src/main/res/mipmap-xxhdpi/icon.png (updated file)
                                                          delete ../app/src/main/res/mipmap-xxxhdpi/icon.png (no source)
                                                        Updating splash screens at ../app/src/main/res
                                                          delete ../app/src/main/res/drawable-land-hdpi/screen.png (no source)
                                                          delete ../app/src/main/res/drawable-land-ldpi/screen.png (no source)
                                                          delete ../app/src/main/res/drawable-land-mdpi/screen.png (no source)
                                                          delete ../app/src/main/res/drawable-land-xhdpi/screen.png (no source)
                                                          delete ../app/src/main/res/drawable-land-xxhdpi/screen.png (no source)
                                                          delete ../app/src/main/res/drawable-land-xxxhdpi/screen.png (no source)
                                                          copy res/screen/windows-phone/screen.scale-240.png ../app/src/main/res/drawable-mdpi/screen.png (new file)
                                                          copy res/screen/android/screen-hdpi-universal.9.png ../app/src/main/res/drawable-port-hdpi/screen.9.png (new file)
                                                          delete ../app/src/main/res/drawable-port-hdpi/screen.png (no source)
                                                          copy res/screen/android/screen-ldpi-universal.9.png ../app/src/main/res/drawable-port-ldpi/screen.9.png (new file)
                                                          delete ../app/src/main/res/drawable-port-ldpi/screen.png (no source)
                                                          copy res/screen/android/screen-mdpi-universal.9.png ../app/src/main/res/drawable-port-mdpi/screen.9.png (new file)
                                                          delete ../app/src/main/res/drawable-port-mdpi/screen.png (no source)
                                                          copy res/screen/android/screen-xhdpi-universal.9.png ../app/src/main/res/drawable-port-xhdpi/screen.9.png (new file)
                                                          delete ../app/src/main/res/drawable-port-xhdpi/screen.png (no source)
                                                          copy res/screen/android/screen-xxhdpi-universal.9.png ../app/src/main/res/drawable-port-xxhdpi/screen.9.png (new file)
                                                          delete ../app/src/main/res/drawable-port-xxhdpi/screen.png (no source)
                                                          copy res/screen/android/screen-xxxhdpi-universal.9.png ../app/src/main/res/drawable-port-xxxhdpi/screen.9.png (new file)
                                                          delete ../app/src/main/res/drawable-port-xxxhdpi/screen.png (no source)
                                                        This app does not have additional resource files defined
                                                        Prepared android project successfully
                                                        PLUGIN OUTPUT
                                                        Fetching plugin "cordova-plugin-network-information@1.3.4" via npm
                                                        Fetching plugin "cordova-plugin-splashscreen@4.1.0" via npm
                                                        Fetching plugin "cordova-plugin-whitelist@1.3.3" via npm
                                                        Fetching plugin "cordova-plugin-console@1.1.0" via npm
                                                        Fetching plugin "cordova-plugin-media-capture@1.4.3" via npm
                                                        Installing "cordova-plugin-media-capture" at "1.4.3" for android
                                                        Fetching plugin "cordova-plugin-file@^4.0.0" via npm
                                                        Installing "cordova-plugin-file" at "4.3.3" for android
                                                        Plugin doesn't support this project's cordova-android version. cordova-android: 7.0.0, failed version requirement:
                                                          <6.3.0
                                                        Skipping 'cordova-plugin-compat' for android
                                                        The Android Persistent storage location now defaults to "Internal". Please check this plugin's README to see if your application needs any changes in its config.xml.
                                                        If this is a new application no changes are required.
                                                        If this is an update to an existing application that did not specify an "AndroidPersistentFileLocation" you may need to add:
                                                          "<preference name="AndroidPersistentFileLocation" value="Compatibility" />"
                                                        to config.xml in order for the application to find previously stored files.
                                                        Plugin dependency "cordova-plugin-compat@1.2.0" already fetched, using that version.
                                                          <6.3.0
                                                        Fetching plugin "cordova-plugin-contacts@2.3.1" via npm
                                                        Installing "cordova-plugin-contacts" at "2.3.1" for android
                                                          <6.3.0
                                                        Fetching plugin "cordova-plugin-device@1.1.7" via npm
                                                        Fetching plugin "cordova-plugin-geolocation@2.4.3" via npm
                                                        Installing "cordova-plugin-geolocation" at "2.4.3" for android
                                                          <6.3.0
                                                        Fetching plugin "cordova-plugin-inappbrowser@1.7.2" via npm
                                                        Fetching plugin "cordova-plugin-media@3.0.1" via npm
                                                        Installing "cordova-plugin-media" at "3.0.1" for android
                                                        Plugin dependency "cordova-plugin-file@4.3.3" already fetched, using that version.
                                                        Dependent plugin "cordova-plugin-file" already installed on android.
                                                          <6.3.0
                                                        Fetching plugin "cordova-plugin-dialogs@1.3.4" via npm
                                                        Fetching plugin "cordova-plugin-camera-with-exif" via npm
                                                        Installing "cordova-plugin-camera-with-exif" at "1.2.2" for android
                                                          <6.3.0
                                                        Subproject Path: app
                                                        "plugman-151 install --platform android --project --plugin cordova-plugin-file-transfer@1.5.1 --nohooks=.": Fetching plugin "cordova-plugin-file-transfer@1.5.1" via npm
                                                        Installing "cordova-plugin-file-transfer" at "1.5.1" for android
                                                        Failed to install 'cordova-plugin-file-transfer': Error: ENOENT: no such file or directory, open '/AndroidManifest.xml'
                                                          at Error (native)
                                                          at Object.fs.openSync (fs.js:640:18)
                                                          at Object.fs.readFileSync (fs.js:508:33)
                                                          at Object.parseElementtreeSync (/cordova/node_modules/cordova-common/src/util/xml-helpers.js:180:27)
                                                          at new AndroidManifest (/cordova/lib/AndroidManifest.js:29:20)
                                                          at AndroidProject.getPackageName (/cordova/lib/AndroidProject.js:99:12)
                                                          at Api.addPlugin (/cordova/Api.js:223:57)
                                                          at handleInstall (/usr/local/lib/npm/lib/node_modules/pgb-plugman-151/node_modules/pgb-cordova-lib/src/plu gman/install.js:594:10)
                                                          at /usr/local/lib/npm/lib/node_modules/pgb-plugman-151/node_modules/pgb-cordova-lib/src/plug man/install.js:364:24
                                                          at _fulfilled (/usr/local/lib/npm/lib/node_modules/pgb-plugman-151/node_modules/q/q.js:787:54)
