6 Replies Latest reply on Nov 15, 2017 1:09 PM by JJMack
    Receiving message The command "Make" is not currently available
    b5photo Level 1
      I have a variety of actions that use Make -> New: channel At: mask channel Using: reveal all
      I am receiving an error message stating The command "Make" is not currently available.  I have a new laptop using Windows 10.  I was previously on Windows 7.  I upgraded to the latest version of Photoshop CC(Release 19.0) however reverting back to previous available versions has made no difference.  I had no issue prior to upgrading my laptop.  I appreciate any help that you can provide.
        • 1. Re: Receiving message The command "Make" is not currently available
          Chuck Uebele Adobe Community Professional & MVP
          Have you tried re-recording that step? I got PS to give me that error if the layer already had a layer mask.
          • 2. Re: Receiving message The command "Make" is not currently available
            When you get this message does the current layer in the document have a layer mask? If it does the message is correct for the layer has a layer mask.  You can not create an additional raster reveal all layer make on a layer that has a mask.  Actions have dependences when these are not meet actions fail.  Command not available is a common error message one gets when a command requirement is missing.
            This is a proper error message in the following example.
            • 3. Re: Receiving message The command "Make" is not currently available
              b5photo Level 1
              These are a set of actions that I purchased over 3 years ago and have used thousands of times(many other users would have the same actions set).  They have never thrown an error so I am not following how this is now all of the sudden an issue.  The only thing that has changed is the device that I am using, the operating system and the version of Photoshop. I don't have a great working knowledge of building actions at this level so I guess at this point I am looking for advice on how I could change the action set in order to correct and not affect the overall functionality of what the action was trying to accomplish.  Thanks
              • 4. Re: Receiving message The command "Make" is not currently available
                I ask a very simple question. When that action failed with that error message.  Did the document active layer have a Layer mask..  If the document active layer had a layer mask the action could nor add a reveal all layer mask to the layer for the layer had a layer mask. That would cause the error.  The Action can run on document the layer have nor layer mask.  However if the current target layer has a layer mask when you play the action it will fail.
                Action steps may have dependencies.  It is very difficult to craft an action the will always play correctly on every document.  A document in CMYK mode can cause an action created for RGB mode documents to fail.   You may have use the action on thousands of documents.  That is no guarantee that the action will work on all documents.  Conditions can cause Action to fail. An  active selection may cause and action to fail.  A RAW file opened as a smart object layer will cause an action that select the background layer to fail for there is no background layer.  Most actions have dependencies.
                I have seen many poor action over the years.   I do not believe that I have ever downloaded an action that I did not edit to make it work better in my workflow.   I would never buy an action they are just a sequence id Photoshop steps.   I only download action to see how other user Photoshop.  Reading other actions can be very educational.
                Crafting Actions Package  UPDATED Aug 10, 2014 Added Conditional Action steps to Action Palette Tips.
                Contains
                Download
                • 5. Re: Receiving message The command "Make" is not currently available
                  b5photo Level 1
                  I figured out the issue.  Inside Layers Palette -> Panel Options, I had to un-check Use Default Masks on Fill Layers.  In Adjustments Palette the Add Mask by Default needs to be checked.
                  • 6. Re: Receiving message The command "Make" is not currently available
                    Yes Adobe added some bug in CS4 when they added the Adjustment Panel.  Its fly-out menu Item can brake actions if you change some items from Adobe's default settings. Actions that add Adjustment layers will likely fail one way or another.   I Asked many at Adobe to fix this bug by removing the to bad options from the fly-out menu they act more like Photoshop Preferences. The Problem is Actions and Scripts can not change then or even find out how they are set.   The option may change the way Photoshop behaves where steps will not play the way they were recorded.  However Photoshop does not always work the way the menu Item are set. So if you  have a broken action you can edit it and force it to work.   If there is a selection a layer mask will be addled when the menu item is set not to add a layer mask and  the Adjustment  layer will be clipped if when your record the step using the layer menu and add the clip option in its the pop-up dialog.   I do not know why Adobe chooses not to fix some reported and acknowledge bugs.  I gave up year ago fighting with Adobe I work around the bugs Adobe does not fix.
