11 Replies Latest reply on May 8, 2008 10:20 AM by Rapatski
    Filthy _alpha values: -2.874 ...why?!?
    Rapatski
      Dear all,
      I'm pretty puzzled. How can Flash, who has always served me as a loyal calculator make such a mess?
      this.mc.onEnterFrame = function() {
      trace(this._alpha);
      this._alpha--
      traces this:
      100
      98.828125
      97.65625
      96.484375
      95.3125
      94.140625
      etc.
      Why?!!
        • 1. Re: Filthy _alpha values: -2.874 ...why?!?
          Level 7
          Rapatski,
          Heh. Flash is loyal as long as you're calculating within its limits.
          ;) Don't try to calculate anything beyond 15 significant digits.
          > trace(this._alpha);
          > this._alpha--
          > traces this:
          > 100
          > 98.828125
          > 97.65625
          The _alpha property is stored internally as a range from 0 to 255. When
          Flash gives you that 0 to 100 range, it's giving you a translation.
          Sham Bhangal mentions a work-around in his Flash Hacks (O'Reilly) book,
          in which you create a stand-in variable, decrement (or increment) that, then
          use that variable to set the _alpha property.
          mc.alphaStandin = 100;
          mc.onEnterFrame = function():Void {
          trace(this.alphaStandin);
          this.alphaStandin--;
          this._alpha = this.alphaStandin;
          David Stiller
          Co-author, Foundation Flash CS3 for Designers
          http://tinyurl.com/2k29mj
          "Luck is the residue of good design."
          • 2. Filthy _alpha values: -2.874 ...why?!?
            That's interesting... worth a little digging... it's even more inconsistent if you try:
            var Direction = 1;
            this.onEnterFrame = function() {
            trace(this._alpha);
            this._alpha -= Direction;
            Direction *= -1;
            When reducing it drops ~1.2, but when increasing it only rises ~0.8
            output:
            100
            98.828125
            99.609375
            98.4375
            99.21875...
            Maybe it has a built-in easing of some odd sort?
            • 3. Re: Filthy _alpha values: -2.874 ...why?!?
              Rapatski Level 1
              Haha unbelievable.. the first time in ages I visit the boards again and within minutes it's David that answers my question...
              Tiemen
              • 4. Re: Filthy _alpha values: -2.874 ...why?!?
                actually _alpha varies from 0 to 256, not 0 to 255. it would seem like it should vary from 0 to 255, but it doesn't.
                anyway, ds is correct: you're all seeing the numbers you're displaying because of rounding.
                • 5. Re: Filthy _alpha values: -2.874 ...why?!?
                  Level 7
                  HA! I thought that username looks familiar ... but I didn't put
                  two-and-two together.
                  David
                  stiller@quip.net
                  "Rapatski" <webforumsuser@macromedia.com> wrote in message
                  news:fvtukc$2cq$1@forums.macromedia.com...
                  > Thanks,
                  > Tiemen
                  • 6. Re: Filthy _alpha values: -2.874 ...why?!?
                    Level 7
                    kglad,
                    Not saying I doubt your findings, but I'm curious how you arrive at 0 to
                    256? I checked Sham's book again and he (perhaps incorrectly) states 0 to
                    256, which makes immediate sense to me because 256 is 2 to the 8th power.
                    David Stiller
                    Adobe Community Expert
                    Dev blog, http://www.quip.net/blog/
                    "kglad" <webforumsuser@macromedia.com> wrote in message
                    news:fvu3o5$6vp$1@forums.macromedia.com...
                    • 7. Re: Filthy _alpha values: -2.874 ...why?!?
                      Level 7
                      Well, I screwed up that reply, didn't I? :-p
                      Sham's book says 0 to 255, which is a range of 256 values, hence 2 to
                      the 8th.
                      David Stiller
                      • 8. Re: Filthy _alpha values: -2.874 ...why?!?
                        test in flash.
                        create a movieclip assign its alpha to any multiple of 1/255 and then trace that mulitple of 1/255 and trace the alpha. they'll be different (by 1/255-1/256, unless the multiple is zero or less or greater than 100).
                        now test using any multiple of 1/256.
                        and i agree, it should be 0 to 255. but it's just not. if jeckyll were still here he could probably tell us why.
                        • 9. Re: Filthy _alpha values: -2.874 ...why?!?
                          Level 7
                          kglad,
                          > greater than 100).
                          Heh.
                          Yep. Can't argue with that.
                          I miss jeckyll. His _alpha has been 0 for a while now.
                          David Stiller
                          • 10. Re: Filthy _alpha values: -2.874 ...why?!?
                            yes, jeckyll brought a unique perspective and knowledge base to the discussion.
                            • 11. Re: Filthy _alpha values: -2.874 ...why?!?
                              Rapatski Level 1
                              Pff, give me a chance. Now I know this, it surely can't be long for some very unique perspective to be coming from this corner... ;)
