4 Replies Latest reply on May 8, 2008 7:19 AM by adam@blueapplestudio
    Need help generating variable name for timeout object
    adam@blueapplestudio Level 1
      Below is a function I am using to scale an object down and then hide it. It works fine on just one object, but if I try to run it on multiple objects at the same time, only the last object gets scaled down. I believe this is because the timeout list only ever has a single item in it, “ShrinkTimeOut”.
      Does each entity in the timeout list need a distinct name? And if so, how would I dynamically generate a name and save it so I can kill the timeout object once the object has scaled down fully?
