• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
How to change line width after it is drawn?
Guest
Nov 13, 2017 Nov 13, 2017
Hello,
I started a project hand drawn, using the brush tool at size 3, and then somehow didn't catch that some frames are drawn with brush size 4.
I can't find anything in the program that allows me to select frame and change brush width.
Please help!
TOPICS
How to
Views
21.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Nov 14, 2017 Nov 14, 2017
You can't ex post facto change the thickness of brush strokes, because brush strokes are converted to outlines when they're drawn. From that point it's just a shape as far as Animate is concerned. If you want to draw strokes that you can change the thickness of, use the pen, pencil, or paintbrush tools.
Votes
Translate
Translate
Community Expert ,
If these are normal paths you've laid down, you will need to select all the objects and then adjust the stroke value. Use the selection tool to choose them all.
Votes
Translate
Translate
Report
Report
Guest
When I select everything I want to change, I don't see an option for input to adjust the stroke value and I couldn't find anything in the tabs / modify tab either
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Community Expert ,
Nov 15, 2017 Nov 15, 2017
Ah yes - I was thinking the new paint brush tool!
Votes
Translate
Translate
Report
Report
Community Expert ,
If you were using the regular brush, your lines are just regular fills. So you can't automatically change the width.
One emergency fix you can try is to:
- Get the Ink Bottle Tool (S);
- Set its stroke height to 2;
- Click on each of your brush strokes at size 4;
- Select all these clicked fills along with their added strokes;
- Go to Modify > Shape > Convert Lines to Fills;
- Select the strokes converted to fills using the Selection Tool (V);
- Delete these converted strokes.
You should now have brush strokes with similar sizes.
Alternatively, you can do all the previous steps with the brush strokes at size 3. But instead of deleting them, you are going to leave them with the same color used originally by each brush stroke.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Nov 21, 2022 Nov 21, 2022
thank you bro. weird though
Votes
Translate
Translate
Report
Report
LATEST
Another tip: control/adjust/change fill and stroke on Adobe Animate CC by using the primitive tool (e.g. Oval Primitive Tool) instead of the tool (e.g. Oval Tool).
Votes
Translate
Translate
Report
Report
